Je printservertje is gemaakt speciaal om te werken met vorige Novell Netware versies:
Setting an RBL server for an XL or EL
For NetportExpressä XL and EL print servers only: The RBL server stores the Application Code that controls printing for the NetportExpress print server. You must assign an RBL server before you can completely configure a NetportExpress print server.
Notes
·The RBL server should be stable, and not separated from the NetportExpress print server by a Wide Area Link.
·To use a NetBIOS system for the RBL server, set up a shared directory on that system before configuring your print server. Do not set a password on the share.
To set an RBL server
1Select a NetportExpress XL or EL print server in the Netportâ Manager window.
2Click the Configure button and click Properties.
3Select a server type (Novell NDS*, Novell Bindery, or NetBIOS).
4Select a server.
For NDS: Browse to select a context and then a server.
For bindery: Select from the list of servers.
For NetBIOS: Browse to select a workgroup, name, and share. Specify a username.
Application Code
The code that controls printing for NetportExpressä print servers.
10, 10/100, PRO/100, and PRO print servers: The application code is stored in Flash memory. You can update the application code using the Update button in Netportâ Manager.
XL and EL print servers: The application code is stored on an RBL server. Netport Manager copies the Application Code to the RBL server when you set up an XL or EL. Each time the print server boots, it loads the Application Code. You can update the application code by copying a new file to the RBL server.
bron: help functie van Intel Netport Manager
|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
