[BC3] Animated spraypaints in HL!!!
  • 107 views sinds 30-01-2008
  • Vinnienerd
  • Laatst online: 00:13
En hier staat hoe het moet:
D''r zitten wel limieten aan:
Making a animated color logo is just like making a colored logo except it has ALOT of restrictions.
1. You can''t have holes in your logo even if you use 255 blue.
2. The animated logo will be smaller in dimension depending upon how many frames are in the animation.
3. A animated spray can not have more than 10 frames.
4. The name of the first frame must start with a "+0" (without the quotes)
5. Each additional frame must go up sequencialy by 1''s. Ex: +0Logo, +1Logo, +2Logo etc...
6. The total file size of the pldecal.wad must not exceed 15k or it will not be uploaded to the server.
7. The animation will only play ONCE per spray. (Hopefully valve will fix this in the next patch)
Rule 7 is the one that everyone is going to hate. But you can use this restriction to your advantage. For instance, if you were to make spray of an Eyeball. And that eye has its eyelids closed for 2 frames and then open for the 3rd frame. You in effect would have a spray that once sprayed is shown in game as a constantly open eye. But when ever you press your spray button, the eye will magicaly blink!
If your animated logo is a continuos loop, like a spining globe, then it will only play the animation once and will will pause on the last frame. If Valve fixes the logos so that they loop continulessly then that wont be a problem. It will work fine. But for now, there is one way to fake it. Server Administers, set this command in your console. decalfreqency "2" (with or without the quotes) this will allow the user to continuosly press their spray button to have their animated spray loop.
Decalfreqency is used to change the amount of delay there is between each spray. Do not set it to 1 or 0 unless you don''t mind people spaming the whole map with their decals. 2, 3, 4,etc is best for a short delay yet allowing animated sprays to be done in a loop by the client.
Maar hoe maak ik nou zo''n spraypaint?
Make the spray while following the same rules as any colored logo.
Remember that if theres 7 frames, each frame would have to be 32x32 in dimension due to the 15k size limit.
First draw the first frame and save it as +0LOGO
Then draw each aditional frame saving it as +1LOGO, +2LOGO etc..
Then compile them into a pldecal.wad using Wally (www.telefragged.com/wally) or the TextureSDK (included with Valves SDK2.0)
Thats it!
Bron: >:) Zeg ik lekker niet >:)
  • YakuzA
YakuzA
Wat denk je nou zelluf hey :X
wally heb ik al nu alleen de rest nog :P
PSN
  • pica
  • Laatst online: 26-08 13:21
WOOHOO! Moving Enterprise! :9
Steam
  • BC3 Victim
  • Laatst online: 29-09-2006
bron:klik
(de eerste hit in google.com met zoekterm: half-life animated logo was al raak) :Z
have fun!
  • BasieP
  • Laatst online: 19-10-2025
is kewl...
maar ik doe het toch maar niet...
1 keer afspelen is wat weinig ;)
This message was sent on 100% recyclable electrons.
  • Captain Pervert
  • Laatst online: 26-02 17:43
Hahaha, zal me benieuwen hoe men dit concept wederom weet te combineren met sex :)
Ik bedoel, ik kan nergens rondlopen met mijn MP5 of ineens zie ik een paar dikke tieten of gespreide benen op de muur... :P
Porsche 928 - It's about as fast as you can go without having to eat airline food.
  • Buck Danny
Buck Danny
flying ace
Ja erg he? Maar aan de andere kant, soms zitten er echt mooie kunstwerkjes tussen :)
  • 8088
NaN
Zeg ik lekker niet.
The Flat Earth Society has members all around the globe.
  • Vinnienerd
Op dinsdag 29 mei 2001 07:29 schreef KillBilly het volgende:
Zeg ik lekker niet.
Wat?? :?
Vinnienerd nerd er ligt nog steeds een CD klaar voor jou hier... Naaiertje :)
  • Vinnienerd
Ik neem contact met je op met ICQ :)
  • Vinnie
Op maandag 28 mei 2001 19:26 schreef JeanLucPicard het volgende:
Welke? /A/B/C/D/E :)
C:\>_
  • Chillout
  • Laatst online: 03-09-2025
leuk idee: maak een paar shots van je eigen player, en maak er een animated movietje van... denkt de ''vijand'' dat jij daar loopt, gaat ie op je schieten, schiet ie zn hele wapen leeg, en dan val jij aan :D
Jaa, zijn er al proggies voor??
Zodat ik ze zelf hoef te fixen, ik ben namelijk een beeetje lui! :P
color logo''s zijn gaar :(
en beweegde helemaal
  • Speedy
  • Laatst online: 16:42
r_decals 0 heerst :)
Had zelf altijd wel een vette colorspray, helaas kwijt geraakt :(
Flickr | Lego collectie
  • pica
Op dinsdag 29 mei 2001 15:51 schreef TAG_Speedy het volgende:
wasda dan?
Steam
  • rove
  • Laatst online: 02-06-2022
Op dinsdag 29 mei 2001 16:34 schreef JeanLucPicard het volgende:
wasda dan?
Dat er 0 decals op je scherm verschijnen.. decals zijn dus kogelgaten, spraypaints, bloed..dat soort dingen. Gaat je fps ook van omhoog.
dunno
Op dinsdag 29 mei 2001 17:15 schreef RoVe het volgende:
so what mijn bakkie is snel genoeg. Het kan mij niet schelen ik wil gewoon alle pracht zien.
  • Speedy
Als er maar genoeg shit op je scherm zit wil je vanzelf wel al die bullshit kwijt, en niet alleen om de fps :)
  • YakuzA
YakuzA
cl_allowdownload 0
En hij download geen spraypaints meer van de server
PSN
