Kernel 2.4.10-ac3: Compile-fout
  • huijaa
  • Laatst online: 20-05-2024
Patch van 2.4.10-ac3 succesvol uitgevoerd, en er genereert een foutmelding na 'make dep bzImage':
ld -m elf_i386 -T /usr/src/linux-2.4.10/arch/i386/vmlinux.lds -e stext arch/i386/kernel/head.o arch/i386/kernel/init_task.o init/main.o init/version.o \
--start-group \
arch/i386/kernel/kernel.o arch/i386/mm/mm.o kernel/kernel.o mm/mm.o fs/fs.o ipc/ipc.o \
drivers/acpi/acpi.o drivers/parport/driver.o drivers/char/char.o drivers/block/block.o drivers/misc/misc.o drivers/net/net.o drivers/media/media.o drivers/char/agp/agp.o drivers/char/drm-4.0/drm.o drivers/ide/idedriver.o drivers/cdrom/driver.o drivers/sound/sounddrivers.o drivers/pci/driver.o drivers/pnp/pnp.o drivers/video/video.o drivers/usb/usbdrv.o \
net/network.o \
/usr/src/linux-2.4.10/arch/i386/lib/lib.a /usr/src/linux-2.4.10/lib/lib.a /usr/src/linux-2.4.10/arch/i386/lib/lib.a \
--end-group \
-o vmlinux
drivers/ide/idedriver.o: In function `ide_build_sglist':
drivers/ide/idedriver.o(.text+0x53ec): undefined reference to `flush_write_buffers'
make: *** [vmlinux] Error 1
Iemand een *D idee :?
since 21aug'04: Asus K8VSE Deluxe, AMD Athlon 64 3400+, Twimos 1 GB PC3200, Maxtor U133/7200 160GB+120GB, Asus V9999GE and SunBeam Aryclic Case
  • Sjonny
  • Laatst online: 08:34
Sjonny
Fratser
check de includes van die file, is er vast een missing.
probeer met
$ grep -r flush_write_buffers `find . -name "*.h"`
de juiste header file te vinden anders...
The problem is in the part of your brain that handles intelligence.
  • huijaa
Opgelost door her-plukken en her-uitpakken kernel
