[BC3] yamaha cdr400t brand niet goed onder nero
Mijn cdr400t kapt steeds met brander ik heb hier de log van nero maar neergezetw ant weet nietw at het probleem is. wie kan er wijs uit worden wat het probleem is en wat is de oplossing ervoor :)
Windows NT 5.0
WinAspi: File ''Wnaspi32.dll'': Ver=4.57 (1009), size=48128 bytes, created 5-3-1998 1:16:56
ahead WinASPI: File ''C:\Program Files\ahead\Nero\Wnaspi32.dll'': Ver=2.0.1.16, size=151619 bytes, created 9-5-2001 22:16:46
Nero Version: 5.0.4.8
Recorder: <YAMAHA CDR400t> Version: 1.0q - HA 2 TA 5 - 5.0.4.8
Adapter driver: <aic78xx> HA 2
Drive buffer : 2048kB
CD-ROM: <TOSHIBA CD-ROM XM-6201TA>Version: 1030 - HA 2 TA 4 - 5.0.4.8
TOSHIBA CD-ROM XM-6201TA1030 aic78xx Port 2 ID 4 DMA: ?
YAMAHA CDR400t 1.0q aic78xx Port 2 ID 5 DMA: ?
AutoRun : 0
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523824kB)
Free physical memory: 333MB (341284kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-Image
10.5.2001
14:08:24#1 Text 0 File Reader.cpp, Line 116
Reader running
14:08:24#2 Text 0 File Writer.cpp, Line 108
Writer YAMAHA CDR400t running
14:08:25#3 Text 0 File ThreadedTransferInterface.cpp, Line 644
Setup items (original item values)
0: TRM_DATA_MODE1 (Joliet)
2 indices, index0 (150) not provided
original CD pos #0 + 328378 (328378) = #328378/72:58.28
relocatable, CD pos for caching/writing not required/not required, patch infos
14:08:25#4 SCSI -1033 File Cdrdrv.cpp, Line 1140
SCSI Exec, HA 2, TA 5, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x1B 0x01 0x00 0x00 0x02 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x04 0x01
14:08:25#5 mmc -1033 File Burncd.cpp, Line 1212
Drive not ready
14:08:55#6 Text 0 File Burncd.cpp, Line 1661
Recorder: YAMAHA CDR400t;
CDR code: 00 97 33 00; CD manufacturer unknown
ATIP Data:
Special Info [hex] 1: D0 00 80, 2: 61 21 00 (LI 97:33.00), 3: 4A 1E 00 (LO 74:30.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:08:55#7 Text 0 File ThreadedTransferInterface.cpp, Line 778
Prepare recorder YAMAHA CDR400t for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 672825344
14:08:55#8 Text 0 File ThreadedTransferInterface.cpp, Line 806
Removed 2 run-out blocks from end of track 1.
14:08:55#9 Text 0 File ThreadedTransferInterface.cpp, Line 644
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 328376 blocks [YAMAHA CDR400t]
14:08:55#10 Phase 32 File dlgbrnst.cpp, Line 1193
Start of simulation at 4x (600 KB/s)
14:08:55#11 Text 0 File ThreadedTransferInterface.cpp, Line 1765
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
14:16:35#12 SCSI -1039 File Cdrdrv.cpp, Line 1351
SCSI Exec, HA 2, TA 5, LUN 0, buffer 0x08BF9378
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x02 0x03 0x28 0x00 0x00 0x1E 0x00
Sense Data: 0x70 0x00 0x04 0xD1 0xC0 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x09 0x01
14:16:35#13 mmc -1039 File Writer.cpp, Line 284
Focus or tracking error
14:16:36#14 Text 0 File ThreadedTransfer.cpp, Line 216
all writers idle, stopping conversion
14:16:36#15 Text 0 File ThreadedTransfer.cpp, Line 210
conversion idle, stopping reader
14:16:36#16 CDR -201 File WriterStatus.cpp, Line 114
Invalid writestate
14:16:36#17 TRANSFER -18 File WriterStatus.cpp, Line 114
Could not perform EndTrack
14:16:36#18 Phase 34 File dlgbrnst.cpp, Line 1193
Simulation failed at 4x (600 KB/s)
14:16:36#19 Text 0 File Scsicmd.cpp, Line 311
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File ''Drivers\SCSIPWR.SYS'': Ver=4.01b (1000), size=19904 bytes, created 20-2-1997 19:12:34
File ''Drivers\ASPI32.SYS'': Ver=4.57 (1009), size=23968 bytes, created 4-3-1998 23:53:28
  • Toewan
  • Laatst online: 29-07 19:17
Het vreemde is, ik heb zo''n zelfde brander gehad, en ik heb Nero niet vaak gebruikt, ik was helemaal aan de Adaptec EZ cd creator.
Nu heb ik een Plextor 12x, en nu is het Nero all the way.
Maar om even ontopic te komen, ik heb het probleem niet gehad met die enkele keer dat ik met Nero heb gebrand. Wat doet ie met andere programma''s ?? (WinonCD, EZ cd creator ??)
