[BC3] ???? What is SCSI ????
  • 103 views sinds 30-01-2008
sorry dat ik jullie stoor met deze vraag.
wie kan mijn het
wie, wat, waar, wanneer, hoezo en waarom over en van SCSI vertellen.
en wat zijn er de voordelen en nadelen van?
  • Bulldog
Ik quote een stukje van www.whatis.com
SCSI
See our comparison table for SCSI-1, SCSI-2, Fast SCSI-2, Wide SCSI-2, Fast Wide SCSI-2, Ultra SCSI-3 8-bit, Ultra SCSI-3 16-bit, Ultra-2 SCSI, Wide Ultra-2 SCSI, and Ultra160/m.
SCSI (pronounced SKUH-zee and sometimes colloquially known as "scuzzy"), the Small Computer System Interface, is a set of evolving ANSI standard electronic interfaces that allow personal computers to communicate with peripheral hardware such as disk drives, tape drives, CD-ROM drives, printers, and scanners faster and more flexibly than previous interfaces. Developed at Apple Computer and still used in the Macintosh, the present set of SCSIs are parallel interfaces. SCSI ports are built into most personal computers today and supported by all major operating systems.
In addition to faster data rates, SCSI is more flexible than earlier parallel data transfer interfaces. The latest SCSI standard, Ultra-2 SCSI for a 16-bit bus can transfer data at up to 80 megabytes per second (MBps). SCSI allows up to 7 or 15 devices (depending on the bus width) to be connected to a single SCSI port in daisy-chain fashion. This allows one circuit board or card to accommodate all the peripherals, rather than having a separate card for each device, making it an ideal interface for use with portable and notebook computers. A single host adapter, in the form of a PC Card, can serve as a SCSI interface for a "laptop," freeing up the parallel and serial ports for use with an external modem and printer while allowing other devices to be used in addition.
Although not all devices support all levels of SCSI, the evolving SCSI standards are generally backwards-compatible. That is, if you attach an older device to a newer computer with support for a later standard, the older device will work at the older and slower data rate.
The original SCSI, now known as SCSI-1, evolved into SCSI-2, known as "plain SCSI." as it became widely supported. SCSI-3 consists of a set of primary commands and additional specialized command sets to meet the needs of specific device types. The collection of SCSI-3 command sets is used not only for the SCSI-3 parallel interface but for additional parallel and serial protocols, including Fibre Channels, Serial Bus Protocol (used with the IEEE 1394 Firewire physical protocol), and the Serial Storage Protocol (SSP).
A widely implemented SCSI standard is Ultra-2 (sometimes spelled "Ultra2") which uses a 40 MHz clock rate to get maximum data transfer rates up to 80 MBps. It provides a longer possible cabling distance (up to 12 meters) by using Low Voltage Differential (LVD) signaling. Earlier forms of SCSIs use a single wire that ends in a terminator with a ground. Ultra-2 SCSI sends the signal over two wires with the data represented as the difference in voltage between the two wires. This allows support for longer cables. A low voltage differential reduces power requirements and manufacturing costs.
The latest SCSI standard is Ultra-3 (sometimes spelled "Ultra3")which increases the maximum burst rate from 80 Mbps to 160 Mbps by being able to operate at the full clock rate rather than the half-clock rate of Ultra-2. The standard is also sometimes referred to as Ultra160/m. New disk drives supporting Ultra160/m will offer much faster data transfer rates. Ultra160/m also includes cyclical redundancy checking (CRC) for ensuring the integrity of transferred data and domain validation for testing the SCSI network.
Currently existing SCSI standards are summarized in the table here.
  • Speedy
  • Laatst online: 10:13
www.scsischool.com
leer je veel van.
Flickr | Lego collectie
bedankt jullie 2 ik begin ut te snappen
  • O.D.Smolik
  • Laatst online: 07-11-2025
O.D.Smolik
Geen dag, zonder een appel.
Hoe spreek je het uit dan??
Ik heb echt geen flauw idee.
Sorry, had beter moeten lezen|:(
  • Macros
  • Laatst online: 24-08 21:59
Macros
I'm watching...
Skoezie
"Beauty is the ultimate defence against complexity." David Gelernter
  • MP83
  • Laatst online: 31-01 18:11
Op woensdag 28 februari 2001 21:40 schreef TAG_Speedy het volgende:
www.scsischool.com
leer je veel van.
En het gave is: als je dat diploma haalt sturen ze het dus echt op ! Heb er hier 1 liggen...
  • Laurent
Op vrijdag 04 mei 2001 22:25 schreef Macros het volgende:
Skoezie
Eg nie
skoessie :P
Nee hoor
Es-Zee-Es-Ie :P
skoeszie >:)
  • Bigs
Even mijn HTML->UBB convertor uitproberen.. :)
SCSI is, as previously mentioned, is a type of interface for peripherals. Most modern SCSI devices are much speedier than their USB, FireWire, or IDE equivalents. But SCSI is not only beneficial for its speed, but also its much reduced dependence on the main CPU. For operations like CD Burning, this is a godsend. The number of coasters produced is much, much smaller when compared with an equivalent IDE or FireWire CD-R drive. And then Plextor introduced BurnProof technology. But still, if you like to watch a DVD or two while playing Unreal Tournament and record a 76 minute CD of Napster-ized songs in the background, SCSI is the way to go.
(dit komt trouwens van Everything)
  • JvdBosch
  • Laatst online: 13-09 21:09
SCSI>IDE in alle opzichten, behalve de prijs *D. Laat je niets anders wijsmaken!
e-Niro Runway Red met Smokey Grey interieur
  • _JGC_
SCSI kan 7 of 15 apparaten aan
IDE slechts 2
SCSI kan doubletailed zijn
IDE niet (hmm, wat ruikt er zo)
SCSI heeft last van storingen als er een slechte kabel gebruikt wordt of niet getermineerd wordt
IDE heeft nergens last van, behalve als je het heel erg bont maakt
SCSI is superduur
IDE is lekker goedkoop
  • FrankGuthrie
  • Laatst online: 09:24
FrankGuthrie
I Wanna Be Kate
Weet iemand een nederlandse versie van whatis.com???????
Russian Blue Neji
Kate Bush
Blue Horizon(a website about Star Trek & Babylon 5)
  • smvs
ga naar school man
enfin, bestaat er ook zoiets als Large Computer System Interface?
dat soort dingen vraag ik me dan af. interessante vind ik zelf.
  • Laurent
Op zaterdag 05 mei 2001 23:05 schreef FrankGuthrie het volgende:
www.watis.com :P
