Canon 5D Mark II, Canon 35 f/1.4L
Ik gebruik gewoon de Raid-on Tweaker ... zit een optie ''fix shimmering'' oid in.
Shimmering zijn een soort horizontale/diagonale strepen die over je beeld heen ''rollen'' ..
Ik heb er zonder de patch ook een beetje last van (vooral jitter) .. heb een Iiyama A901HT monitor met Diamondtron beeldbuis ..
Bron : Rage3DThis setting corrects for the shimmering that some Trinitron/Diamondtron tube monitors experience with the Radeon. It slightly modifies the horizontal frequency/slows the edge rates to correct for inconsistencies in system configuration and varying monitor timings. By default this value is set to "0", or disabled and should be fine for the majority of systems out there. If you experience shimmering in your monitor, try setting this to "1" and you should see significant improvement. You will have to reboot between changes of this setting. This option is only available in the most recent drivers, specifically drivers with a build of D7.16-xxxxx-xxxx-ATI and later. There appear to still be some issues with full screen DOS sessions, but this is supposed to be fixed with drivers coming out shortly.
ok thanx
hlpdsk waarom zuigt @home hard???
heb hier geen problemen
