[BC3] Verschil in Maxtor hardeschijf.....???
  • BC3 Victim
  • Laatst online: 29-09-2006
Dag mensen kort vraagje; Wat is het verschil tussen de:
-Maxtor 30GB (DMax 45 Plus, 7200rpm) en de
-Maxtor 30GB (DMax 60 Plus, 7200rpm)
Heeft iemand nog andere sugesties onder de f400,- (ps. zoek een snelle!!)
Bedankt! :)
:) zoek de verschillen
>:) 45-serie:
PERFORMANCE:
Seek Performance (including settling time and servo overhead)
Seek Times (Typical):
Track to track: ....................... 1.0 ms
Average: .............................. 8.7 ms
Maximum: .............................. <20.0 ms
Average Latency: ........................... 4.17 ms
Rotational Speed (+-0.1%): ................. 7,200 RPM
Controller Overhead: ....................... <0.3 ms
Start Time (0 - Drive Ready) ............... 8.5 sec
DATA TRANSFER RATE:
To/From Interface (UDMA/66): ............. Up to 100 MB/Sec
To/From Media: ........................... Up to 49.5 MB/Sec
DRIVE CONFIGURATION:
Integrated Controller/Interface: ........... Ultra ATA/100
Buffer Size: ............................... 2 MB
Buffer Type: ............................... SDRAM
Data Zones per Surface: .................... 16
Bytes per Sector/Block: .................... 512
Reliability Specifiacations
Annual Return Rate: ................ < 1.0 %
Start/Stop Cycles: ................. 50,000 (minimum)
Component Design Life: ............. 5 years (minimum)
Data Errors (non-recoverable) ...... <10 per 10^15 bits read
POWER REQUIREMENTS (Average)
Mode +12VDC+-10% +5VDC +-5% Power
Spin-up (peak) 2500 mA 620 mA
Seek 800 mA 510 mA 12.9 W
Read/Write 525 mA 515 mA <9.0 W
Idle 350 mA 490 mA <6.6 W
Standby 30 mA 270 mA <1.75 W
ENVIRONMENTAL:
Temperature
Operating (stabilized)............. 5 C to 55 C
Non-operating/Storage ............. -40 C to 71 C
Relative Humidity (Non-Condensing)
Operating, Non-operating/Storage .. 5% to 95%
Wet Bulb .......................... 30 C Maximum
Altitude (relative to sea level)
Operating ......................... -200 to 10,000''
Non-operating ..................... -200 to 40,000''
Shock & Vibration (typical)
Operating, Random ........ 10-45 Hz @ 0.004 G2/Hz
48-62 Hz @ 0.008 G2/Hz
65-300 Hz @ 0.004 G2/Hz
301-500 Hz @ 0.0006 G2/Hz
(no errors)
Non-Operating
Mechanical Shock ......... 10-2,000 Hz @ 2.15 Grms
(no damage)
Operating, swept sine (1 octave/minute)
10-300 Hz ..................... 1.0 Peak Amplitude
SHOCK:
Operating Mechanical Shock ........... 30 Gs, 2 ms
(no errors)*
Non-Operating Mechanical Shock ...... 250 Gs, 2 ms
(no damage)*
* Without non-recoverable errors
ACOUSTICS:
Idle Mode ..................... 3.3 bel
(avg. sound power)
PHYSICAL:
Height: 1.02 in 2.61 cm
Length: 5.78 in 14.70 cm
Width: 4.02 in 10.21 cm
Weight: 1.30 lb. 0.59 kg
>:) 60-serie:
PERFORMANCE:
Start Time (0 - Drive Ready) ............... <8.5 sec
DATA TRANSFER RATE:
To/From Interface (UDMA/100): ............ Up to 100.0 MBs
To/From Media: ........................... Up to 57.0 MBs
Integrated Controller/Interface: ........... uLTRA ATA-100
Data Errors (non-recoverable) ...... <1 per 10^15 bits read
Spin-up (peak) 2950 mA 430 mA 41.2 w
Seek 550 mA 510 mA 9.5 W
Read/Write 600 mA 550 mA 10.0 W
Idle 350 mA 500 mA 6.7 W
Standby 30 mA 150 mA 1.2 W
ENVIRONMENTAL:
Temperature
(no errors)
Non-Operating
(no damage)
Operating, swept sine (.25 octave/minute)
SHOCK:
(no errors)*
Non-Operating Mechanical Shock ...... 300 Gs, 2 ms
(no damage)*
ACOUSTICS:
(avg. sound power)
PHYSICAL:
  • Vrieskist
  • Laatst online: 03-04 09:28
looks the same :)
  • BC3 Victim
Bedankt???..ha ha..maar euh..welke zou jij mij aanraden?
...nogmaals bedankt!! >:)
tja echt veel verschil zit er ook nie in volgens mij, maar verschil nog wel in data transfer rate, maar verder zie ik zo ook nie echt iets opvallends..
[edit modus]
ik denk dat je de 60-serie moet pakken die heeft een hoger transfer rate, is wel belangrijk denk ik ?, maar ik kan er ook naast zitten
[/edit modus]
Die transfer rate verschilt niet zo gek veel. Ze zijn allebei van Maxtor, 7200rpm en U-ATA/100.
Ik zou voor de 40 gaan, die is stiller (uit eigen ervaring >:)), dus die heb ik zelf
  • bartvb
  • Laatst online: 14:56
Verschil is de datadensity op de platters. De 60 serie heeft een hogere density (dus meer bits per oppervlakte-eenheid). Hierdoor komen er meer bits voorbij per omwenteling (en dus hogere transferrate)..
Als ze even duur zijn zou ik de 60 pakken dus..
  • Abbadon
  • Laatst online: 15:46
De 60 serie is de snelste. Bij disken gaat het niet alleen om maximale doorvoer maar tellen meerdere zaken. Eigenlijk is de 60 serie de eerste Maxtor die goed presteerd op álle benchmarks, de vorige series waren ook snel maar lagen op enkele onderdelen merkbaar achter. (overigens heeft de 60 20GB platters en de 45 heeft 15GB platters)
  • BoNeZ99
  • Laatst online: 09-09 16:07
ik heb de 40+ en die loopt perfect, np!
Ga, zoals Abaddon mij laatst ook al zei (bedankt nog :) ), idd maar voor de 60 serie. Ik heb ze alletwee, een 20 gig max40 (de 52049H4 ofzo) en een 20 gig max60 (de 5T020H2) . De 60 is idd een stuk sneller in sisoft sandra. Met de max40 haal ik een score van 19500, en met de max60 een score van 24960.
Eentje uit de diamond max60 plus serie nemen, dus :)
Suc6
  • BC3 Victim
Mensen bedankt voor jullie steun het lijkt me wel duidelijk welke ik dan maar moet nemen de 60+ dus *D
thanks again!!
