En deze heb ik ook voor je.
Q. Where can I get and how do I use NVFlash?
NVFlash does not work under Windows 2000.
If you want to use NVFlash under Windows ME, make sure you install the Real DOS-Mode Patch for Windows Millennium first.
You might want to read the ''How can I use the latest Video BIOS without flashing my Video BIOS?'' question. Be warned that flashing your Video BIOS could quite possibly permanently damage your card, and it is unlikely that any company would be willing to replace the card for free. Having said that, so long as you follow these instructions you should not have any problems. This is NOT for beginners.
You can download the NVIDIA Flash program at the following website:
http://www.m3dzone.com/zoiah/
Download the latest version under the BIOS / Utilities / NVFlash section, or here:
http://www.gforcex.com/biostop.htm
You will also need a copy of DOS4GW - download it at the following website:
http://www.fastgraphics.com/zip/dos4gw.zip
Extract both files to an empty directory, along with the Flash BIOS file that you are going to use (see ''Where can I get the latest NVIDIA Flash BIOS and which should I use?'' question).
Reboot your PC and when it says ''Starting Windows 9x...'' press F8. Select ''Safe Mode Command Prompt''.
Switch to the directory where you extracted the files and type: NVFLASH -fFILENAME where FILENAME is the name of the Flash BIOS file you downloaded.
Now wait. The screen may go black, but watch the keyboard lights - they will make a pretty pattern to assure you that the system is still working
When the process is finished, reboot.
