[SuSe 7.2] Aureal SQ2500 [vortex 2] onder Linux?
  • 683 views sinds 30-01-2008
  • StarLite
  • Laatst online: 15-11 22:07
StarLite
'ON ERROR RESUME NEXT
Ik heb SuSe 7.2 en een Aureal SQ2500 geluidskaart met Vortex 2 chipset.
Yast2 ZIET hem wel, hij geeft ook de juiste kaart aan, maar hij wil em maar niet installeren: "The kernel module off for sound support could not be loaded"
Wat betekend deze foutmelding?
Hoe kan ik geluid uit me kaartje krijgen?
tyrips, tywreps, tiewreps, tiereps, tie raps, ripties, taiwraps, kabelbindbandjes » Tie Wraps
\o/
  • StarLite
StarLite
Erm..
ik krijg een paar foutmeldingkjes:
elwin@spc:~ > cd /drivers/aureal
elwin@spc:/drivers/aureal > su
Password:
root@spc:/drivers/aureal > make install
cc -D__KERNEL__ -DMODULE -DAU8830 -mpentiumpro -O6 -fomit-frame-pointer -Wall
-pipe -I/usr/src/linux/include -c -o au_audio.o au_audio.c
In file included from au_vortex.h:44,
from au_audio.c:49:
/usr/include/linux/version.h:2: #error "========================================
/usr/include/linux/version.h:3: #error "You should not include /usr/include/{lin
ux,asm}/ header"
/usr/include/linux/version.h:4: #error "files directly for the compilation of ke
rnel modules."
/usr/include/linux/version.h:5: #error ""
/usr/include/linux/version.h:6: #error "glibc now uses kernel header files from
a well-defined"
/usr/include/linux/version.h:7: #error "working kernel version (as recommended b
y Linus Torvalds)"
/usr/include/linux/version.h:8: #error "These files are glibc internal and may n
ot match the"
/usr/include/linux/version.h:9: #error "currently running kernel. They should on
ly be"
/usr/include/linux/version.h:10: #error "included via other system header files
- user space"
/usr/include/linux/version.h:11: #error "programs should not directly include <l
inux/*.h> or"
/usr/include/linux/version.h:12: #error "<asm/*.h> as well."
/usr/include/linux/version.h:13: #error ""
/usr/include/linux/version.h:14: #error "To build kernel modules please do the f
ollowing:"
/usr/include/linux/version.h:15: #error ""
/usr/include/linux/version.h:16: #error " o Have the kernel sources installed"
/usr/include/linux/version.h:17: #error ""
/usr/include/linux/version.h:18: #error " o Make sure that the symbolic link"
/usr/include/linux/version.h:19: #error " /lib/modules/`uname -r`/build exists
and points to"
/usr/include/linux/version.h:20: #error " the matching kernel source directory
/usr/include/linux/version.h:21: #error ""
/usr/include/linux/version.h:22: #error " o Now copy /boot/vmlinuz.version.h to"
/usr/include/linux/version.h:23: #error " /lib/modules/`uname -r`/build/includ
e/linux/version.h"
/usr/include/linux/version.h:24: #error ""
/usr/include/linux/version.h:25: #error " o When compiling, make sure to use the
following"
/usr/include/linux/version.h:26: #error " compiler option to use the correct i
nclude files:"
/usr/include/linux/version.h:27: #error ""
/usr/include/linux/version.h:28: #error " -I/lib/modules/`uname -r`/build/incl
ude"
/usr/include/linux/version.h:29: #error ""
/usr/include/linux/version.h:30: #error " instead of"
/usr/include/linux/version.h:31: #error ""
/usr/include/linux/version.h:32: #error " -I/usr/include/linux"
/usr/include/linux/version.h:33: #error ""
/usr/include/linux/version.h:34: #error " Please adjust the Makefile according
ly."
/usr/include/linux/version.h:35: #error "=======================================
In file included from au_audio.c:49:
au_vortex.h:46: parse error
au_vortex.h:50: linux/autoconf.h: No such file or directory
In file included from /usr/include/linux/module.h:260,
from au_vortex.h:58,
from au_audio.c:49:
ux,asm}/ header"
rnel modules."
a well-defined"
y Linus Torvalds)"
ot match the"
ly be"
- user space"
inux/*.h> or"
ollowing:"
and points to"
e/linux/version.h"
following"
nclude files:"
ude"
ly."
In file included from au_vortex.h:59,
from au_audio.c:49:
ux,asm}/ header"
rnel modules."
a well-defined"
y Linus Torvalds)"
ot match the"
ly be"
- user space"
inux/*.h> or"
ollowing:"
and points to"
e/linux/version.h"
following"
nclude files:"
ude"
ly."
au_vortex.h:74: parse error
In file included from au_vortex.h:77,
from au_audio.c:49:
/usr/include/asm/spinlock.h:36: warning: `SPIN_LOCK_UNLOCKED' redefined
/usr/include/linux/spinlock.h:48: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:38: warning: `spin_lock_init' redefined
/usr/include/linux/spinlock.h:51: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:47: warning: `spin_is_locked' redefined
/usr/include/linux/spinlock.h:53: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:48: warning: `spin_unlock_wait' redefined
/usr/include/linux/spinlock.h:55: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:131: warning: `RW_LOCK_UNLOCKED' redefined
/usr/include/linux/spinlock.h:111: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:133: warning: `rwlock_init' redefined
/usr/include/linux/spinlock.h:114: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:164: warning: `read_unlock' redefined
/usr/include/linux/spinlock.h:116: warning: this is the location of the previous
definition
/usr/include/asm/spinlock.h:165: warning: `write_unlock' redefined
/usr/include/linux/spinlock.h:118: warning: this is the location of the previous
definition
au_vortex.h:80: parse error
au_vortex.h:118: parse error
au_vortex.h:146: parse error
au_vortex.h:197: parse error
In file included from au_audio.c:50:
ux,asm}/ header"
rnel modules."
a well-defined"
y Linus Torvalds)"
ot match the"
ly be"
- user space"
inux/*.h> or"
ollowing:"
and points to"
e/linux/version.h"
following"
nclude files:"
ude"
ly."
au_audio.c:63: parse error
au_audio.c:606: parse error
au_audio.c:666: parse error
au_audio.c:690: parse error
au_audio.c:767: parse error
au_audio.c:825: parse error
au_audio.c:838: parse error
au_audio.c:859: parse error
au_audio.c:867: parse error
au_audio.c:879: parse error
In file included from au_vortex.h:58,
from au_audio.c:49:
/usr/include/linux/module.h:262: parse error before `UTS_RELEASE'
In file included from /usr/include/linux/dcache.h:7,
from /usr/include/linux/fs.h:18,
from /usr/include/linux/capability.h:17,
from /usr/include/linux/binfmts.h:5,
from /usr/include/linux/sched.h:8,
from au_vortex.h:63,
from au_audio.c:49:
/usr/include/linux/mount.h: In function `mntput':
/usr/include/linux/mount.h:46: warning: implicit declaration of function `BUG'
In file included from au_vortex.h:63,
from au_audio.c:49:
/usr/include/linux/sched.h: At top level:
/usr/include/linux/sched.h:195: parse error before `pgd_t'
/usr/include/linux/sched.h:195: warning: no semicolon at end of struct or union
/usr/include/linux/sched.h:217: parse error before `}'
/usr/include/linux/sched.h: In function `mmdrop':
/usr/include/linux/sched.h:710: dereferencing pointer to incomplete type
In file included from /usr/include/asm/pgtable.h:17,
from /usr/include/linux/mm.h:23,
from /usr/include/linux/slab.h:14,
from /usr/include/linux/malloc.h:4,
from au_vortex.h:66,
from au_audio.c:49:
/usr/include/asm/fixmap.h: At top level:
/usr/include/asm/fixmap.h:72: parse error before `pgprot_t'
In file included from /usr/include/linux/mm.h:23,
from au_audio.c:49:
/usr/include/asm/pgtable.h:24: parse error before `swapper_pg_dir'
/usr/include/asm/pgtable.h:24: warning: data definition has no type or storage c
lass
In file included from /usr/include/asm/pgtable.h:109,
from au_audio.c:49:
/usr/include/asm/pgtable-2level.h:32: parse error before `pgd'
/usr/include/asm/pgtable-2level.h:33: parse error before `pgd'
/usr/include/asm/pgtable-2level.h:34: parse error before `pgd'
/usr/include/asm/pgtable-2level.h:53: parse error before `*'
/usr/include/asm/pgtable-2level.h: In function `pmd_offset':
/usr/include/asm/pgtable-2level.h:55: `pmd_t' undeclared (first use in this func
tion)
/usr/include/asm/pgtable-2level.h:55: (Each undeclared identifier is reported on
ly once
/usr/include/asm/pgtable-2level.h:55: for each function it appears in.)
/usr/include/asm/pgtable-2level.h:55: parse error before `)'
/usr/include/asm/pgtable-2level.h:56: warning: control reaches end of non-void f
unction
from au_audio.c:49:
/usr/include/asm/pgtable.h: At top level:
/usr/include/asm/pgtable.h:265: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_read':
/usr/include/asm/pgtable.h:265: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:265: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:266: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_exec':
/usr/include/asm/pgtable.h:266: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:266: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:267: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_dirty':
/usr/include/asm/pgtable.h:267: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:267: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:268: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_young':
/usr/include/asm/pgtable.h:268: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:268: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:269: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_write':
/usr/include/asm/pgtable.h:269: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:269: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:271: parse error before `pte_rdprotect'
/usr/include/asm/pgtable.h:271: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_rdprotect':
/usr/include/asm/pgtable.h:271: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:271: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:272: parse error before `pte_exprotect'
/usr/include/asm/pgtable.h:272: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_exprotect':
/usr/include/asm/pgtable.h:272: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:272: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:273: parse error before `pte_mkclean'
/usr/include/asm/pgtable.h:273: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkclean':
/usr/include/asm/pgtable.h:273: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:273: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:274: parse error before `pte_mkold'
/usr/include/asm/pgtable.h:274: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkold':
/usr/include/asm/pgtable.h:274: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:274: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:275: parse error before `pte_wrprotect'
/usr/include/asm/pgtable.h:275: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_wrprotect':
/usr/include/asm/pgtable.h:275: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:275: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:276: parse error before `pte_mkread'
/usr/include/asm/pgtable.h:276: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkread':
/usr/include/asm/pgtable.h:276: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:276: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:277: parse error before `pte_mkexec'
/usr/include/asm/pgtable.h:277: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkexec':
/usr/include/asm/pgtable.h:277: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:277: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:278: parse error before `pte_mkdirty'
/usr/include/asm/pgtable.h:278: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkdirty':
/usr/include/asm/pgtable.h:278: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:278: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:279: parse error before `pte_mkyoung'
/usr/include/asm/pgtable.h:279: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkyoung':
/usr/include/asm/pgtable.h:279: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:279: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:280: parse error before `pte_mkwrite'
/usr/include/asm/pgtable.h:280: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_mkwrite':
/usr/include/asm/pgtable.h:280: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:280: warning: control reaches end of non-void functio
n
/usr/include/asm/pgtable.h:282: parse error before `*'
/usr/include/asm/pgtable.h: In function `ptep_test_and_clear_dirty':
/usr/include/asm/pgtable.h:282: `ptep' undeclared (first use in this function)
/usr/include/asm/pgtable.h:283: parse error before `*'
/usr/include/asm/pgtable.h: In function `ptep_test_and_clear_young':
/usr/include/asm/pgtable.h:283: `ptep' undeclared (first use in this function)
/usr/include/asm/pgtable.h:284: parse error before `*'
/usr/include/asm/pgtable.h: In function `ptep_set_wrprotect':
/usr/include/asm/pgtable.h:284: `ptep' undeclared (first use in this function)
/usr/include/asm/pgtable.h:285: parse error before `*'
/usr/include/asm/pgtable.h: In function `ptep_mkdirty':
/usr/include/asm/pgtable.h:285: `ptep' undeclared (first use in this function)
/usr/include/asm/pgtable.h:297: parse error before `pte_modify'
/usr/include/asm/pgtable.h:297: parse error before `pte'
/usr/include/asm/pgtable.h: In function `pte_modify':
/usr/include/asm/pgtable.h:299: `pte' undeclared (first use in this function)
/usr/include/asm/pgtable.h:299: `PTE_MASK' undeclared (first use in this functio
n)
/usr/include/asm/pgtable.h:300: warning: implicit declaration of function `pgpro
t_val'
/usr/include/asm/pgtable.h:300: `newprot' undeclared (first use in this function
/usr/include/asm/pgtable.h:302: warning: control reaches end of non-void functio
n
In file included from /usr/include/linux/slab.h:14,
from au_audio.c:49:
/usr/include/linux/mm.h: At top level:
/usr/include/linux/mm.h:49: parse error before `pgprot_t'
/usr/include/linux/mm.h:49: warning: no semicolon at end of struct or union
/usr/include/linux/mm.h:69: parse error before `}'
/usr/include/linux/mm.h:112: parse error before `protection_map'
/usr/include/linux/mm.h:112: warning: data definition has no type or storage cla
ss
/usr/include/linux/mm.h:394: parse error before `pgprot_t'
/usr/include/linux/mm.h:395: parse error before `pgprot_t'
/usr/include/linux/mm.h:398: parse error before `*'
/usr/include/linux/mm.h:398: parse error before `pgd_t'
/usr/include/linux/mm.h:398: warning: data definition has no type or storage cla
ss
/usr/include/linux/mm.h:399: parse error before `*'
/usr/include/linux/mm.h:399: parse error before `pmd_t'
/usr/include/linux/mm.h:399: warning: data definition has no type or storage cla
ss
/usr/include/linux/mm.h:411: parse error before `*'
/usr/include/linux/mm.h:411: parse error before `pgd_t'
/usr/include/linux/mm.h: In function `pmd_alloc':
/usr/include/linux/mm.h:413: `pgd' undeclared (first use in this function)
/usr/include/linux/mm.h:414: `mm' undeclared (first use in this function)
/usr/include/linux/mm.h:414: `address' undeclared (first use in this function)
/usr/include/linux/mm.h: In function `do_mmap':
/usr/include/linux/mm.h:448: warning: implicit declaration of function `PAGE_ALI
GN'
/usr/include/linux/mm.h: In function `expand_stack':
/usr/include/linux/mm.h:505: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:506: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:507: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:509: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:510: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:511: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:512: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:513: dereferencing pointer to incomplete type
/usr/include/linux/mm.h:514: dereferencing pointer to incomplete type
/usr/include/linux/mm.h: In function `find_vma_intersection':
/usr/include/linux/mm.h:530: dereferencing pointer to incomplete type
In file included from /usr/include/asm/io.h:108,
from /usr/include/asm/pci.h:26,
from /usr/include/linux/pci.h:559,
from au_vortex.h:68,
from au_audio.c:49:
/usr/include/linux/vmalloc.h: At top level:
/usr/include/linux/vmalloc.h:23: parse error before `pgprot_t'
/usr/include/linux/vmalloc.h:27: parse error before `pgprot_t'
/usr/include/linux/vmalloc.h: In function `vmalloc':
/usr/include/linux/vmalloc.h:35: `pgprot_t' undeclared (first use in this functi
on)
/usr/include/linux/vmalloc.h:35: parse error before `__ret'
/usr/include/linux/vmalloc.h:35: `__ret' undeclared (first use in this function)
/usr/include/linux/vmalloc.h:35: warning: implicit declaration of function `__pg
prot'
/usr/include/linux/vmalloc.h: In function `vmalloc_dma':
/usr/include/linux/vmalloc.h:44: `pgprot_t' undeclared (first use in this functi
on)
/usr/include/linux/vmalloc.h:44: parse error before `__ret'
/usr/include/linux/vmalloc.h:44: `__ret' undeclared (first use in this function)
/usr/include/linux/vmalloc.h: In function `vmalloc_32':
/usr/include/linux/vmalloc.h:53: `pgprot_t' undeclared (first use in this functi
on)
/usr/include/linux/vmalloc.h:53: parse error before `__ret'
/usr/include/linux/vmalloc.h:53: `__ret' undeclared (first use in this function)
In file included from /usr/include/asm/pci.h:26,
from au_audio.c:49:
/usr/include/asm/io.h: In function `virt_to_phys':
/usr/include/asm/io.h:130: warning: implicit declaration of function `__pa'
/usr/include/asm/io.h: In function `phys_to_virt':
/usr/include/asm/io.h:135: warning: implicit declaration of function `__va'
/usr/include/asm/io.h:135: warning: return makes pointer from integer without a
cast
/usr/include/asm/io.h: In function `isa_check_signature':
/usr/include/asm/io.h:237: `PAGE_OFFSET' undeclared (first use in this function)
from au_audio.c:49:
/usr/include/asm/spinlock.h: At top level:
/usr/include/asm/spinlock.h:26: conflicting types for `spinlock_t'
/usr/include/linux/spinlock.h:47: previous declaration of `spinlock_t'
/usr/include/asm/spinlock.h:68: parse error before `{'
/usr/include/asm/spinlock.h:78: parse error before `void'
/usr/include/asm/spinlock.h:93: parse error before `do'
/usr/include/asm/spinlock.h:121: conflicting types for `rwlock_t'
/usr/include/linux/spinlock.h:110: previous declaration of `rwlock_t'
/usr/include/asm/spinlock.h:146: parse error before `void'
/usr/include/asm/spinlock.h:155: parse error before `void'
au_audio.c:78: warning: initialization from incompatible pointer type
au_audio.c:79: warning: initialization from incompatible pointer type
au_audio.c:80: warning: initialization from incompatible pointer type
au_audio.c:82: warning: initialization from incompatible pointer type
au_audio.c:83: warning: initialization from incompatible pointer type
au_audio.c:84: warning: initialization from incompatible pointer type
au_audio.c:85: warning: initialization from incompatible pointer type
au_audio.c:87: warning: initialization from incompatible pointer type
au_audio.c: In function `au_audio_read':
au_audio.c:193: warning: passing arg 1 of `interruptible_sleep_on' from incompat
ible pointer type
au_audio.c: In function `au_audio_write':
au_audio.c:261: warning: passing arg 1 of `interruptible_sleep_on' from incompat
ible pointer type
au_audio.c: In function `au_audio_poll':
au_audio.c:311: warning: passing arg 2 of `poll_wait' from incompatible pointer
type
au_audio.c:313: warning: passing arg 2 of `poll_wait' from incompatible pointer
type
au_audio.c: In function `au_audio_mmap':
au_audio.c:609: dereferencing pointer to incomplete type
au_audio.c:612: dereferencing pointer to incomplete type
au_audio.c:614: dereferencing pointer to incomplete type
au_audio.c:620: dereferencing pointer to incomplete type
au_audio.c:624: dereferencing pointer to incomplete type
au_audio.c:630: dereferencing pointer to incomplete type
au_audio.c: In function `drain_playback':
au_audio.c:724: warning: passing arg 1 of `interruptible_sleep_on' from incompat
ible pointer type
au_audio.c: In function `add_wave_device':
au_audio.c:771: warning: implicit declaration of function `init_waitqueue'
au_audio.c: In function `get_frags':
au_audio.c:843: warning: implicit declaration of function `MAP_NR'
au_audio.c: In function `au_handle_timer':
au_audio.c:1121: warning: passing arg 1 of `__wake_up' from incompatible pointer
type
au_audio.c:1143: warning: passing arg 1 of `__wake_up' from incompatible pointer
type
au_audio.c:1173: warning: passing arg 1 of `__wake_up' from incompatible pointer
type
make: *** [au_audio.o] Error 1
Er gaat iets fout... Alleen WAT gaat er fout?
\o/
  • StarLite
StarLite
argh, quote en edit door elkaar gehaald
\o/
