quake3 op win2k final met ultra
  • 100 views sinds 30-01-2008
  • RobbyNitroz
  • Registratie: Augustus 1999
  • Laatst online: 04-09-2021
werkt niet :-(
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:\Gamez\Quake III Arena\baseq3\pak0.pk3 (3539 files)
C:\Gamez\Quake III Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: server
IP: 192.168.0.2
Working directory: C:\Gamez\Quake III Arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
begin gaat nog goed...maar daarna gaat het fout omdat ie goeie pixel size niet kan vinden ofzo....heeft iemand de oplossing voor me?!?
thanx!
RobbyNitroz
altijd de laatste AMD-cpu op het laatste mobo met zoveel geheugen als erin past :-)
  • /TheDuke\
  • Registratie: December 1999
Een simpel antwoord:
Er zijn GEEN (officiele) openGL drivers voor Win2k
Maar je kan altijd ff op de volgende link kijken,zijn niet officeel ondersteund maar wel makkelijk als je openGL wilt gebruiken onder Win2k (zoals veel gamers)
(let niet op Gforce,hij werkt op alle recente TNT modellen
http://www.clanworld.dk/files/essentials/drivers/nVidia/GeForce256/Windows_2000/win2k-geforce-365.zip
  • RobbyNitroz
net geprobeert....blauwe schermpie voorbij..maar dan een grijs scherm en vast met die driver :(
ik d8 dat in final win2k direct X 7.1 zat..maar kan hem ook niet vinden...in eerste regels zie je wel dat opengl.dll al wel in standaard driver zit!
RobbyNitroz
  • /TheDuke\
Het zegt inderdaad dat die hem vind
maar zie het volgende:
Will there be any OpenGL drivers shipped with Windows 2000?
Not at this time. Historically, OpenGL ICDs have been provided directly by IHVs (either in their box or on their web site). OpenGL ICDs have also been pre-packaged on systems by OEMs.
zie http://www.opengl.org/News/Events&Notices/w2k.html voor het hele verhaal
verder zou ik het nu niet weten,wacht tot er officiele drivers uitkomen zou ik zeggen,en hou tot die tijd een duel boot
  • RobbyNitroz
thanx for the info duke
ik heb net 3.66 gevonden voor win2k...
ga ze thuis uitproberen
mmh mijn BP dual 366@550 is toch server maar vin het wel handig als je erop kan quaken als er maatje langskomt...server draait alleen win2k werkt prima :)
"desktop" systeem is atlhon 500@750 met geforce...die draait win98se :)
RobbyNitroz
