[BC3] [PHP] "/" inplaats van "&" en "?"
  • 270 views sinds 30-01-2008
Hi,
ik heb hier al iets over gezien maar weet helemaal niet hoe het heet dus waarmee zou ik moeten zoeken. maargoed.
In dit forum heb je bijv. niet gewoon "http://gathering.tweakers.net/showtopic.php3?Topic=5851" maar gewoon "http://gathering.tweakers.net/forum/list_messages/58512". Dit was dacht ik dat ze gewoon door zoekmachines toegevoegd kunnen worden. Maar hoe heet het (moest in de php.ini veranderd worden?) en waar kan ik er wat meer informatie over vinden?
Dank
Dat heet MultiViews en is iets van Apache. Zie Apache site voor info.
  • Redlum
  • Laatst online: 01-09-2025
Multiviews
MultiViews is a per-directory option, meaning it can be set with an Options directive within a <Directory>, <Location> or <Files> section in access.conf, or (if AllowOverride is properly set) in .htaccess files. Note that Options All does not set MultiViews; you have to ask for it by name.
The effect of MultiViews is as follows: if the server receives a request for /some/dir/foo, if /some/dir has MultiViews enabled, and /some/dir/foo does not exist, then the server reads the directory looking for files named foo.*, and effectively fakes up a type map which names all those files, assigning them the same media types and content-encodings it would have if the client had asked for one of them by name. It then chooses the best match to the client''s requirements.
MultiViews may also apply to searches for the file named by the DirectoryIndex directive, if the server is trying to index a directory. If the configuration files specify
DirectoryIndex index
then the server will arbitrate between index.html and index.html3 if both are present. If neither are present, and index.cgi is there, the server will run it.
If one of the files found when reading the directive is a CGI script, it''s not obvious what should happen. The code gives that case special treatment --- if the request was a POST, or a GET with QUERY_ARGS or PATH_INFO, the script is given an extremely high quality rating, and generally invoked; otherwise it is given an extremely low quality rating, which generally causes one of the other views (if any) to be retrieved.
meer info
-Woef-,
heb je het nu al voor elkaar?
Ik nog niet echt, heb al een aantal dingen geprobeerd maar kom er niet uit.....
  • WouZz
WouZz
Elvis is alive!
Ik ben hier ook mee bezig geweest... :D
Op een windoos bak ben ik zover gekomen dat Apache als ik localhost/blaat intypte localhost/blaat.php aanriep. Probleem was echter dat php vervolgens localhost/blaat probeerde te openen, maar die bestaat dus niet dus kreeg ik zo''n fout als ''unable to open c:\filez\www\blaat in blaat at line 0'' (ofzoiets).
Nadat ik dus een echt ''blaat'' bestand had aangemaakt lukte het mij niet om in Apache in te stellen om bestanden zonder extensie met php te parsen :(
Kortom, geen resultaat :'(
On track
  • mavink
  • Laatst online: 24-11-2025
''t is iets minder efficient, maar zo werkt het ook:
RewriteEngine On
RewriteBase /
RewriteRule ^Editor(.*) /editor.drv/$1
RewriteRule ^Zoeken(.*) /index.drv/Zoeken/$1
(.drv is hier een php-file...)
The PHP Snurk
http://freshmeat.net/projects/thephpsnurk/
En het werkt zolang je met een .htaccess bestand FileInfo kan ''overriden''.
Ik heb het dan over Apache, zie de docs :)
Cheers Marcel
  • $tranger
  • Laatst online: 21-01 02:56
Je zou het zelfs met errordocument kunnen doen. Maar dat lijkt me traag en knullig
Ik kreeg laatst dit stukje code van een engelsman, het werkt wel, maar nog niet helemaal perfect, je moet hem bovenin je pagina zetten of includen, whatever :)
Bij mij gaan er nog wel wat dingen mis, zoals bijv. de plaatjes, hij denkt dat de plaatjes dan ook in die dir staan, als je bijv een plaatje hebt als: img/bla.gif en je roept de pagina niet aan met page.php?id=2 maar met page.php/id/2 of page/id/2 ofzo, dan denkt hij dus dat het plaatje in de directory page/id/2/img staat.....
PHP:
$HTTP_TEMP_PATH_VARS = explode("/",$PATH_INFO);
array_shift($HTTP_TEMP_PATH_VARS);
reset($HTTP_TEMP_PATH_VARS);
$HTTP_PATH_VARS = array();
while( list($index,$key) = each($HTTP_TEMP_PATH_VARS) ) {
list($index,$val) = each($HTTP_TEMP_PATH_VARS);
$HTTP_PATH_VARS[$key] = $val;
$$key = $val;
Hmm, zou je dit met zo''n basehref lijntje in je header op kunnen lossen?
TangLeFuzZ: Als je bijv een plaatje hebt als: img/bla.gif en je roept de pagina niet aan met page.php?id=2 maar met page.php/id/2 of page/id/2 ofzo, dan denkt hij dus dat het plaatje in de directory page/id/2/img staat.....
Absolute URLs willen wel eens helpen. Dus ipv img/bla.gif, gebruik je /img/bla.gif
Was dat de vraag die je stelde?
nee dat werkt niet, hij ziet die fake map als een echte map zodat hij dan denkt dat de plaatjes in bijvoorbeeld www/forumindex/img/ staan ipv www/img/ ........
tis echt makkelijk!
RewriteEngine On
RewriteBase /vandaag
RewriteRule index.php.* - [L]
RewriteRule ^(.*) /index.php?vandaag=on&zoek=$1
zie ook: tv.sjeemz.nl/vandaag/now
TangLeFuzZ: nee dat werkt niet, hij ziet die fake map als een echte map
Dat maakt niet uit met absolute URLs omdat je het pad opgeeft vanaf de root van de webserver en dus NIET relatief ten opzichte van de pagina.
Op maandag 25 december 2000 15:59 schreef sjeemz het volgende:
tis echt makkelijk!
RewriteEngine On
Waar plaats ik dit?
  • stylee
  • Laatst online: 04-09-2021
stylee
blah zeg ik je
.htaccess in root dir
tis echt makkelijk!
RewriteEngine On
Ik heb dit een beetje door, maar nog niet helemaal, kun je misschien een pagina geven waar dit wordt uitgelegd?
thnx..
  • chem
  • Laatst online: 18-03 09:01
chem
Reist de wereld rond
tlf> ik doe met je mee :P
of: kan iemand uitleggen hoe je dit dus met meerdere ''levels'' doet?
dus
website.com/actie/var1/var2/var3
hoe roep ik dan
index.php?blaat=var1&blaat2=var2 etc. aan in website.com?
jah, een newbie vraag :P maar ik snap nie veel van htaccess en apache :'(
Klaar voor een nieuwe uitdaging.
me neither :)
ik bedoel dus dat ik van apache enzo ook weinig snap.....
chem: Kan iemand uitleggen hoe je dit dus met meerdere ''levels'' doet?
dus website.com/actie/var1/var2/var3
Om te beginnen moet je MultiViews aanzetten (vergeet mod_rewrite even, want dat kan VEEL meer en is dus complexer...) in je httpd.conf of .htaccess oid. Dat kan met
Options +MultiViews
Alles wat na de (incomplete) scriptnaam komt (dus /actie/...) in het voorbeeld komt in PATH_INFO te zitten.
Dus vervolgens strip je de eerste slash van PATH_INFO en explode op /. Zoiets:
PHP:
list($var1, $var2, $var3) = explode("/", substr($PATH_INFO,1));
Et voila. :)
  • chem
chem
okay, en wat als ik niet actie.php maar bv. index.php of ditispom.php wil aanroepen?
  • paulh
  • Registratie: Juli 1999
  • Laatst online: 12-03 16:31
Op zich werkt het wel maar niet alle search engines werken even goed ermee .... bijvoorbeeld www.altavista.com geeft bij mij een vage error ... terwijl nl.altavista.com wel goed werkt.
[ZwareMetalen.com] - [Kom in aktie tegen de CO2 maffia]
chem: okay, en wat als ik niet actie.php maar bv. index.php of ditispom.php wil aanroepen?
actie/foo/bar/baz
index/foo/bar/baz
ditispom/foo/bar/baz
etc...
paulh: Op zich werkt het wel maar niet alle search engines werken even goed ermee
:? Hebben we het over hetzelfde? :?
  • chem
chem
Op dinsdag 09 januari 2001 10:15 schreef Arien het volgende:
actie/foo/bar/baz
index/foo/bar/baz
ah dat vermoedde ik al... dus de naam van de file moet in de URL staan... mokay ga ik ff een mooie naam verzinnen :)
en ff denken, want ik moet dan ''alle'' linkjes omgooien wat nie tof is :P
maar bedankt!
index/bla/hallo
echo "$agvr[1] - $agvrp[2]";
werkt ook prima, geen explode voor nodig.
dat snap ik allemaal nog wel, maar hoe krijg ik het nou voor elkaar dat hij index.php pakt als ik index intik?
werkt met multiviews ja, maar als ik dat in m''n htaccess zet krijg ik een internal server error :?
TangLeFuzZ: Hoe krijg ik het nou voor elkaar dat hij index.php pakt als ik index intik?
Dat zijn dus die MultiViews...
Werkt met multiviews ja, maar als ik dat in m''n htaccess zet krijg ik een internal server error :?
Misschien heeft de beheerder ingesteld dat je geen MultiViews mag gebruiken? :?
  • Rense Klinkenberg
  • Laatst online: 23-02 22:54
Ik doe het op localhost, maar daar krijg ik ook die internal server error |:(
[update]
[url="http://localhost/test/default/"]http://localhost/test/default/[/url]
doet ie wel |:(
[/update]
dit staat nu in httpd.conf:
Alias /test "Z:/htmldocs/test/"
<Directory "Z:/htmldocs/test">
    Options Indexes FollowSymLinks MultiViews
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
en het bestandje heet default.php
freak007: Ik doe het op localhost, maar daar krijg ik ook die internal server error |:(
Zelf even gekeken onder Win32 met Apache 1.3.14:
<Directory "C:/Apache/htdocs">
    Options All MultiViews
    AllowOverride All
    Order allow,deny
    Allow from all
</Directory>
En gewoon werken...
  • chem
chem
wel stoer!
Iemand die er al een scriptje heeft gebouwd wat overal voor te gebruiken is? Dat je dus niet voor elk apart script een apart scriptje hoeft te bouwen die de variabelen eruit trekt?
Mas*Mind: Iemand die er al een scriptje heeft gebouwd wat overal voor te gebruiken is? Dat je dus niet voor elk apart script een apart scriptje hoeft te bouwen die de variabelen eruit trekt?
Aangezien je niet weet welke variabelen je meegeeft (hangt nl af van de positie in de URL) moet je het hier dus mee doen:
PHP:
En dan even de variabelen in de goede volgorde zetten en naamen geven. :)
hmz..is het niet een idee om bijv:
index.php?bla=dit&blie=dat&wie=wat
om te zetten naar bijv:
index/bla/dit/blie/dat/wie/wat
en dan met een regex de waardes eruit te halen en door eval() heen te gooien? Op deze manier kan je het voor elk script werkend bouwen? Het is maar een hersenspinseltje :)
hoeft niet eens met een regex natuurlijk....kan ook met explode
zoiets als:
PHP:
$query = explode("/", substr($PATH_INFO,1));
$fileName = $query[0];
for($i=1; $i&amp;lt;sizeof($query); $i+=2)
  $queryString[] = $query[$i] . "=" .$query[$i+1];
$queryString = implode("&amp;", $queryString);
$queryString = "$fileName?$queryString";
parse_url($queryString);
ik krijg nog steeds een internal server error, bij wat ik ook gebruik......
waar kan dit aan liggen?
Mas*Mind: Is het niet een idee om bijv: index.php?bla=dit&blie=dat&wie=wat om te zetten naar bijv: index/bla/dit/blie/dat/wie/wat
Je vergeet een ding: het script wordt aangeroepen met die tweede vorm dus je hebt hier bar weinig aan. :)
Je gebruikt niet meer een querystring met een aantal variabelen en waarden, maar een soort toevoegsel aan een URL dat er zo uit kan zien zoals jij wilt (binnen grenzen dan) en alleen jij weet dus hoe jij je informatie het script instuurt (en hoe je het er dus weer uithaalt).
Snappie? :)
TangLeFuzZ: ik krijg nog steeds een internal server error, bij wat ik ook gebruik.
Welke OS (Windows gok ik), welke versie van Apache, stukje van je httpd.conf en/of .htaccess?
  • mavink
Op woensdag 10 januari 2001 19:24 schreef TangLeFuzZ- het volgende:
Kijk eens in je error log van apache, daar staat ongetwijfeld meer info. Als je er dan nog niet uitkomt moet je die maar eens posten.
  • Rense Klinkenberg
Hé TangLeFuzZ- het is mij nu ook eindelijk gelukt :):):)
ik heb dit .htaccess bestand in mijn /test/ dir:
RewriteEngine On
RewriteBase /test
RewriteRule ^(.*) /test/index.php?vandaag=on&zoek=$1
in mijn httpd.conf heb ik het volgende:
    AllowOverride All
    Order allow,deny
    Allow from all
</Directory>
en de belangerijkste wijziging in http.conf:
verander #LoadModule rewrite_module modules/ApacheModuleRewrite.dll in LoadModule rewrite_module modules/ApacheModuleRewrite.dll oftewel haal het # ervoor weg.
Maak in de /test/ dit effe index.php aan het phpinfo(); erin.
Dan effe Apache restarten. En kijk een op: [url="http://localhost/test/parameter"]localhost/test/parameter[/url]
Bij mij werkt het in ieder geval wel
* Rense Klinkenberg is nu erg blij en kan eidelijk slapen [img=15,15]i&#047;s&#047;smile.gif[/img]
thnx freak, ik ga het uitproberen.....
het probleem is dat het hier niet om m''n eigen pc gaat, m''n site wordt door nxs gehost.
Ik kan dus niet apache herstarten.
De server daar draait op unix d8 ik......
Op donderdag 11 januari 2001 00:02 schreef Arien het volgende:
Snappie? :)
iek snap :D
Maar op phpbuilder heb ik eens een artikel gelezen wat anders te werk ging (volgens een andere methode) en volgens mij kan het dan wel (maar hou me ten goede)
Mas*Mind: Op phpbuilder heb ik eens een artikel gelezen wat anders te werk ging
Hij doet ongeveer hetzelfde als ik het zo vlug zie:
PHP:
$url_array=explode("/",$REQUEST_URI);
$url_affil_num=$url_array[2];
$url_country=$url_array[3];
$url_state=$url_array[4];
$url_alpha_state=$url_array[5];
$url_zip=$url_array[6];
$url_content=$url_array[7];
Alleen vergeet hij dat het makkelijker kan als je gewoon MultiViews en PATH_INFO gebruikt. :P Namelijk zo:
PHP:
list(
  $url_affil_num, $url_country, $url_state,
  $url_alpha_state, $url_zip, $url_content
En als je het met zijn configuratie wil doen even aanpassen met REQUEST_URI en goede velden pakken. Het is hetzelfde idee.
  • Rense Klinkenberg
Op donderdag 11 januari 2001 09:42 schreef Arien het volgende:
dat is ook het verschil niet.
het gaat om het stukje in het httpd.conf bestand. hij gebruikt:
<Location /local>
ForceType application/x-httpd-php3
</Location>
freak007: Het gaat om het stukje in het httpd.conf bestand. hij gebruikt:
[code]<Location /local>
</Location>[/code]
Ja dat zag ik en hij vist zijn data uit REQUEST_URI. Voor wat betreft PHP dus een pot nat.
Het kan met mod_rewrite (beetje overkill), met MultiViews, met ForceType... Maar vervolgens heb je een URL en dan? Dat was de vraag. :)
Op woensdag 10 januari 2001 15:11 schreef Arien het volgende:
PHP:
list($id, $var2, $var3) = explode("/", substr($PATH_INFO,1));
Werkt,
maar als ik nu geen id invul, (dus gewoon index.php aanvraag en niet index.php/123), dan bestaat $id toch op een of andere manier, want dit werkt niet meer:
if (!isset($id)) {
echo "blaat";
hoe los ik dit op dan?
  • WouZz
WouZz
Elvis is alive!
Gebruik de empty() functie ipv isset()
Die geeft ook true als de variabele 0 is...
/edit: foutje :D
On track
een nadeel is wel dat die nepdir dan als een echt dir wordt gezien door de server,
als ik namelijk in m''n script een bepaalde andere file link, bijv index2.php, en die link staat in:
index.php/1
dan wil hij die index2.php zo aanroepen:
index.php/1/index2.php
in plaats van gewoon index2.php
TangLeFuzZ: een nadeel is wel dat die nepdir dan als een echt dir wordt gezien door de server
Nee, door de browser.
Oplossing is het gebruiken van absolute paden dus /pad/naar/pagina.
  • Jelle Niemantsverdriet
  • Laatst online: 11:54
Of een BASE HREF= definieren
door de browser, dat bedoel ik :)
het kan ook door gewoon / voor elke file te zetten kwam ik achter......
het kan niet met base href!!
  • Rense Klinkenberg
Ik heb daarvoor gewoon bovenaan staat:
PHP:
$serverpath = "http://www.blaat.blaat/";
en overal waar een linkje wordt gemaakt, gebruik ik die variabele weer.
Dus niet meer met relatieve paden, maar absolute werken.
Ik ben er ook de hele tjid aan bezig geweest om het aan de praat te krijgen alleen is het me gelukt om van [url="http://localhost/index.php"]http://localhost/index.php[/url] naar [url="http://localhost/index/"]http://localhost/index/[/url] te veranderen en dat hij dan dat als .php bestand ziet, alleen hoe doe je het nu met die variabelen? Misschien zouden jullie me even kunnen helpen ik kwam hier niet zo uit dit topic heb het wel gelezen. Misschien zou iemand heel eventjes een klein stappenschema neer kunnen zetten waarin staat wat allemaal gedaan moet worden om het dan met variabelen zoals [url="http://localhost/index.php?foo=bar"]http://localhost/index.php?foo=bar[/url] maar [url="http://localhost/index/foo/bar"]http://localhost/index/foo/bar[/url] te zien krijg.
Hopelijk kan iemand me even helpen, in ieder geval alvast bedankt
kammetje: Hoe doe je het nu met die variabelen? Misschien zou iemand heel eventjes een klein stappenschema neer kunnen zetten waarin staat wat allemaal gedaan moet worden om het dan met variabelen zoals [url="http://localhost/index.php?foo=bar"]http://localhost/index.php?foo=bar[/url] maar [url="http://localhost/index/foo/bar"]http://localhost/index/foo/bar[/url] te zien krijg.
Als je (zoals ik hier boven al schreef) explode() gebruikt om je $PATH_INFO te ontleden dan zet je alleen de waarden in je URL.
wordt dan dus
http://localhost/index/bar
en het is aan je script om de volgorde van je variabelen bij te houden.
nog ff over dat multiviews he,
onder windows moest je php4win installeren zag ik,
maar hoe zit ''t met freebsd?
Op dinsdag 09 januari 2001 11:05 schreef [nielsonline] het volgende:
index/bla/hallo
dikke onzin :?
Weet iemand een degelijke oplossing waarbij er gebruik wordt gemaakt van Win2000/IIS5.0 met daarop PHP?
  • chem
chem
Op woensdag 02 mei 2001 11:27 schreef berend het volgende:
linux installeren?
Hey... Als ik het voor het zeggen had... :) Dus graag een oplossing voor bovenstaande situatie.
  • Rense Klinkenberg
berend: Weet iemand een degelijke oplossing waarbij er gebruik wordt gemaakt van Win2000/IIS5.0 met daarop PHP?
Kijk effe naar de 2e post: Dat heet MultiViews en is iets van Apache.
Maar onder IIS is err wel iets voor, moet je effe zoeken, want die heb ik toen ook hiet op GoT gevonden.
Ik zoek me wezenloos. Ik heb wel eens een DLL''tje gezien die zoiets deed, maar kan dat absoluut niet meer vinden.
Wie heeft er wat voor IIS?
  • brammetje
  • Laatst online: 12-01-2025
gewoon ff apache installen?
Yes, I know :?
Maar dat vroeg ik niet
Uiteindelijk toch zelf wat gevonden. Wellicht dat er meerdere mensen zijn die met dezelfde situatie als ik zitten?
Hier dus de link: http://www.pstruh.cz/help/urlrepl/library.htm
Niet zo elegant als de oplossing bij Apache, maar het is in ieder geval iets.
  • BC3 Victim
  • Laatst online: 29-09-2006
als ik tjetta.nl/test/bla doe, dan gebruikt hij inderdaad test.php
maar hoe doe ik dat met indexfile zonder tjetta.nl/index/bla te doen? dus gewoon tjetta.nl/bla? (en dat hij dan index.php gebruikt)
  • ACM
ACM
Software Architect
Werkt hier
Op woensdag 23 mei 2001 22:15 schreef tjetta het volgende:
Dat zul je met een lastige RewriteRule moeten doen...
Zie mijn eigen reply in mijn code library thread.
  • BC3 Victim
daar ben ik al 4 uur mee bezig geweest maar het lukt niet :D
[weer edit]
Ik wil het liever gewoon met multiviews doen en niet met rewriterule, omdat me dat uiteindelijk toch steeds niet lukt. tenzij jij (of iemand anders) me ff wil helpen (contact me dan maar op icq of tjetta@ircnet ;)
[/weer edit]
