| To acknowledge what is known as known and what is not known as known is knowledge. |
Staat je document root goed in apache:
iets van:
DocumentRoot "/plek/van/je/html/files/"
en heeft die directory de goede rechten (drwxr-xr-x)?
Hoe heb je apache geinstalleerd? Via rpm of via de source?
Staat er niets in je errorlogs (standaard in /usr/local/apache/logs/error_log)?
iets van:
Heb de RPM install gedaan, en in de error log staat:
(2)No such file or directory: getpwuid: couldn''t determine user name from uid 4294967295, you probably need to modify the User directive.
Wat doe ik fout? en waar kan ik de user directive vinden?
