UT TNT2 Tweaks....
  • 117 views sinds 30-01-2008
  • MP3-Junky
Eindelijk wat gevonden:
Hit tilde [~] to bring up the console and type preferences.
Locate the display item amnd open it up.
Set ScreenFlash to false.
Set Decals to False.
Det NoDynamicLights to true. [All three of these can be changed under the normal preference menu also.]
Then find Rendering, D3D and set these options.
VolumetricLighting= False
HighDetailActors=False
DettailTextures=False
If you FPS was really bad you may also wish to set ShinySurfaces to False, and Coronas has never seemed to change my performance even one FPS, but feel free to try it set to false also.
You can manually edit these in the UnrealTournament.ini file under the headings of [WinDrv.WindowsClient] and [D3DDrv.D3DRenderDevice]
Lighting seemed to make the biggest effect, and if you are hopelessly slow even after these changes, under display is an option for NoLighting, set it to true. This will make the game incredibly ugly however, it did enable me to break 50 FPS avg with a GeForce DDR on a P2-450 with 128MB ram and my low was exacxtly 30.15 FPS which played nice enough that I was never killed by an invisible rocket. And yes, I have plenty of swap space and a completely defragged HD with the swapfile at the end unfragemented. As well as the latest detonators drivers, and the 402 patch. Good luck to you nvidia users.
  • Kool
  • Registratie: September 1999
UT TNT2 Tweaks? Je zet juist alle mooie dingen uit!
Op mijn PII 400 met TNT2 Ultra draait ie superdeluxe met alle details maximaal.
