...Met een willekeurige geforce mx kaart.
Gaat dit dan een mooi beeldje geven en is er een spelletje op te spelen??
Heeft iemand ervaring met dit schermpje, zoja vertel er graag wat meer over.
Welke mx kaart raden jullie aan bij dit scherm ??
specs scherm:
Model TXA3823MT
LCD 38,0cm (15"), a-Si TFT Active Matrix
Viewing zone Horizontal 120 degrees, vertical 90 degrees
Compatibility All current PC and MAC graphics standards. Windows® 95/98 Plug-and-Play (DCC 1/2B)
Displayable colors Approx. 16 million
Pixel arrangement RGB vertical stripe
Sync Frequency Horizontal: 24.8 - 61.0 kHz Vertical: 55 - 75 Hz
Video bandwith 80Mhz dot clock
Resolution 1024 x 768 (max.) lwer resolutions are displayed with digital linear smoothing for optimum picture
Response time Rise: 20ms, Fall: 30ms
Brightness 200 typical
Contrast 150 moninal
Backlight Fluoriscent light cold cathode tube x 2
Input signal 15 pin D-sub connector 1,8 mtr VGA 15 pin cable included
User controls 3 push buttons accessing contrast and brightness adjustment, clock and phase adjustment, horizontal and vertical positioning, colour balance, colour temperature, auto set-up language selection (including Dutch)
Plug & Play VESA DDC 1/2B
Power supply World-wide 90-132/198-264VAC, 50/60Hz
Power usage 40W maximum in normal use 5W in suspend mode
Power saving Auto power down to standby mode, VESA-DPMS, EPA Energy Star and Nutek, TCO99 Compliant
Low radiation TCO99 and MPRIII compliant
Approvals TCO99, CE, TÜV-GS, MPRIII, (prEN50279)/ISO13406, FFC-B, UL/C-UL,VCC-B
Operating temperature 5 - 35 degrees
Humidity 20-85% non condesing
Accessories User manual (incl. Dutch), Power cable, USB cable SU41, audio cable AD21, signal cable (1,8 mtr)
Manufacture All monitors manufactured using CFC free materials, non-toxic metals and non- bromided flame retardants, and are fully recyclable. Recycled material used for packaging and user documentation
Additional features Integrated USB HUB (1 upstream, 4 downstream ports), 2 x 1 W front firing speakers, removable base / VESA compliant mounting plate, no need for seperate power supply
(hm staat er niet helemaal mooi en duidelijk maar ja...moet maar ff, anders ff kijken op www.Iiyama.nl
[typo]
specs scherm:
Model TXA3823MT
[typo]
1..2 Freddy's coming for you, 3..4 Knocking at ya door, 5..6 Grab your crusifix, 7..8 Better stay up late, 9..10 Never sleep again|| SPECS
