Vraag voor Linux/PPP guru
  • 319 views sinds 30-01-2008
  • Muyz
  • Laatst online: 06-09 21:22
Hoi,
Heb gisteren SuSE 6.4 geinstalleerd. Kan niet inbellen. Modem belt wel, maar hangt na userid/password check op. Zowel met wvdial als met kppp lukt het inbellen niet :( Hieronder een relevant stuk uit /var/log/messages. Iemand een idee?
Thanx,
Muyz
May 22 21:52:23 linux pppd[589]: pppd 2.3.11 started by root, uid 0
May 22 21:52:23 linux pppd[589]: Perms of /dev/ttyS0 are ok, no 'mesg n' neccesary.
May 22 21:52:23 linux pppd[589]: Using interface ppp0
May 22 21:52:23 linux pppd[589]: Connect: ppp0 <--> /dev/ttyS0
May 22 21:52:23 linux pppd[589]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xe6506991> <pcomp> <accomp>]
May 22 21:52:23 linux pppd[589]: rcvd [LCP ConfReq id=0x1 <mru 1500> <asyncmap 0xa0000> <auth pap> <magic 0xfb5fc4be> <pcomp> <accomp>]
May 22 21:52:23 linux pppd[589]: sent [LCP ConfAck id=0x1 <mru 1500> <asyncmap 0xa0000> <auth pap> <magic 0xfb5fc4be> <pcomp> <accomp>]
May 22 21:52:23 linux pppd[589]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xe6506991> <pcomp> <accomp>]
May 22 21:52:23 linux pppd[589]: sent [LCP EchoReq id=0x0 magic=0xe6506991]
May 22 21:52:23 linux pppd[589]: sent [PAP AuthReq id=0x1 user="XXXXXXXXXXXX" password=<hidden>]
May 22 21:52:23 linux pppd[589]: rcvd [LCP EchoRep id=0x0 magic=0xfb5fc4be]
May 22 21:52:23 linux pppd[589]: rcvd [PAP AuthAck id=0x1 ""]
May 22 21:52:23 linux pppd[589]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <compress VJ 0f 01>]
May 22 21:52:23 linux pppd[589]: sent [CCP ConfReq id=0x1 <deflate 15> <deflate(old#) 15> <bsd v1 15>]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP ConfReq id=0x1]
May 22 21:52:24 linux pppd[589]: sent [IPCP ConfNak id=0x1 <addr 0.0.0.0>]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>]
May 22 21:52:24 linux pppd[589]: sent [IPCP ConfReq id=0x2 <addr 0.0.0.0>]
May 22 21:52:24 linux pppd[589]: rcvd [CCP ConfReq id=0x1 < 12 06 00 00 00 01>]
May 22 21:52:24 linux pppd[589]: sent [CCP ConfRej id=0x1 < 12 06 00 00 00 01>]
May 22 21:52:24 linux pppd[589]: rcvd [CCP ConfRej id=0x1 <deflate 15> <deflate(old#) 15> <bsd v1 15>]
May 22 21:52:24 linux pppd[589]: sent [CCP ConfReq id=0x2]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP ConfReq id=0x2]
May 22 21:52:24 linux pppd[589]: sent [IPCP ConfAck id=0x2]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP ConfNak id=0x2 <addr 212.189.210.158>]
May 22 21:52:24 linux pppd[589]: sent [IPCP ConfReq id=0x3 <addr 212.189.210.158>]
May 22 21:52:24 linux pppd[589]: rcvd [CCP ConfReq id=0x2 < 11 05 00 01 04>]
May 22 21:52:24 linux pppd[589]: sent [CCP ConfRej id=0x2 < 11 05 00 01 04>]
May 22 21:52:24 linux pppd[589]: rcvd [CCP ConfAck id=0x2]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP ConfAck id=0x3 <addr 212.189.210.158>]
May 22 21:52:24 linux pppd[589]: Could not determine remote IP address
May 22 21:52:24 linux pppd[589]: sent [IPCP TermReq id=0x4 "Could not determine remote IP address"]
May 22 21:52:24 linux pppd[589]: rcvd [CCP ConfReq id=0x3 < 11 05 00 01 03>]
May 22 21:52:24 linux pppd[589]: sent [CCP ConfRej id=0x3 < 11 05 00 01 03>]
May 22 21:52:24 linux pppd[589]: rcvd [IPCP TermAck id=0x4]
May 22 21:52:24 linux pppd[589]: sent [LCP TermReq id=0x2 "No network protocols running"]
May 22 21:52:24 linux pppd[589]: rcvd [CCP TermReq id=0x1]
May 22 21:52:24 linux pppd[589]: rcvd [LCP TermAck id=0x2]
May 22 21:52:24 linux pppd[589]: Connection terminated.
May 22 21:52:24 linux pppd[589]: Connect time 0.1 minutes.
May 22 21:52:24 linux pppd[589]: Sent 280 bytes, received 277 bytes.
May 22 21:52:24 linux pppd[589]: Exit.
Zo te zien weet je machientje het ip adres van je server niet. Mijn ISP is wanadoo.
In /etc/resolv.conf moet zoiets staan als:
search wanadoo.nl
nameserver 195.96.96.97
nameserver 195.96.96.33
Ik ben vandaag begonnen met het modemgedoe,
dus ik ben ook geen expert. Maar ... het werkt wel al bij mij. Tenminste ik kan surfen. Nu de mail nog.
succes,
Z.
  • Neo_2000
  • Laatst online: 06-06-2024
Volgens mij valt dit onder Non-Windows Operating Systems of niet?
  • PolarBear
Op dinsdag 28 augustus 2001 18:24 schreef Neo_2000 het volgende:
Op maandag 22 mei 2000 22:03 schreef Muyz het volgende:
Hoi,<P>Heb gisteren SuSE 6.4 geinstalleerd.
SuSE Linux Mja
  • Arno
  • Laatst online: 09-09 21:44
Arno
PF5A
--> [forum=23] <--
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
