VooDoo XP... hoeveel moet ik hiervan geloven???
do not try this at home folks ;)
het onderstaande heb ik gelezen in een nieuwsgroep...
______________
I read it on another board about how to install Voodoo 5 Drivers to get the best possible performance under Windows XP. I tried and tested it, eveything works just perfect now, before my NHL 2002 was playing not that good and i wasn't able to see some of the effects in it and the game speed has increased and i coudn't use all the screen savers in Windows XP themes that come with Windows XP Plus! Now they are working fine, which means now my 3D part of the card is working properly.
Its not my idea ( I am not stealing it, i am not the one who wrote it but i read it from a board)
ok now get to the point:
1) Search for the words "Glide" and "3dfx" in your system registry and delete keys, values or folders that have these words in them.(delete all instances)
2) Go to device manager and change the Video Card to something else like "Sound Blaster's" card or something.
3) Reboot, download Windows 2000 drivers for Voodoo 5 from http://www.3dfx.com, install them, when it ask you about over writing the files make sure you say "yes", overwrite all the files, finish installation, reboot.
Your system will have fully functional Voodoo 5 64MB AGP Card with all the capabilities as it had in Windows 2000 Professional. (Don;t worry about the .dll errors during the installation, just ignore them)
Have fun. I hope this helps for those who need it.
But hey, if you mess your your computer, don;t blame me or this board. its your own responsibility.
___________
hoeveel zou er van waar zijn? Wie is wil er 't ff uitproberen ;) veel suc6 zou'k zeggen!
  • salvador4
  • Laatst online: 16-08 15:17
Waarom probeer je het zelf niet, in windows xp zit zo'n handige restore optie, dus je zegt ff dat je zo'n store point wil maken, (of begin v/d week automatisch) test het, werkt het niet, backup er over heen, klaar.
Of je installeerd win gewoon ff op een andere partitie, ben je ok zo klaar. Lijkt me sterk dat je je kaart ermee om zeep helpt.
weet je wat? je hebt helemaal gelijk! Ik ga't proberen!
als 't niets is/wordt dan hoort iedereen dat wel...!
Laat nog ff weten of het werkt dan hebben anderen er ook wat aan :)
Was dit niet allang duidelijk dan? Dat je simpelweg Win2K drivers moet installen?
ben aan't k(*&ten met WinXP
verwacht dat ik morgen of anders vrijdag as. resultaten kan laten zien!
morgen = vrijdag :D maar laat het ff weten =]
tering laat ffies zsm weten :) ik zit in precies hetzelfde schuitje :'(
Heej allemaal... ik ben ermee bezig hoor... ff winXP opnieuw installeren want het was zo'n mess in mijn system32 map... heb al zo'n 10 verschillende drivers geïnstalleerd dus ja, lijkt op .dll-soep.... :) 8-)
Take it easy and let us know :)
Dat hele verhaal heb ik hier al gepost. Werkt perfect dus... ik heb het al 3 weken draaien zo....
Alhoewel bovenstaande verhaal niet helemaal klopt, kom je er wel uit zo.... anders kijk even hier:
[topic=282717/1/25]
Afbeeldingslocatie: http://members.home.nl/website/3dfxdriver.jpg
Afbeeldingslocatie: http://members.home.nl/website/3dfxclock.jpg
