[BC3] error:msvcrt.dll is not comp. with win32s
  • 181 views sinds 30-01-2008
  • jaspov
  • Laatst online: 21:43
Ik krijg deze melding bij het draaien van de setup van een aantal programmas. Ik draai w2k sp2
Ik zag wat eerdere posts maar die verwijzen naar een speu.exe die er niet (meer) is.
enig idee iemand? ik heb ie5.5 en sp2 al opnieuw geinstalleerd zonder geluk.
  • Arno
  • Laatst online: 01-11 11:39
Arno
PF5A
PRB: Error "...MSVCRT20.DLL is not compatible with Win32s" [Q125476]
PSS ID Number: Q125476
Article last modified on 02-04-2000
2.0 2.1 2.2 4.0 4.1
NT WINDOWS
The information in this article applies to:
- The C Run-Time (CRT), included with:
- Microsoft Visual C++, 32-bit Editions, versions 2.0, 2.1, 2.2, 4.0, 4.1
SYMPTOMS
When running a Win32-based application that was linked with MSVCRT.LIB on
Win32s, a message box titled "MSVCRT??.DLL for Win32" displays the message
"Error: This version of MSVCRT??.DLL is not compatible with Win32s" where ??
specifies the runtime version. The application terminates following this
message.
CAUSE
There are two versions of each MSVCRT??.DLL -- one for Win32s and one for
Windows NT/Windows 95. If you use the wrong version on Win32s, the error
described above occurs.
The following is a list of Visual C++ versions and the runtime DLLs that are
included with them:
Visual C++ File Size Date / Time
2.0 WIN32S\REDIST\MSVCRT20.DLL 237,568 09-12-94 / 7:00a
2.0 MSVC20\REDIST\MSVCRT20.DLL 243,200 09-12-94 / 8:00a
2.1 WIN32S\REDIST\MSVCRT20.DLL 244,736 01-20-95 / 9:46a
2.1 MSVC20\REDIST\MSVCRT20.DLL 250,368 01-20-95 / 9:45a
2.2 WIN32S\REDIST\MSVCRT20.DLL 244,736 01-20-95 / 1:46a
2.2 MSVC20\REDIST\MSVCRT20.DLL 253,952 02-23-95 / 11:32a
4.0 WIN32S\DEBUG\MSVCR40D.DLL 437,760 09-29-95 / 9:33p
4.0 WIN32S\REDIST\MSVCRT40.DLL 320,000 09-29-95 / 9:35p
4.0 MSDEV\DEBUG\MSVCR40D.DLL 439,296 09-29-95 / 9:25p
4.0 MSDEV\REDIST\MSVCRT40.DLL 312,832 09-29-95 / 10:06p
4.1 WIN32S\DEBUG\MSVCR40D.DLL 439,296 02-14-96 / 4:43p
4.1 WIN32S\REDIST\MSVCRT40.DLL 332,048 02-07-96 / 3:24a
4.1 MSDEV\DEBUG\MSVCR40D.DLL 444,928 02-19-96 / 5:05P
4.1 MSDEV\REDIST\MSVCRT40.DLL 326,656 02-19-96 / 5:03p
RESOLUTION
On the Visual C++ product CD, you will find the Windows NT/Windows 95 version of
the runtime DLL in the MSVC20\REDIST or MSDEV\ directories shown above and the
Win32s version of the runtime DLL under the WIN32S\ directories shown above. The
files that end with the letter "D" are the debug versions of the libraries which
are accompanied by a debug info file that has the same name and a ".PDB" file
extension.
You should ship both release versions of the runtime DLL with your application if
it is to be run under Win32s. Your setup program should detect which platform
you are installing the application under and copy the appropriate DLL. Install
the Win32s version in the WINDOWS\SYSTEM directory of your Windows or Windows
for Workgroups machine.
MORE INFORMATION
A similar error occurs if the Win32s version of MSVCRT??.DLL is used on a
Windows NT machine or a Windows 95 machine. The error''s title is "MSVCRT??.DLL
for Win32s," and the message is:
Error: This version of MSVCRT??.DLL is only intended for Win32s.
Additional query words:
Keywords : kberrmsg kbCRT kbVC kbWin32s
Technology : kbvc
Version : 2.0 2.1 2.2 4.0 4.1
Platform : NT WINDOWS
Issue type : kbprb
Copyright Microsoft Corporation 2000.
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
  • jaspov
Dank maar die pagina heb ik dus ook gevonden. Staat op dat een softwareleverancier de juiste versies van die file mee moet leveren bla bla bla maar daar schiet ik dus weinig mee op.
wat kan ik doen?
  • jaspov
system file checker gedraaid en nog niets.....wel NOG meer sites gevonden op internet met gebruikers met dit probleem maar nergens een oplossing. File staat 3 keer op de pc allemaal met versie
6.1.8924.0
  • jaspov
Opgelost. het is een bug in apcompat.exe!
  • Hubert
  • Laatst online: 18:55
Hubert
Decepticons 4ever!!!!
hoe heb je t opgelost dan?
Together let us beat this ample field, Try what the open, what the covert yield.
sorry voor het uit de sloot halen van deze oude koe
maar ik zit met precies hetzelfde probleem (ook veroorzaakt door apcompat). hoe heb je het opgelost ?
  • elevator
elevator
Officieel moto fan :)
LAuWe,
Er is een erg kleine kans dat dit ooit nog beantwoord gaat worden omdat het topic meer dan 3 jaar oud is :)
Ik ga dit topic sluiten - open gerust een nieuw topic :)
