[BC3] scsi vraagje
wie verteld mij of dit een goede combinatie is en kan dit
adaptec AHA-2944UW
segate Cheetah ST39102LW 9GB
  • Snuffel
  • Laatst online: 20:16
Snuffel
Vroem!
MANUFACTURER PART# ST39102LW
FORM FACTOR 3.5 inch
INTERFACE Wide Ultra2 SCSI (Low Voltage Differential)
or Ultra Wide SCSI
(drive has dual transceivers and will automatically detect which interface it is operating on and will turn off the appropriate transceiver)
FORMATTED CAPACITY 9.1GB
AVERAGE SEEK TIME 5.4/6.2ms
DATA TRANSFER RATE Wide Ultra2 SCSI 80 MB/sec (sync)
Ultra Wide SCSI 40 MB/sec (sync)
SPINDLE SPEED 10,033 RPM
BUFFER 1024KB
PROJECTED FIELD MTBF 1,000,000 Hours
WARRANTY 5 year manufacturer''s
En dat op een UW controller: moet goed werken :)
You have to be careful if you don't know where you are going because you might not get there...
Op woensdag 18 april 2001 17:03 schreef Snuffel het volgende:
or Ultra Wide SCSI
BUFFER 1024KB
Ik las dit net maakt dit uit
Reliable connections for High Voltage Differential (HVD) SCSI devices and storage systems
AHA-2944UW Technical Specifications
Product Specifications
Why to buy
Customer Needs
Extended cable lengths for external HVD Ultra Wide SCSI Devices
System Environment
For Servers
Data Transfer Rate
Up to 40MB/sec
External Connectors
68-pin High-Density (for Ultra Wide SCSI)
Internal Connectors
50-pin standard (Ultra SCSI) and 68-pin high-density (Ultra-Wide SCSI)
Bus Type
32-bit PCI
System Requirements
Intel PC or equivalent with available PCI slot
Package Contents
AHA-2944UW PCI-to-SCSI host adapter
Adaptec EZ-SCSI Software (CD-ROM version)
Easy CD Creator Lite software
Installation and user''s guides
Warranty card
Registration card
Warranty
5-year manufacturing and materials warranty
General Specifications
Peripheral Support
15 High Voltage Differential Peripherals
Electrical Drivers
High Voltage Differential, active, programmable via SCSISelect configuration utility
Electrical and Mechanical Specifications
Board Dimensions
6.87" x 3.87"
MTBF (mean time between failures, Bellcore)
411,093
  • mvdejong
  • Laatst online: 29-11-2024
mvdejong
When does the hurting stop ?
Ik heb haast spijt van mijn antwoord op de andere post, vuile dubbel-poster !
The number of things that Arthur couldn't believe he was seeing was fairly large
  • bugs
  • Laatst online: 18-06-2024
bugs
www.bugs.nl
Ik ken die kaart. Die is onbruikbaar voor dit soort schijven en kan deze zelfs beschadigen!
De kaart is High Voltage Diferential. De schijf is Low Voltage Diferential. Dat gaat dus fout!
Ik ben bang dat HVD niet veel voorkomt. Het werd vooral in externe schijfcylo''s gebruikt. Ik denk dat het tegenwoording niet meer veel voor komt.
Celeron(cd0) 1000@1000,1.80V ASUS P2B-S Rev 1.03 BIOS 1014 beta 1a, 256@222,100Mhz/AMD k6-III+ 450@550,2.0V ASUS P5A-B rev 1.03 BIOS 1010, 256Mb@222,100Mhz
  • Bulldog
Verplaatst van Hardware Algemeen naar het Opslagmedia & I/O Controllers forum.
