[BC3] Help me (netbus)
  • 112 views sinds 30-01-2008
ik word helemaal gek van een turk die probeert bij mij te hacken. hoe kom ik er vanaf? :( :(
de logfile
62.29.100.41 [ ]
Connected at 24-4-2001 [13:24:08]
62.29.100.41 disconnected at 24-4-2001 [13:24:09]
62.29.100.41 [ ]
Connected at 24-4-2001 [13:24:18]
13:24:18: Received the ''force password'' command
13:24:19: Received the ''force password'' command
62.29.100.41 thrown out at 24-4-2001 [13:24:27]
62.29.97.226 [ ]
Connected at 25-4-2001 [19:18:21]
62.29.97.226 disconnected at 25-4-2001 [19:18:21]
No NetBus server found on remote host
62.29.97.226 [ ]
Connected at 25-4-2001 [19:18:33]
19:19:12: Get Info [Infomessage(s) sent back]
19:19:19: Listen mode ON
19:19:51: Download [Retrieve Directory Listing]
62.29.97.226 thrown out at 25-4-2001 [19:19:51]
62.29.97.226 [ ]
Connected at 25-4-2001 [19:20:25]
62.29.97.226 thrown out at 25-4-2001 [19:20:30]
62.29.97.226 [ ]
Connected at 25-4-2001 [19:20:43]
62.29.97.226 thrown out at 25-4-2001 [19:20:43]
62.29.100.212 [ ]
Connected at 25-4-2001 [21:17:40]
62.29.100.212 disconnected at 25-4-2001 [21:17:41]
62.29.100.212 [ ]
Connected at 25-4-2001 [21:27:18]
62.29.100.212 thrown out at 25-4-2001 [21:27:20]
62.29.100.212 [ ]
Connected at 25-4-2001 [21:27:50]
62.29.100.212 thrown out at 25-4-2001 [21:27:55]
62.29.100.212 [ ]
Connected at 25-4-2001 [21:28:27]
62.29.100.212 thrown out at 25-4-2001 [21:28:30]
  • jelmervos
jelmervos
Simple user
Heb je er echt zoveel last van? Hij probeerd toch alleen? Je kunt het hoogstens melden bij zijn ISP ofzo. abuse@isp.nl.
"The shell stopped unexpectedly and Explorer.exe was restarted."
Het probleem is dat hij uit turkye komt.
En kan er niet goed achter komen wat zijn isp is
  • jelmervos
jelmervos
Simple user
Op woensdag 25 april 2001 21:32 schreef goldfish80 het volgende:
Dan wordt het idd moeilijker, gewoon nergeren geen oplossing?
  • IceStorm
  • Laatst online: 08-09 21:49
IceStorm
This place is GoT-like!!!
Firewall erop = problem solved?
je moet er ekkes een vuurmuur op ketsen daarmee kun je ook zijn IP adres 8erhalen en dan kun je em meej sub7 of iets dergelijks terughacken >:)
je moet btw wel je firewall aan laten staan anders kan ie nog in je pc
Op woensdag 25 april 2001 21:55 schreef Sickness het volgende:
ik heb zijn ip, kijk maar in de logfile boven.
ach... ik negeer hem wel, hij zou vast wel een keer ophouden
  • freddifish
  • Laatst online: 29-01 09:15
freddifish
schnappi !
bombardeer dat IP met pakketjes ! >:)
'people say I'm a drinker, but I'm sober half the time' - Mick Jagger | mail: freddifish_AT_gmx.net
Zal ik jou is bombarderen?
  • jelmervos
jelmervos
Simple user
Op woensdag 25 april 2001 22:53 schreef mxstrAEm het volgende:
Waar slaat dit op? :?:?
  • jelmervos
jelmervos
Simple user
Op woensdag 25 april 2001 22:28 schreef goldfish80 het volgende:
Idd, is gewoon het beste. Zijn irri lui, die aandacht willen, in welke vorm dan ook. Negeren is dan het beste!
Op woensdag 25 april 2001 23:31 schreef jelmervos het volgende:
Het ene onrecht rechtvaardigt eigen onrecht niet
  • JaNNeS
  • Laatst online: 10-09-2024
Zal ik je een klein eindje op weg proberen te helpen...
62.29.100.41
inetnum: 62.29.0.0 - 62.29.127.255
netname: TR-DOGAN-20000427
descr: Dogan Iletisim Elektronik Servis Hizmetleri
descr: PROVIDER
country: TR
admin-c: AD309-RIPE
tech-c: OC552-RIPE
tech-c: EK1532-RIPE
status: ALLOCATED PA
mnt-by: RIPE-NCC-HM-MNT
changed: hostmaster@ripe.net 20000427
source: RIPE
route: 62.29.0.0/17
origin: AS12978
mnt-by: AS12978-MNT
changed: ekalkan@hurriyet.com.tr 20000505
source: RIPE
person: Ahmet DALMAN
address: Hurriyet Gazetecilik ve Matbaacilik A.S.
address: Information Systems
address: Hurriyet Medya Towers
address: 34544 Gunesli
address: ISTANBUL
address: TURKEY
phone: +90 212 550 0050
fax-no: +90 212 550 0094
nic-hdl: AD309-RIPE
changed: epyd@servis.net.tr 19961014
source: RIPE
person: Osman CAKIR
address: Evren Mah. Kat:8 Gunesli
address: Istanbul - Turkey
phone: +90 212 677 05 85
fax-no: +90 212 677 05 35
e-mail: ocakir@hurriyet.com.tr :)
nic-hdl: OC552-RIPE
changed: ocakir@hurriyet.com.tr 19991201
source: RIPE
person: Eyup Kalkan
address: Atakan Sok. No:14
address: Mecidiyekoy Istanbul TURKIYE
phone: +90 212 2120750
fax-no: +90 212 2120762
e-mail: eyup@escort.com.tr
nic-hdl: EK1532-RIPE
changed: hostmaster@knidos.cc.metu.edu.tr 19960520
changed: ripe-dbm@ripe.net 19990615
source: RIPE
abuse@hurriyet.com.tr :)
  • jelmervos
jelmervos
Simple user
Op woensdag 25 april 2001 23:40 schreef mxstrAEm het volgende:
jaja, zal wel.
  • Apronex
  • Laatst online: 20-04 18:06
Adressen zijn allemaal van een grote turkse krant(hurriyet)/drukkerij(dogan group). De namen die je daar ziet zijn de schrijvers van die krant denk ik.
Think! B4 u doing instead of doing b4 u think!
Op donderdag 26 april 2001 00:18 schreef Apronex het volgende:
ja inderdaad dat d8 ik ook.
Het is volgens mij geen provider
  • JaNNeS
Hmm dacht dat het wel een provider was...
www.hurriyet.com.tr lijkt bestwel op de frontpage van een provider, maar ik kan geen Turks, dus ik kan er heel goed naast zitten.
Maar `It''s worth a try'', en mocht het toch geen ISP zijn dan kunnen ze vanaf daar je nog wel zitten te bokken Goldfish.
Iemand The Matrix gezien? :Y)
`I can only show you the door...''
Succes.
