http://www.ping.be/bios schreef in de FAQ:
The Intel VX doesn''t have enough Memory Address lines to drive the
higher integration DRAM technology, be it EDO or SDRAM. 16-MBit is the highest density
supported, while the parts on a 64-MByte EDO SIMM are 64-MBit (eight chips)
Do the math - count the SDRAM chips on your DIMM (the large ones)
[if they''re ECC DIMMs, round down to the nearest power of two], and compute:
((total capacity in MByte)*8)/(number of chips)
The result is the density in MBit of the SDRAM components used.
Examples:
32-MByte DIMM with 16 chips: 32*8/16=16, usable with Intel VX.
128-MByte ECC DIMM with 18 chips - round down to 16, 128*8/16 = 64,
not usable on VX.
As current production is 64- or 128-MBit densities, the bottom line
of all this is that SDRAM support in Intel VX is useless with today''s DIMMs.
Also, in order to have your board recognize
32Mb per DIMM, you''ll need the 16-chip versions. If you have the 8-chip version, only 8Mb (your case) will be recognized.
Remember, it''s not a memory problem; it''s a
chipset limitation. And no, this can''t be fixed by a BIOS update.
