Unreal werkt niet met Voodoo Banshee!!
  • 134 views sinds 30-01-2008
Ik heb nu unreal (Gewoon) maar ik krijg hem niet aan de praat met de voodoo banshee
Ik moet zeker een patch downloaden maar ik heb die niet gevonden
Wat moet ik doen??
Alvast Bedankt
Wat dacht je hiervan:
3dfx heeft nieuwe Windows 9x drivers in elkaar getimmerd voor haar Voodoo Banshee videokaartjes. Hieronder de waslijst met veranderingen aangebracht in versie 1.04.00:
Driver updated to support General Format mode Timings
Fixed issue with possible Deer Hunter 2 hanging at main menu.
Fixed issue which caused a slowdown with some Glide and OpenGL applications.
Fixed issue with Unreal not running with OpenGL.
Fixed issue with the control panel not allowing the selection of 800x600 when the machine was used with a non-PNP monitor.
Fixed issue with Quake 3's brightness control being grayed out.
Fixed issue with Flight Sim 98 and 2000 missing point lights during night scenes on right of screen.
Fixed issue with desktop corruption occurring when changing form a 16bit mode to 8bit mode on certain motherboard/processor combinations.
Fixed issue with Moto Racer2 crashing to the desktop when attempting to load.
Fixed issue with System Shock 2. Players could lose weapon overlay, depending on position.
Fixed issue with Jane's USAF, Textures beyond plane visible through the plane.
Fixed issue with Deer Hunter 3, Terrain behind buildings visible through the building.
Updated OpenGL with miscellaneous bug fixes
Fixed issue with Organic Art screen saver causing screen corruption and/or system lock when running with power management enabled.
Fixed issue with pulsating circles around edges of jump pads and lighting around skull being corrupted with Q3 test.
Fixed issue with fog not correctly displayed on Q3 Test.
Fixed issue with Motor cross Madness: Menu distortion.
Fixed issue with Screen failing to update (freezing) after exiting Zoran SoftDVD when TV out only enabled
Fixed issue with 3DMark99 locking up during transition from Game Test#2
Fixed issue with 3DMark2000GM game Test#1 freezes and locking Windows
Fixed issue with Quake 3 Smoke trails and other alpha blended effects that caused frame rate to slow to near zero a
http://www.tweakers.net/nieuws.dsp?ID=8999
Probleem weg?
Ja die heb ik ook al geprobeerd maar dat werkt nog niet!!
Ik had hetzelfde probleem met nfs3 en toen had ik een patch geload en toen deed die het!!
Neem iig Direct x 7a en Unreal 2.25f.
Als dit nog niet werkt moet je is wickedgl proberen. Een maat van mij had ook problemen met z'n banshee.
Anders moet je ff een vraag droppen op www.3dfxgamers.com , daar heb je een grotere kans.
Suc6!!!
