driver voor Traxdata 2260plus?
  • Ivke
  • Registratie: December 1999
  • Laatst online: 07-01-2003
Heeft iemand 'n idee waar ik een driver voor m'n (oude)brander kan vinden?
de Traxdata site is al geruime tijd down dus daar kan ik geen driver van downloaden...
"I'd change the world but God won't give me the source code"
  • Diamon
  • Laatst online: 27-08 13:00
Diamon
The Weird One
First, Firmware is drivers. Second, you only need CD drivers for DOS mode, and not for windows. Check in system properties, to see if your Primary or secondary IDE controller is working properly. If driver is wrong for controller, it will force CD to run in dos compatibility mode, which can make it useless. Also check properties for CDRW, and make sure there is no check in DMA box.
Firmware kun je hier leechen.
Firmware per CDRW 2260 Plus, v3.09
Aggiunge il supporto dei CD da 80 Minuti
22602.zip / 0.4 MB / 6 minutes @ 28.8
Je hebt dus geen echte driver nodig, alleen onder DOS
And The Only One
