Kernel 2.4.10: Geen internetsharing?!?
  • 127 views sinds 30-01-2008
  • huijaa
  • Laatst online: 20-05-2024
Na het compilatie van Kernel 2.4.10 (Kernel 2.4.9 werkt heel goed) is er geen internetsharing meer bij andere computers met windows. Misschien iets aan iptables of forwarding? Hieronder de lijst voor compilatie:-
Voorbaat dank! :? :? :?
# Automatically generated make config: don't edit
CONFIG_X86=y
CONFIG_ISA=y
# CONFIG_SBUS is not set
CONFIG_UID16=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
# Processor type and features
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
CONFIG_M686=y
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
# CONFIG_RWSEM_GENERIC_SPINLOCK is not set
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_X86_TSC=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_PGE=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
# CONFIG_TOSHIBA is not set
# CONFIG_MICROCODE is not set
# CONFIG_X86_MSR is not set
CONFIG_X86_CPUID=y
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM4G is not set
# CONFIG_HIGHMEM64G is not set
# CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
CONFIG_SMP=y
CONFIG_HAVE_DEC_LOCK=y
# General setup
CONFIG_NET=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_NAMES=y
# CONFIG_EISA is not set
# CONFIG_MCA is not set
CONFIG_HOTPLUG=y
# PCMCIA/CardBus support
# CONFIG_PCMCIA is not set
# CONFIG_SYSVIPC is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_SYSCTL is not set
CONFIG_KCORE_ELF=y
# CONFIG_KCORE_AOUT is not set
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_MISC=y
CONFIG_PM=y
CONFIG_ACPI=y
CONFIG_ACPI_DEBUG=y
CONFIG_ACPI_BUSMGR=y
CONFIG_ACPI_SYS=y
CONFIG_ACPI_CPU=y
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_AC=y
# CONFIG_ACPI_EC is not set
CONFIG_APM=y
CONFIG_APM_IGNORE_USER_SUSPEND=y
CONFIG_APM_DO_ENABLE=y
CONFIG_APM_CPU_IDLE=y
CONFIG_APM_DISPLAY_BLANK=y
CONFIG_APM_RTC_IS_GMT=y
CONFIG_APM_ALLOW_INTS=y
CONFIG_APM_REAL_MODE_POWER_OFF=y
# Memory Technology Devices (MTD)
# CONFIG_MTD is not set
# Parallel port support
CONFIG_PARPORT=y
CONFIG_PARPORT_PC=y
CONFIG_PARPORT_PC_CML1=y
CONFIG_PARPORT_SERIAL=y
# CONFIG_PARPORT_PC_FIFO is not set
# CONFIG_PARPORT_PC_SUPERIO is not set
# CONFIG_PARPORT_AMIGA is not set
# CONFIG_PARPORT_MFC3 is not set
# CONFIG_PARPORT_ATARI is not set
# CONFIG_PARPORT_SUNBPP is not set
# CONFIG_PARPORT_OTHER is not set
# CONFIG_PARPORT_1284 is not set
# Plug and Play configuration
CONFIG_PNP=y
CONFIG_ISAPNP=y
# CONFIG_PNPBIOS is not set
# Block devices
CONFIG_BLK_DEV_FD=y
# CONFIG_BLK_DEV_XD is not set
# CONFIG_PARIDE is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_NETLINK=y
CONFIG_RTNETLINK=y
CONFIG_NETLINK_DEV=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG=y
CONFIG_FILTER=y
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_RTNETLINK=y
CONFIG_NETLINK=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_FWMARK=y
CONFIG_IP_ROUTE_NAT=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_TOS=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_LARGE_TABLES=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
# CONFIG_IP_PNP_BOOTP is not set
# CONFIG_IP_PNP_RARP is not set
CONFIG_NET_IPIP=y
CONFIG_NET_IPGRE=y
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
# CONFIG_IP_PIMSM_V1 is not set
# CONFIG_IP_PIMSM_V2 is not set
# CONFIG_ARPD is not set
CONFIG_INET_ECN=y
CONFIG_SYN_COOKIES=y
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=y
CONFIG_IP_NF_FTP=y
CONFIG_IP_NF_QUEUE=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_LIMIT=y
CONFIG_IP_NF_MATCH_MAC=y
CONFIG_IP_NF_MATCH_MARK=y
CONFIG_IP_NF_MATCH_MULTIPORT=y
CONFIG_IP_NF_MATCH_TOS=y
CONFIG_IP_NF_MATCH_TCPMSS=y
CONFIG_IP_NF_MATCH_STATE=y
CONFIG_IP_NF_MATCH_UNCLEAN=y
CONFIG_IP_NF_MATCH_OWNER=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_TARGET_MIRROR=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_IP_NF_NAT_FTP=y
CONFIG_IP_NF_MANGLE=y
CONFIG_IP_NF_TARGET_TOS=y
CONFIG_IP_NF_TARGET_MARK=y
CONFIG_IP_NF_TARGET_LOG=y
CONFIG_IP_NF_TARGET_TCPMSS=y
# CONFIG_IPV6 is not set
# CONFIG_KHTTPD is not set
# CONFIG_ATM is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_DECNET is not set
# CONFIG_BRIDGE is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_LLC is not set
# CONFIG_NET_DIVERT is not set
# CONFIG_ECONET is not set
CONFIG_WAN_ROUTER=y
CONFIG_NET_FASTROUTE=y
CONFIG_NET_HW_FLOWCONTROL=y
# QoS and/or fair queueing
# CONFIG_NET_SCHED is not set
# Telephony Support
CONFIG_PHONE=m
# CONFIG_PHONE_IXJ is not set
# ATA/IDE/MFM/RLL support
CONFIG_IDE=y
# IDE, ATA and ATAPI Block devices
CONFIG_BLK_DEV_IDE=y
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_HD_IDE is not set
# CONFIG_BLK_DEV_HD is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
# CONFIG_BLK_DEV_IDEDISK_VENDOR is not set
# CONFIG_BLK_DEV_COMMERIAL is not set
CONFIG_BLK_DEV_IDECD=m
CONFIG_BLK_DEV_IDETAPE=m
CONFIG_BLK_DEV_IDEFLOPPY=m
# IDE chipset support/bugfixes
CONFIG_BLK_DEV_CMD640=y
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
# CONFIG_BLK_DEV_ISAPNP is not set
CONFIG_BLK_DEV_RZ1000=y
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_BLK_DEV_IDEDMA_PCI=y
CONFIG_BLK_DEV_ADMA=y
# CONFIG_BLK_DEV_OFFBOARD is not set
# CONFIG_IDEDMA_PCI_AUTO is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_PCI_WIP is not set
# CONFIG_BLK_DEV_AEC62XX is not set
# CONFIG_BLK_DEV_ALI15X3 is not set
# CONFIG_BLK_DEV_AMD74XX is not set
# CONFIG_BLK_DEV_CMD64X is not set
# CONFIG_BLK_DEV_CY82C693 is not set
# CONFIG_BLK_DEV_CS5530 is not set
# CONFIG_BLK_DEV_HPT34X is not set
# CONFIG_BLK_DEV_HPT366 is not set
CONFIG_BLK_DEV_PIIX=y
# CONFIG_BLK_DEV_NS87415 is not set
# CONFIG_BLK_DEV_OPTI621 is not set
# CONFIG_BLK_DEV_PDC202XX is not set
# CONFIG_BLK_DEV_SVWKS is not set
# CONFIG_BLK_DEV_SIS5513 is not set
# CONFIG_BLK_DEV_SLC90E66 is not set
# CONFIG_BLK_DEV_TRM290 is not set
# CONFIG_BLK_DEV_VIA82CXXX is not set
CONFIG_IDE_CHIPSETS=y
# Note: most of these also require special kernel boot parameters
# CONFIG_BLK_DEV_4DRIVES is not set
# CONFIG_BLK_DEV_ALI14XX is not set
# CONFIG_BLK_DEV_DTC2278 is not set
# CONFIG_BLK_DEV_HT6560B is not set
# CONFIG_BLK_DEV_PDC4030 is not set
# CONFIG_BLK_DEV_QD65XX is not set
# CONFIG_BLK_DEV_UMC8672 is not set
# CONFIG_IDEDMA_AUTO is not set
# CONFIG_IDEDMA_IVB is not set
# CONFIG_DMA_NONPCI is not set
CONFIG_BLK_DEV_IDE_MODES=y
# CONFIG_BLK_DEV_ATARAID is not set
# SCSI support
# CONFIG_SCSI is not set
# Fusion MPT device support
# CONFIG_FUSION_BOOT is not set
# CONFIG_FUSION_ISENSE is not set
# CONFIG_FUSION_CTL is not set
# CONFIG_FUSION_LAN is not set
# IEEE 1394 (FireWire) support (EXPERIMENTAL)
# CONFIG_IEEE1394 is not set
# I2O device support
CONFIG_I2O=m
CONFIG_I2O_PCI=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_LAN=m
CONFIG_I2O_PROC=m
# Network device support
CONFIG_NETDEVICES=y
# ARCnet devices
# CONFIG_ARCNET is not set
CONFIG_DUMMY=m
CONFIG_BONDING=m
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_ETHERTAP is not set
# CONFIG_NET_SB1000 is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
CONFIG_NET_VENDOR_3COM=y
# CONFIG_EL1 is not set
# CONFIG_EL2 is not set
# CONFIG_ELPLUS is not set
# CONFIG_EL16 is not set
# CONFIG_EL3 is not set
# CONFIG_3C515 is not set
CONFIG_VORTEX=m
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_NET_VENDOR_RACAL is not set
# CONFIG_AT1700 is not set
# CONFIG_DEPCA is not set
# CONFIG_HP100 is not set
# CONFIG_NET_ISA is not set
CONFIG_NET_PCI=y
# CONFIG_PCNET32 is not set
# CONFIG_ADAPTEC_STARFIRE is not set
# CONFIG_AC3200 is not set
# CONFIG_APRICOT is not set
# CONFIG_CS89x0 is not set
# CONFIG_TULIP is not set
# CONFIG_DE4X5 is not set
# CONFIG_DGRS is not set
# CONFIG_DM9102 is not set
CONFIG_EEPRO100=m
# CONFIG_FEALNX is not set
# CONFIG_NATSEMI is not set
# CONFIG_NE2K_PCI is not set
# CONFIG_8139TOO is not set
# CONFIG_SIS900 is not set
# CONFIG_EPIC100 is not set
# CONFIG_SUNDANCE is not set
# CONFIG_TLAN is not set
# CONFIG_VIA_RHINE is not set
# CONFIG_WINBOND_840 is not set
# CONFIG_LAN_SAA9730 is not set
# CONFIG_NET_POCKET is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_SK98LIN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
# CONFIG_PLIP is not set
CONFIG_PPP=m
# CONFIG_PPP_MULTILINK is not set
# CONFIG_PPP_FILTER is not set
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPPOE=m
# CONFIG_SLIP is not set
# Wireless LAN (non-hamradio)
# CONFIG_NET_RADIO is not set
# Token Ring devices
# CONFIG_TR is not set
# CONFIG_NET_FC is not set
# CONFIG_RCPCI is not set
# CONFIG_SHAPER is not set
# Wan interfaces
# CONFIG_WAN is not set
# Amateur Radio support
# CONFIG_HAMRADIO is not set
# IrDA (infrared) support
# CONFIG_IRDA is not set
# ISDN subsystem
# CONFIG_ISDN is not set
# Old CD-ROM drivers (not SCSI, not IDE)
# CONFIG_CD_NO_IDESCSI is not set
# Input core support
CONFIG_INPUT=m
CONFIG_INPUT_KEYBDEV=m
CONFIG_INPUT_MOUSEDEV=m
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_SERIAL=y
# CONFIG_SERIAL_CONSOLE is not set
# CONFIG_SERIAL_EXTENDED is not set
# CONFIG_SERIAL_NONSTANDARD is not set
CONFIG_UNIX98_PTYS=y
CONFIG_UNIX98_PTY_COUNT=256
CONFIG_PRINTER=m
# CONFIG_LP_CONSOLE is not set
# CONFIG_PPDEV is not set
# I2C support
CONFIG_I2C=m
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_PHILIPSPAR=m
CONFIG_I2C_ELV=m
CONFIG_I2C_VELLEMAN=m
CONFIG_I2C_ALGOPCF=m
CONFIG_I2C_ELEKTOR=m
CONFIG_I2C_CHARDEV=m
# Mice
CONFIG_BUSMOUSE=y
# CONFIG_ATIXL_BUSMOUSE is not set
CONFIG_LOGIBUSMOUSE=y
CONFIG_MS_BUSMOUSE=y
CONFIG_MOUSE=y
CONFIG_PSMOUSE=y
# CONFIG_82C710_MOUSE is not set
# CONFIG_PC110_PAD is not set
# Joysticks
# CONFIG_INPUT_GAMEPORT is not set
# CONFIG_INPUT_SERIO is not set
# Joysticks
# CONFIG_INPUT_IFORCE_USB is not set
# CONFIG_INPUT_DB9 is not set
# CONFIG_INPUT_GAMECON is not set
# CONFIG_INPUT_TURBOGRAFX is not set
# CONFIG_QIC02_TAPE is not set
# Watchdog Cards
# CONFIG_WATCHDOG is not set
# CONFIG_INTEL_RNG is not set
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
# CONFIG_DTLK is not set
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_SONYPI is not set
# Ftape, the floppy tape device driver
# CONFIG_FTAPE is not set
CONFIG_AGP=y
CONFIG_AGP_INTEL=y
# CONFIG_AGP_I810 is not set
# CONFIG_AGP_VIA is not set
# CONFIG_AGP_AMD is not set
CONFIG_AGP_SIS=y
CONFIG_AGP_ALI=y
# CONFIG_AGP_SWORKS is not set
CONFIG_DRM=y
CONFIG_DRM_TDFX=m
CONFIG_DRM_GAMMA=m
CONFIG_DRM_R128=m
CONFIG_DRM_RADEON=m
CONFIG_DRM_I810=m
CONFIG_DRM_MGA=m
# Multimedia devices
CONFIG_VIDEO_DEV=m
# Video For Linux
CONFIG_VIDEO_PROC_FS=y
CONFIG_I2C_PARPORT=m
# Video Adapters
# CONFIG_VIDEO_BT848 is not set
# CONFIG_VIDEO_PMS is not set
# CONFIG_VIDEO_BWQCAM is not set
# CONFIG_VIDEO_CQCAM is not set
# CONFIG_VIDEO_CPIA is not set
CONFIG_VIDEO_SAA5249=m
CONFIG_TUNER_3036=m
# CONFIG_VIDEO_STRADIS is not set
# CONFIG_VIDEO_ZORAN is not set
# CONFIG_VIDEO_ZR36120 is not set
# Radio Adapters
# CONFIG_RADIO_CADET is not set
# CONFIG_RADIO_RTRACK is not set
# CONFIG_RADIO_RTRACK2 is not set
# CONFIG_RADIO_AZTECH is not set
# CONFIG_RADIO_GEMTEK is not set
# CONFIG_RADIO_GEMTEK_PCI is not set
# CONFIG_RADIO_MAXIRADIO is not set
# CONFIG_RADIO_MAESTRO is not set
# CONFIG_RADIO_SF16FMI is not set
# CONFIG_RADIO_TERRATEC is not set
# CONFIG_RADIO_TRUST is not set
# CONFIG_RADIO_TYPHOON is not set
CONFIG_RADIO_ZOLTRIX=m
# File systems
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=y
CONFIG_REISERFS_FS=y
# CONFIG_REISERFS_CHECK is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_BFS_FS is not set
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_UMSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_EFS_FS=m
# CONFIG_CRAMFS is not set
CONFIG_TMPFS=y
# CONFIG_RAMFS is not set
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
CONFIG_MINIX_FS=m
# CONFIG_VXFS_FS is not set
CONFIG_NTFS_FS=m
# CONFIG_NTFS_RW is not set
# CONFIG_HPFS_FS is not set
CONFIG_PROC_FS=y
# CONFIG_DEVFS_FS is not set
CONFIG_DEVPTS_FS=y
# CONFIG_QNX4FS_FS is not set
CONFIG_ROMFS_FS=m
CONFIG_EXT2_FS=y
# CONFIG_SYSV_FS is not set
CONFIG_UDF_FS=y
# CONFIG_UDF_RW is not set
CONFIG_UFS_FS=y
# CONFIG_UFS_FS_WRITE is not set
# Network File Systems
# CONFIG_CODA_FS is not set
CONFIG_NFS_FS=y
# CONFIG_NFS_V3 is not set
# CONFIG_ROOT_NFS is not set
CONFIG_NFSD=y
# CONFIG_NFSD_V3 is not set
CONFIG_SUNRPC=y
CONFIG_LOCKD=y
CONFIG_SMB_FS=y
# CONFIG_SMB_NLS_DEFAULT is not set
# CONFIG_NCP_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_SMB_NLS=y
CONFIG_NLS=y
# Native Language Support
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=y
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Console drivers
CONFIG_VGA_CONSOLE=y
CONFIG_VIDEO_SELECT=y
# CONFIG_MDA_CONSOLE is not set
# Frame-buffer support
CONFIG_FB=y
CONFIG_DUMMY_CONSOLE=y
# CONFIG_FB_RIVA is not set
# CONFIG_FB_CLGEN is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_CYBER2000 is not set
CONFIG_FB_VESA=y
CONFIG_FB_VGA16=y
# CONFIG_FB_HGA is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
CONFIG_FB_SIS=y
# CONFIG_FB_SIS_300 is not set
# CONFIG_FB_SIS_315 is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_VIRTUAL is not set
CONFIG_FBCON_ADVANCED=y
# CONFIG_FBCON_MFB is not set
# CONFIG_FBCON_CFB2 is not set
# CONFIG_FBCON_CFB4 is not set
CONFIG_FBCON_CFB8=y
CONFIG_FBCON_CFB16=y
CONFIG_FBCON_CFB24=y
CONFIG_FBCON_CFB32=y
# CONFIG_FBCON_AFB is not set
# CONFIG_FBCON_ILBM is not set
# CONFIG_FBCON_IPLAN2P2 is not set
# CONFIG_FBCON_IPLAN2P4 is not set
# CONFIG_FBCON_IPLAN2P8 is not set
# CONFIG_FBCON_MAC is not set
CONFIG_FBCON_VGA_PLANES=y
CONFIG_FBCON_VGA=y
# CONFIG_FBCON_HGA is not set
# CONFIG_FBCON_FONTWIDTH8_ONLY is not set
# CONFIG_FBCON_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# Sound
CONFIG_SOUND=y
CONFIG_SOUND_BT878=m
CONFIG_SOUND_CMPCI=m
# CONFIG_SOUND_CMPCI_FM is not set
CONFIG_SOUND_CMPCI_MIDI=y
CONFIG_SOUND_CMPCI_MPUIO=330
CONFIG_SOUND_CMPCI_JOYSTICK=y
# CONFIG_SOUND_CMPCI_CM8738 is not set
# CONFIG_SOUND_EMU10K1 is not set
# CONFIG_SOUND_FUSION is not set
# CONFIG_SOUND_CS4281 is not set
# CONFIG_SOUND_ES1370 is not set
# CONFIG_SOUND_ES1371 is not set
# CONFIG_SOUND_ESSSOLO1 is not set
# CONFIG_SOUND_MAESTRO is not set
# CONFIG_SOUND_MAESTRO3 is not set
# CONFIG_SOUND_ICH is not set
# CONFIG_SOUND_RME96XX is not set
# CONFIG_SOUND_SONICVIBES is not set
# CONFIG_SOUND_TRIDENT is not set
CONFIG_SOUND_MSNDCLAS=m
# CONFIG_MSNDCLAS_HAVE_BOOT is not set
CONFIG_MSNDCLAS_INIT_FILE="/etc/sound/msndinit.bin"
CONFIG_MSNDCLAS_PERM_FILE="/etc/sound/msndperm.bin"
CONFIG_SOUND_MSNDPIN=m
# CONFIG_MSNDPIN_HAVE_BOOT is not set
CONFIG_MSNDPIN_INIT_FILE="/etc/sound/pndspini.bin"
CONFIG_MSNDPIN_PERM_FILE="/etc/sound/pndsperm.bin"
# CONFIG_SOUND_VIA82CXXX is not set
CONFIG_SOUND_OSS=m
# CONFIG_SOUND_TRACEINIT is not set
# CONFIG_SOUND_DMAP is not set
# CONFIG_SOUND_AD1816 is not set
# CONFIG_SOUND_SGALAXY is not set
# CONFIG_SOUND_ADLIB is not set
# CONFIG_SOUND_ACI_MIXER is not set
# CONFIG_SOUND_CS4232 is not set
# CONFIG_SOUND_SSCAPE is not set
# CONFIG_SOUND_GUS is not set
CONFIG_SOUND_VMIDI=m
# CONFIG_SOUND_TRIX is not set
CONFIG_SOUND_MSS=m
CONFIG_SOUND_MPU401=m
# CONFIG_SOUND_NM256 is not set
# CONFIG_SOUND_MAD16 is not set
# CONFIG_SOUND_PAS is not set
# CONFIG_SOUND_PSS is not set
CONFIG_SOUND_SB=m
# CONFIG_SOUND_AWE32_SYNTH is not set
# CONFIG_SOUND_WAVEFRONT is not set
# CONFIG_SOUND_MAUI is not set
# CONFIG_SOUND_YM3812 is not set
# CONFIG_SOUND_OPL3SA1 is not set
# CONFIG_SOUND_OPL3SA2 is not set
# CONFIG_SOUND_YMFPCI is not set
# CONFIG_SOUND_UART6850 is not set
# CONFIG_SOUND_AEDSP16 is not set
# CONFIG_SOUND_TVMIXER is not set
# USB support
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
# CONFIG_USB_DEVICEFS is not set
# CONFIG_USB_BANDWIDTH is not set
# USB Controllers
# CONFIG_USB_UHCI is not set
# CONFIG_USB_UHCI_ALT is not set
# CONFIG_USB_OHCI is not set
# USB Device Class drivers
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_BLUETOOTH is not set
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_HP8200e is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
CONFIG_USB_ACM=y
CONFIG_USB_PRINTER=y
# USB Human Interface Devices (HID)
# CONFIG_USB_HID is not set
# CONFIG_USB_KBD is not set
# CONFIG_USB_MOUSE is not set
# CONFIG_USB_WACOM is not set
# USB Imaging devices
# CONFIG_USB_DC2XX is not set
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_SCANNER is not set
# USB Multimedia devices
# CONFIG_USB_IBMCAM is not set
# CONFIG_USB_OV511 is not set
# CONFIG_USB_PWC is not set
# CONFIG_USB_SE401 is not set
# CONFIG_USB_DSBR is not set
# CONFIG_USB_DABUSB is not set
# USB Network adaptors
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_CATC is not set
# CONFIG_USB_CDCETHER is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_USBNET is not set
# USB port drivers
# CONFIG_USB_USS720 is not set
# USB Serial Converter support
# CONFIG_USB_SERIAL is not set
# USB misc drivers
# CONFIG_USB_RIO500 is not set
# Bluetooth support
# CONFIG_BLUEZ is not set
# Kernel hacking
# CONFIG_DEBUG_KERNEL is not set
since 21aug'04: Asus K8VSE Deluxe, AMD Athlon 64 3400+, Twimos 1 GB PC3200, Maxtor U133/7200 160GB+120GB, Asus V9999GE and SunBeam Aryclic Case
Aan je kernel config ligt het niet.
Volgens mij weet je niet helemaal wat je allemaal aan moet zetten in de kernel wel :? (Lees de help eens bij het maken van een kernel. Daarin staat veel nuttige info.)
Tenminste ik zie een zooitje dingen aanstaan waarvan ik me afvraag of je ze ooit gebruikt. Verder is het handiger als je in het vervolg alleen de relevante dingen post. ;)
Maar goed, zo kan eigenlijk niemand je verder helpen.
Wat geeft iptables -L ?
Wat geeft iptables -L -t nat ?
Wat voor foutmeldingen geeft je firewall/internet-share script?
wat geeft "cat /proc/sys/net/ipv4/ip_forward"?
  • huijaa
Ook nog erger is de volgende fout onstaan na het compilatie van kernel 2.4.10 (Bij vorig versie werkt het uitstekend)
Shutting down httpd.....failed
Starting httpd [ LDAP PERL PHP4 Python ]
Ouch! ap_mm_create(1048576, "/var/state/httpd/mm.2496") failed
Error: MM: mm:core: failed to acquire shared memory segment (Function not implemented): OS: No such file or directory unused
  • huijaa
Hier volgt het antwoord op de volgende vragen:-
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT all -- anywhere anywhere
DROP all -- 10.0.0.0/24 anywhere
ACCEPT all -- 10.0.0.138 dellinux.huijaa.nu
DROP all -- 192.168.0.0/24 anywhere
ACCEPT all -- 192.168.0.0/24 anywhere
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpts:1024:65535 flags:!SYN,RST,ACK/SYN
ACCEPT udp -- anywhere huijaa.xs4all.nl udp dpts:1024:65535
DROP tcp -- anywhere anywhere tcp dpt:nfs flags:SYN,RST,ACK/SYN
DROP udp -- anywhere anywhere udp dpt:nfs
DROP tcp -- anywhere anywhere tcp dpt:callbook flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpts:6000:6063 flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:socks flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:http-alt flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:6776 flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:12345 flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:20034 flags:SYN,RST,ACK/SYN
DROP tcp -- anywhere anywhere tcp dpt:31337 flags:SYN,RST,ACK/SYN
ACCEPT icmp -- anywhere huijaa.xs4all.nl icmp echo-reply
ACCEPT icmp -- anywhere huijaa.xs4all.nl icmp destination-unreachable
ACCEPT icmp -- anywhere huijaa.xs4all.nl icmp time-exceeded
DROP icmp -- anywhere huijaa.xs4all.nl icmp redirect
DROP udp -- anywhere anywhere udp spts:filenet-rpc:65535 dpts:traceroute:33523
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp spts:login:65535 dpt:ssh
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp spts:1024:65535 dpt:ftp
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp spts:1024:65535 dpts:1024:65535
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpt:http
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpt:telnet
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpt:pop3
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpt:smtp
ACCEPT tcp -- anywhere huijaa.xs4all.nl tcp dpt:domain
ACCEPT udp -- anywhere huijaa.xs4all.nl udp dpt:domain
ACCEPT tcp -- fistix.xs4all.nl huijaa.xs4all.nl tcp spt:ntp dpt:ntp
ACCEPT udp -- fistix.xs4all.nl huijaa.xs4all.nl udp spt:ntp dpt:ntp
DROP all -- anywhere anywhere
Chain FORWARD (policy DROP)
ACCEPT all -- anywhere 192.168.0.0/24
ACCEPT tcp -- anywhere anywhere tcp flags:SYN,RST,ACK/SYN limit: avg 1/sec burst 5
ACCEPT tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
ACCEPT icmp -- anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
Chain OUTPUT (policy DROP)
ACCEPT all -- dellinux.huijaa.nu 10.0.0.138
DROP all -f anywhere anywhere
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spts:1024:65535
ACCEPT udp -- huijaa.xs4all.nl anywhere udp spts:1024:65535
ACCEPT icmp -- huijaa.xs4all.nl anywhere icmp echo-request
ACCEPT udp -- huijaa.xs4all.nl anywhere udp spts:filenet-rpc:65535 dpts:traceroute:33523
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:ssh dpts:login:65535 flags:!SYN,RST,ACK/SYN
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:ftp dpts:1024:65535 flags:!SYN,RST,ACK/SYN
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spts:1024:65535 dpts:1024:65535 flags:!SYN,RST,ACK/SYN
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:http flags:!SYN,RST,ACK/SYN
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:telnet flags:!SYN,RST,ACK/SYN
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:pop3
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:smtp
ACCEPT tcp -- huijaa.xs4all.nl anywhere tcp spt:domain
ACCEPT udp -- huijaa.xs4all.nl anywhere udp spt:domain
ACCEPT tcp -- huijaa.xs4all.nl fistix.xs4all.nl tcp spt:ntp dpt:ntp
ACCEPT udp -- huijaa.xs4all.nl fistix.xs4all.nl udp spt:ntp dpt:ntp
DROP all -- anywhere anywhere ---
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- anywhere 10.0.0.138
MASQUERADE all -- 192.168.0.0/24 anywhere
MASQUERADE all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
target prot opt source destination ---
/sbin/OwnFirewall: /proc/sys/net/ipv4/ip_forward: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/tcp_syncookies: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/conf/*/rp_filter: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts: No such file or directory/sbin/OwnFirewall: /proc/sys/net/ipv4/icmp_ignore_bogus_error_responses: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/conf/*/accept_redirects: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/conf/*/send_redirects: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/conf/*/accept_source_route: No such file or directory
/sbin/OwnFirewall: /proc/sys/net/ipv4/conf/*/log_martians: No such file or directory
en na 'echo 1 > /proc/sys/net/ipv4/ip_forward'
geeft hetzelfde foutmelding hierboven
Proc Filesystem support staat in ieder geval aan.
Staat /proc ook in het lijstje als je het commando "mount"in tikt?
  • Zwelgje
  • Laatst online: 17-08 09:02
hoe heb je de kernel verder geinstalleerd? kreeg je nog foutmeldingen tijdens het compilen?
is het je uberhaubt wel eens gelukt om een kernel goed te compilen? (een niet geheel onbelangrijk element in deze zaak)
  • huijaa
Nee, ik zie geen enkel compile-fout, maar soms wel waarschuwingen...ik ga nog maals hercompileren. Misschien heb ik de library verkeerd gelinkt (ln -s ..)
  • Zwelgje
mmm ik kon mijn 2.4.10 kernel anders gewoon installeren zonder dat ik 'met de hand' librarie's moet gaan linken :?
Op maandag 01 oktober 2001 22:29 schreef huijaa het volgende:
Doe even hetvolgende van te voren dan.
mv /lib/modules/2.4.10 /lib/modules/2.4.10-old
Vergeet ook niet de "make clean" of "make mrproper"
  • huijaa
Het helpt geen moer...ik zou dat kernel wel 'waardeloos' kunnen noemen...ik geef het op! :( :(
  • tweakerbee
  • Laatst online: 04-09 08:53
tweakerbee
dus..?
Terug naar 2.4.9 en kijken of het daarin wel werkt. :P
You can't have everything. Where would you put it?
  • wouzer
Heb je de ".config" uit de 2.4.9 tree gewoon naar de 2.4.10 gezet. Of de 2.4.9 gewoon gepatched met 2.4.10?
  • Zwelgje
De kernel is zeker niet waardeloos, mischien moet de gebruiker wat meer lees/researchwerk doen voordat ie met een kernel upgrade begint? (no offense)
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
[quote]
[quote]
[\quote]
Geen IPC support.. Da's een recompile dus :)
Geen SYSCTL, da's ook al niet goed.
  • igmar
igmar
ISO20022
Lezen wat de opties zijn is wel handig. IPC support eruit halen zijn geen dingen die aan te raden zijn.
  • huijaa
Op dinsdag 02 oktober 2001 08:13 schreef wouzer het volgende:
Ja gewoon overgenomen... ;(
make oldconfig
