[BC3] Udp-packets zorgen voor verbinding (ongewild)
Ik heb sinds kort het volgende probleem: Mijn pc maakt uit zichzelf verbinding met mijn provider, nu ben ik mijn winroute-logs eens gaan nakijken (zie dial-log hieronder) en nu blijkt dat te komen doordat 192.168.1.1 (de pc waarop ik werk, en winrouteserver pc) een UDP packet stuurt naar 192.16.202.11 . Wat is zo''n udp-packet en hoe kan ik voorkomen dat mijn pc die dingen blijft versturen en dus voor onnodige kosten zorgt?
[26/May/2001 14:36:43] ISDN (Demon): successfuly connected
[26/May/2001 14:41:03] ISDN (Demon): disconnected, connection time 00:04:20
[26/May/2001 14:41:38] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:42:25] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:42:29] ISDN (Demon): successfuly connected
[26/May/2001 14:46:35] ISDN (Demon): disconnected, connection time 00:04:06
[26/May/2001 14:46:38] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:47:25] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:47:29] ISDN (Demon): successfuly connected
[26/May/2001 14:50:22] ISDN (Demon): disconnected, connection time 00:02:53
[26/May/2001 14:51:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:51:42] ISDN (Demon): successfuly connected
[26/May/2001 14:54:02] ISDN (Demon): disconnected, connection time 00:02:20
[26/May/2001 14:56:38] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 14:56:42] ISDN (Demon): successfuly connected
[26/May/2001 15:19:02] ISDN (Demon): disconnected, connection time 00:22:20
[26/May/2001 15:21:42] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 15:21:46] ISDN (Demon): successfuly connected
[26/May/2001 15:26:11] ISDN (Demon): disconnected, connection time 00:04:25
[26/May/2001 15:26:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 15:26:42] ISDN (Demon): successfuly connected
[26/May/2001 15:57:39] ISDN (Demon): disconnected, connection time 00:30:57
[26/May/2001 16:01:36] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 16:01:41] ISDN (Demon): successfuly connected
[26/May/2001 16:05:57] ISDN (Demon): disconnected, connection time 00:04:16
[26/May/2001 16:06:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 16:06:42] ISDN (Demon): successfuly connected
[26/May/2001 16:11:04] ISDN (Demon): disconnected, connection time 00:04:22
[26/May/2001 16:11:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 16:11:41] ISDN (Demon): successfuly connected
[26/May/2001 16:15:59] ISDN (Demon): disconnected, connection time 00:04:18
[26/May/2001 16:16:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 16:16:42] ISDN (Demon): successfuly connected
[26/May/2001 16:21:00] ISDN (Demon): disconnected, connection time 00:04:18
[26/May/2001 16:21:37] UDP packet 192.168.1.1:53 -> 192.16.202.11:53 initiated dialing
[26/May/2001 16:21:40] ISDN (Demon): successfuly connected
[26/May/2001 16:24:03] ISDN (Demon): disconnected, connection time 00:02:23
  • ElbY
  • Laatst online: 09-09 14:34
Lijkt erop dat jouw lokale DNS settings niet helemaal in orde zijn.
Port 53 is voor DNS verkeer en IP adres 192.16.202.11 is gezien de naamgeving een DNS-server (ns.EU.net).
  • Steven
  • Laatst online: 08-09 20:16
Ik zou zowiezo automatisch dialen niet aan zetten.. Gewoon iedereen handmatig laten inbellen via die mini-webserver di ein Winroute zit. Ik ben vergeten op welke poort..
Hoe zou ik dat moeten instellen? Als je een URL of iets dergelijks hebt, graag!
  • ElbY
Een link heb ik niet. Je zal het toch allemaal zelf moeten nagaan of alles juist staat. Reken erop dat het gaat om een configuratiefout. Enkel DNS-request mag geen reden zijn om de lijn open te gooien.
Misschien dat onderstaand je verder helpt met het oplossen van je fout.
- In eerste instantie uitsluiten dat van een ander werkstation komt. Dit is nogsteeds mogelijk aangezien je aan het routeren bent en dat je WinRoute machine als gateway heb.
Uitsluiten kun je door de andere machines uit te laten en bijhouden of er uitgebeld wordt op ISDN basis.
- RTFM, Grote kans dat er in de handleiding van WinRoute meer info in staat met het instellen van DNS-settings. Waar moet je de DNS-servers van je provider neerzetten en wanneer je een caching DNS draai, je eigen IP-adres van je WinRoute machine (ik weet niet of WinRoute aan caching-DNS doet).
- Kijk uberhaupt of je geen tikfouten heb gemaakt met je DNS-settings. Een cijfer verkeerd is gelijk niet werken.
Ik vermoed zelf dat je een werkstation(s) heb die als DNS-servers gedefinieerd heeft de DNS-servers van je provider. Bij merdendeel van de internet routertjes is het zo dat je het IP-adres van je router moet opgeven ipv de DNS-servers van je provider. Kijk eens wat jij gedefinieerd heb....
