[BC3] icq file sharing , van firewall naar firewall ?
Ik zit hier achtere een slackware 7.1 router/firewall en mijn vriendin idem bij haar thuis , nou was het geen probleem om files te sharen met mensen die achter een firewall zitten terwijl ik dat hier wel het gaval is. Maar als die andere persoon ook achter een firewall zit hoe moet ik icq dan instellen op beide comps ( nieuwste built icq 3279) zodat file sharing een non-issue word ? thanks !
  • CmdrKeen
  • Laatst online: 27-05 21:11
CmdrKeen
Krentenboltosti
http://http-tunnel.com
Hiermee wordt file-sharing via ICQ achter firewalls idd een non-issue. Quote:
HTTP-Tunnel & ICQProxy
The Firewall
Most corporate networks today are behind firewalls. The purpose of a firewall is to prevent unwanted users from having access to machines within a companies intranet. At the same time to allow people in the intranet to access the internet. Unfortunately due to security reasons, firewall administrators only allow certain applications to go through the firewall. Depending on how a firewall is set up, this restrictions prevents people from using internet applications such as ICQ, checking their POP/IMAP e-mal, PC Anywhere etc.
The Solution - ICQProxy
The founders of this company were determined to find a solution for this problem without compromising security the firewall provides and so they developed ICQProxy. ICQProxy is an application that runs in your system tray acting as an ICQ Server. ICQ sends data to the ICQProxy client running on the users desktop which then tunnels the data over HTTP to one of the free servers run my HTTP-Tunnel.com This server then sends that data to the real ICQ server. This forwarding mechanism allows people to use ICQ from behind a firewall.
Extending ICQProxy to all Internet applications - HTTP-Tunnel
The same technology used to re-route ICQ Packets can be applied to any internet application. This is HTTP-Tunnel. HTTP-Tunnel can now be used with any internet application!!
Bloed, zweet & koffie
dank , maar er staat ook bij dat het eventueel niet met icq 2000 zou werken , maar alleen met 99 ? kan je me daar ook iets meer over vertellen ? bvd
  • valkenier
  • Laatst online: 12:23
En als je nou gewoon icq en je firewall een beetje op elkaar aftstemt? ICQ een range van listening ports geven en deze mappen of over je vuurmuur. Dan moet het toch ook lukken?
  • CmdrKeen
CmdrKeen
Krentenboltosti
Darkman, wat dacht je ervan om eerst eens goed te l.e.z.e.n. voordat je een vraag stelt? Ik vind het niet erg hoor, maar de info die ik heb, haal ik ook van hun site af. Gewoon goed lezen dus.
Op de download-pagina van HTTP-proxy staat:
If you would like to use ICQ99b get:
ICQ Proxy BETA (with install and MFC DLL''s) 1.3 MB
ICQ Proxy BETA (without installation program) 23 KB
To use ANY application that supports SOCKS5 proxies get:
HTTP-Tunnel (with install and MFC DLL''s) 1.3MB
HTTP-Tunnel (without installation program) 45 KB
(supports SOCKS5, Napster, AIM, MSN, Yahoo and many more.. ICQ2000 may not work. Use ICQProxy if you have trouble using ICQ2000)
Je moet dus ICQProxy gebruiken.
Het werkt gewoon. (Zelf geprobeerd...)
