Green skins in UT ?!?!
  • 126 views sinds 30-01-2008
  • TonyTone
  • Laatst online: 26-12-2025
I have a problem, I have 2 PC connected to play UT. 1 with a Geforce and 1 with a Voodoo2 card. On the one wirh the Voodoo2 I have Green players when I choose a custom skin. with original skins I have no problems
and on the other PC (geforce card) all skins are oké, also the 1 of de Voodoo2 PC.
What could this be ??!?
jaja, ik ben zo Dyslectish als een baksteen.
I have the same problem. I've got three PC's, one with a TNT2 and two with Voodoo2.
The one with the TNT2 is oke, but the two with the Voodoo2 give a green skin, So I think the Voodoo2 is the problem. Another possibility is the memory, the problem pcs have 64mb and the good one 128mb.
Same problem here, but the cause is not the V2 or V3, but the fact that you're connecting the PC's together. If you play the game in single play (against bots) your skin will work (just type behindview 1 in the console) but when you connect to a server things get screwed up. Why are we speaking English anyway?
  • VorteX
  • Laatst online: 26-06 08:21
VorteX
held
Maar je mag op zich best wel Nederlands praten hoor... :) :)
Inexperienced travellers might think that 'Aargh!' is universal, but in Betrobi it means 'highly enjoyable' and in Howondaland it means, variously, 'I would like to eat your foot', 'Your wife is a big hippo' and 'Hello, Thinks Mr Purple Cat.'
Ja en hoe lossen we dit op. Ik heb geen zin om als KERMIT de KIKKER rond te lopen ???
Yes and how do we solve this. I don't want to run around like KERMIT the FROG
  • Clay
  • Laatst online: 22-06 13:51
Clay
cookie erbij?
kweenie, ik heb ook een voodoo2, maar als mijn skins groen zijn zie ik dat toch niet.
Is lekker makklijk als je kleurenblind bent :) :)
(is alleen wel lastig met webdesignen, maak ik iets tofs, komt mijn zus langs: "uh jah aardig, maar waarom is dat groen?" dus ik zo: "groen?!?! ik dacht geel?!?!")
Instagram | Flickr | "Let my music become battle cries" - Frédéric Chopin
ik heb een diamond viper 550 en ook bij mij zijn de ventjes soms groen. Dan zie ik alleen bij welk team ze horen als ze maar niet dood willen of als ze de vlag van de tegenpartij bij zich hebben..
wat is dit nou?
  • TonyTone
Maar niemand heeft nog een antwoord ?!?
Damn (Kut kikkers)
  • Kolky
  • Laatst online: 22:58
Kolky
subtitle not available
ik hbe helemaal nergens last van.
viper v550
  • ragger78
  • Registratie: September 1999
  • Laatst online: 20-06-2025
ragger78
ehm...ja
ik heb even gezocht in het forum van unreality.org :
The problem is:
The server has got the skin, but not the line in unreal.tournament.ini to active it in multiplay (this must be done when the server is turned off otherwise the server will overwrite the old one)
In the unrealtournament.ini you see something like this:
[Engine.GameEngine]
CacheSizeMegs=30
UseSound=True ServerActors=IpDrv.UdpBeacon ServerActors=IpServer.UdpServerQuery ServerActors=IpServer.UdpServerUplink MasterServerAddress=unreal.epicgames.com
MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master0.gamespy.com MasterServerPort=27900
ServerActors=IpServer.UdpServerUplink MasterServerAddress=master.mplayer.com MasterServerPort=27900
ServerActors=UWeb.WebServer
ServerPackages=SoldierSkins
ServerPackages=CommandoSkins
ServerPackages=FCommandoSkins
ServerPackages=SGirlSkins
ServerPackages=BossSkins
ServerPackages=Botpack
now under these lines put this one: (if its a soldier skin)
ServerPackages=SoldierSkins_skinname
for example, the skin is called SoldierSkins_poop, then add the line
ServerPackages=SoldierSkins_poop to the unrealtournament.ini
that will be all
remember: only do this when the server is turned off
het hele draadje is hier: http://www.unreality.org/ubb/Forum4/HTML/000451.html
  • ragger78
ragger78
ehm...ja
Ik het bovenstaande even uitgeprobeerd, en het werkt inderdaad, ik had nu wel het juiste pakje aan :)
Bedankt bjorge. Eindelijk doet 'ie het! Wel effe op letten dat UT niet aanstaat als je het .ini bestand gaat aanpassen (duh :P)
  • TonyTone
Yo bjorge BEDANKT voor de Tip !!!
het werkt inderdaad perfect.
(ook wel logisch achteraf)
Nu weer lekker knallen! Op marvel heroes. ;)
