Nieuwe Mutators op [GoT] CTF server !
  • 105 views sinds 30-01-2008
Beste mede-fragaholics
Vanaf vandaag draaien er nieuwe mutators op de [GoT] CTF server:
- Headshot Bonus
Iedere headshot geeft je niet 1 maar 2 frags, en verhoogt je health met 10
- MoreGore
Extra Gibs en Gore als je iemand neerknalt. Vooral bevredigend bij multikills!
- RuneZ 1.3
Verspreid over de maps liggen Runez- permanente powerups die het volgende doen:
What types of "Runes" are there?
Well, Runes can be broken up into three categories:
OFFENSIVE:
These Runes affect the way you do damage, and are unrelated to your health. They are:
Strength Rune: While you have this "Rune", you do 2x Damage.
Pestilence Rune: Everything around you takes some damage
DEFENSIVE:
These Runes affect your Health/Resistence to Damage. They are:
Regen Rune: Your health slowly regenerates up to 150%.
Resist Rune: You take only half damage.
OTHER:
These Runes affect both your Offensive and Defensive abilities, or neither. They include:
Vampire Rune: Whenever you hit some one, you get 50% of the damage you dealt added to your health.
Barb Rune: Whenever you hit some one who has this rune, you will take 50% of the damage you dealt.
Alle maps en mutators zijn nog steeds op te halen op zap.to/got
Kick Some!
Afbeeldingslocatie: http://isecure.dreamhost.com/nph-a.cgi/http/www.planetunreal.com/necron_99/RuneZ/pestilence.jpg Afbeeldingslocatie: http://isecure.dreamhost.com/nph-a.cgi/http/www.planetunreal.com/necron_99/RuneZ/regen.jpg
  • ViNcE
  • Registratie: Juli 1999
ViNcE
Nog 3, nog 2, nog 1, .....
Miischien ook wel een goeie mutator is
cft/e. Die zag ik laatst bij www.planetunreal.com . De mutator doet oa het volgende:
+ Logon Menu that allows team selection
+See the current state of the game before entering
+Select your team from an easy to use menu.
+ Improved Team Balancing measures
+ Players cannot switch or join a team with a player advantage
+ The team that has the advantage can not cap the flag until it's even
+ Onscreen auto-message of Team Imbalance.
+ Players who switch no longer lose their score
+ Server side toggle to give a bonus to the players who even the teams
Want soms is het niet helemaal eerlijk verdeeld op de server..... :)
"Sometimes I really think people ought to have to pass a proper exam before they're allowed to be parents. Not just the practical, I mean." - Terry Pratchett, Thief of Time
Mijn BGG profiel
  • elmuerte
  • Laatst online: 02-08 20:00
CTF/e is geen mutator maar een game type, dus das wat minder
Ja, die CTF-e is wel gaaf met menuutje enzo, maar de uitgepakte versie is weer 1,5MB, en ik zie het nu al gebeuren dat iedereen die aanlogt eerst die files allemaal van de server moeten downloaden. Slecht voor de ping en slecht voor het aantal bezoekers.
De mutators die er nu op staan zijn samen maximaal zo'n 300KB, 1 minuut met een 56K6 aansluiting, en zeker de moeite waard.
  • ViNcE
ViNcE
Ik kom er niet in. Hij wil die rune.mod niet downloaden. Ik krijg dezelfde foutmelding als toen met die fragmaniacs skinpack. Ik weet niet wat het is, mischien is hij toch nog te groot...
Hebben anderen dat ook?
Mijn BGG profiel
Ik ben er pas na 2 dagen achter gekomen dat de server Runez en ook andere mutators niet wilde uploaden. Dat ligt niet aan mijn instellingen, het kan volgens mij niet. Alleen maps.
Nu draaien er nog Headshot bonus, MoreGore en Pinata, die veranderen alleen wat instellingen dus er hoeft niets te worden verstuurd. Volgens mij moet het nu wel lukken.
  • ragger78
  • Registratie: September 1999
  • Laatst online: 20-06-2025
ragger78
ehm...ja
Moet toch wel kunnen met versie 405:
Admininstrators can control downloading of packages from their server by editing the [IpDrv.TcpNetDriver] section of unrealtournament.ini:
AllowDownloads=True
MaxDownloadSize=0
AllowDownloads disables all autodownloads.
MaxDownloadSize=0 means allow autodownload of any sized file. Otherwise the value is in BYTES. We recommend that rather than disabling all
downloads, you set the MaxDownload size to an appropriate value. For example, MaxDownloadSize=100000 will allow mutators and other small packages
to be downloaded, but will not allow large files such as maps to be downloaded.
DUH!
Volgens mij kijk ik scheel, ik heb die instellingen wel 3x nagekeken, maar ik had MaxDownloadSize op 100000 staan, niet 1000000. RuneZ werkt!
YEEEEEHHAA!
Bedankt bjorge :)
PS: check out de nieuwe screenshots!
  • Thijs B
  • Registratie: Augustus 1999
he bij welke provider draaien die servers heb een casema modem en die is traag.
als ik wil gamen moet ik dus inbellen maar vraag me af via welke provider ik een redelijke ping kan halen..
Thijs, ik heb gehoord dat Wannadoo en Worldonline met hun gratis abonnementen heel goed zijn wat pings betreft. Ik heb er zelf geen ervaring mee, de server draait op A2000/ Chello.
