• BC3 Victim
  • Laatst online: 29-09-2006
Wie weet in unreal alle console commands ook cheat stuf op je eigen server.was namelijk bezig op een eigen server en deed,bv summon fly komen er vliegen in je level te staan :9
  • Artwido
  • Laatst online: 20:46
Zoiets kun je makkelijk zelf opzoeken maar hier heb je wat:
Cheat mode:
Note: The following codes may only be enabled in single player mode. Press ` to display the console, then enter iamtheone to enable cheat mode. Then, enter one of the following codes at the console to activate the corresponding cheat function.
Effect Code
God mode god
All weapons loaded
Flight mode fly
No clipping mode ghost
Disable flight and no clipping walk
Add indicated number of bots addbots <number>
Advance to indicated map open <map name>
Broadcast message to others say <message>
Change game speed (default is 1.0) slomo <1.0-10.0>
First person view behindview 0
Full ammunition allammo
Kill all indicated enemy type killall <opponent name>
Kill all opponents killpawns
Spawn indicated item1 summon unreali.<item name>
Spawn indicated opponent1 summon unreali.<opponent name>
Stop time playersonly
Third person view behindview 1
1. There are no spaces between the period and the item or opponent name.
Item names:
Use one of the following entries with the summon code.
cannon
eightball
flakcannon
nali
skaarjwarrior
quad shot
warheadlauncher
enforcer
doubleenforcer
minigun2
pulsegun
shockrifle
sniperrifle
ut_biorifle
ut_eightball
ut_flackcannon
chainsaw
rifle
razorjack
gesbiorifle
minigun
flakcannon
dispersionpistol
stinger
automag
asmd
clip
rifleround
flakshellammo
defaultammo
Opponent names:
Use one of the following entries with the killall or summon codes.
warlord
titan
stone titan
squid
slith
skaarj
skaarjwarrior
skaarjscout
skaarjlord
skaarjberserker
skaarjassassin
iceskaarj
skaarjtrooper
skaarjsniper
skaarjofficer
skaarjinfantry
skaarjgunner
queen
pupae
nali
nalipriest
mercenary
mercenaryelite
manta
giantmanta
cavemanta
krall
lesserkrall
krallelite
gasbag
giantgasbag
fly
devilfish
cow
babycow
tentacle
brute
lesserbrute
behemoth
bots
skaarjplayerbot
humanbot
malebot
maletwobot
malethreebot
maleonebot
femalebot
femaletwobot
femaleonebot
nalirabit
horsefly
blobelt
biterfish
bird1
parentblob
horseflyswarm
deadbodyswarm
biterfishschool
Boss skin:
Note: This procedure involves editing a game file; create a backup copy of the file before proceeding. Use a text editor to edit the "user.ini" file in the game directory. Add the following lines:
[Botpack.Ladder]
HasBeatenGame=True
Hint: Phantom mode:
Get killed by a rocket. Then, immediately pause the game when the screen is about to flash white. Press ~ and enable the "God mode" code. You will not be able to fight, as you cannot fire or respawn. You will have restart by escaping and starting a new game. Also, enable the "No clipping" code to look around.
  • BC3 Victim
tnx maar die had ik al :)
laat ik het zo zeggen ik zoek alle summon commands bv ik had geprobeert cannon book chair moon die kwamen er toen :P
