[BC3] Temprature Bay
laat maar, krijg het niet voor elkaar,
http://www.3dcool.com/prodimg/temperaturebay-1.jpg
is dit wat ??
The Temperature Bay is an idea that came from wanting to monitor temperatures, but without those overpriced DigitalDocs and still in a 5.25" bay. The result of our work comes the Temperature Bay -- Fits in a 5.25" bay, and has two temperature monitors on the bay panel. Each temperature monitor has a 36" long temperature probe on them so you can place them in the case anywhere your heart desires. Since we had the room too, we also made some room for fans or a hard drive. You can fit 1 or 2 80x80mm fans in the 5.25" tray, or you can place one hard drive in the tray. The choices are yours!
The front temperature monitors require no additional power source. They are powered by a watch battery which should last a very long time, and are about $0.25 each to replace after a few years of use. This way there are no power cables to mess with and the monitors are self-contained. The Temperature Bay comes exactly as you see pictured, there is no assembly required except you must snap the faceplate onto the tray which takes under 3 seconds to do. We also include stickers so you can label which monitor is monitoring what
ja lijkt me een kewl ding
ey asl je daar gaat bestellen meld dan ff ik wil ook wat bestellen kunnen we versend kosten delen snappie :P
yups is koud
[edit]typo''s[/edit
  • Renkie
  • Laatst online: 19-09 21:19
als je gaat bestellen mail me dan aub -> renkie@gamepoint.net
ik wil ook wel zo''n ding hebben en dan kunnen we de verzendkosten etc delen
  • Cereal
  • Laatst online: 25-08 23:01
wat kost ie?
  • aP_
  • Laatst online: 16-09 14:41
aP_
Het is lastig om je specs up to date te houden
21 dollar ga je daar toch niet voor neertellen...
Volgens mij moeten jullie tweakers dat best zelf kunnen maken :))
Mzl
  • Potatoman
  • Laatst online: 20-09 20:01
Potatoman
koniwa
Idd zo''n los temperatuurmeetapparaatje kost ibj de conrad veel minder en plak je zo ff in een compuslotje...
Ga ik ook doen :) heb al spul besteld.
The cyclographing developer
maarja voor $21 heb je wel een mooi afgewerkt geheelin je comp
