'It's all a matter of opinion' LTJ Bukem | 'You don't need eyes to see, you need vision' Maxi Jazz
Dit is de uitleg van M$ wat userinit.exe is
USERINIT.EXE == Windows NT logon user interface
En dit is wat het doet.
Userinit.exe Activation
Userinit.exe is an application that is executed by MSGina.dll when the user has logged on. It runs in the newly logged-on user''s context and on the application desktop. Its purpose is to set up the user''s environment, including restoring net uses, establishing profile settings such as fonts and screen colors, and running logon scripts. After completing those tasks, Userinit.exe executes the user shell program(s).The shell programs inherit the environment that Userinit.exe sets up. The specific shell programs that Userinit.exe executes are stored in the Shell key value under the Winlogon registry key.
The Shell key value can contain a comma separated list of programs that will be executed. Explorer is the default shell program and will be executed if the Shell key value is null or not present. By default, Explorer is listed.
Ik vind hem bij registry keys:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Explorer Bars\{C4EE31F3-4768-11D2-BE5C-00A0C9A83DA1}\FilesNamedMRU
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Eventlog\Application\Userinit
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Eventlog\Application\Userinit
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application\Userinit
HKEY_USERS\S-1-5-21-984618572-1381184312-227697207-1001\Software\Microsoft\Internet Explorer\Explorer Bars\{C4EE31F3-4768-11D2-BE5C-00A0C9A83DA1}\FilesNamedMRU
Staat er bij deze keys echt nix wat naar a: verwijst:?
Als ik bij M$ zoek (gewoon alles aanvinken en letterlijk op USERINIT.EXE zoeken) krijg ik ongeveer 100 hits over USERINIT.EXE hier moet toch haast wel de oplossing tussen staan.
Thnx voor je hulp R2D2, ik heb inmiddels met dank aan google en een windows NT forum de oplossing gevonden. Voor degene die er in geinteresseerd zijn:
userinit.exe laadt niet alleen de shell van windows (explorer.exe), maar ook de fonts. En daar zat hem bij mij nou net de kneep. Ik heb laatst voor iemand een briefke geprint met een lettertype dat ie op disk aangeleverd had. Dat heb ik met Adove Type Manager geinstalleerd zonder de files te kopieren. Font-set was ik dus vergeten uit te zetten, vandaar dat windows bij het opstarten elke keer zocht naar dat lettertype op de diskdrive.
Dex
Dex
