[BC3] hoe DHCPD onder redhat 7.1 aanzwengelen?
  • GiLuX
  • Laatst online: 12-11-2025
keb net de dhcpd rpm geinstalled en een dhcpd.conf file aangemaakt in /etc
en daar in gezet:
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.0 192.168.1.254;
maar dit is volgens mij niet voldoende want het werkt niet.
heeft iemand hier meer verstand van dan ik?
"I disagree with what you are saying, but I will defend to the death your right to say it." -- not clear who
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
subnet 10.0.0.0 netmask 255.255.255.0 {
      option routers 10.0.0.1;
      option domain-name "***.*****.nl";
      option domain-name-servers 10.0.0.1, 213.196.1.2, 212.83.68.130;
      range dynamic-bootp 10.0.0.20 10.0.0.49;
      range 10.0.0.10 10.0.0.29;
      default-lease-time 1204723;
      max-lease-time 1204723;
      host hookiL {
            hardware ethernet 00:10:a4:e0:65:f8;
            fixed-address 10.0.0.2;
      host hookiD {
            hardware ethernet 00:10:a7:05:a6:66;
            fixed-address 10.0.0.3;
      host sproggleL {
            hardware ethernet 00:10:A4:E0:67:0D;
            fixed-address 10.0.0.4;
      host sproggleD {
            hardware ethernet 00:50:bf:5c:b9:0b;
            fixed-address 10.0.0.5;
#     host antonL {
#           hardware ethernet 00:10:a4:e0:67:0d;
#           fixed-address 10.0.0.6;
      host antonD {
            hardware ethernet 00:e0:4c:39:1b:78;
            fixed-address 10.0.0.7;
#     host dimitriL {
#           hardware ethernet 00:10:a4:e2:e9:64;
#           fixed-address 10.0.0.8;
      option routers 10.0.0.64;
      option domain-name "****.****.nl";
      range dynamic-bootp 10.0.0.96 10.0.0.127;
      range 10.0.0.80 10.0.0.127;
      host NL-L-JFANG {
            hardware
            ethernet 00:50:04:e9:11:4c;
            fixed-address 10.0.0.65;
      host chain {
            hardware ethernet 00:10:a4:ef:91:c6;
            fixed-address 10.0.0.66;
      host reggino {
            hardware ethernet 00:10:a7:03:9d:71;
            fixed-address 10.0.0.67;
      host regginodesktop {
            hardware ethernet 00:20:18:b1:73:b4;
            fixed-address 10.0.0.68;
      host haas {
            hardware ethernet 00:10:a4:ef:91:cb;
            fixed-address 10.0.0.69;
      host speekenbrink {
            hardware ethernet 00:50:da:ae:cd:80;
            fixed-address 10.0.0.70;
      host marieniet {
            hardware ethernet 00:10:a4:e2:f1:4e;
            fixed-address 10.0.0.71;
      host regginoleen {
            hardware ethernet 00:10:a4:e2:e9:32;
            fixed-address 10.0.0.72;
      host sephiroth {
            fixed-address 10.0.0.73;
zie hier de mijne
  • GiLuX
linuxconf heeft geen dhcp optie bij mij...?
verder,
het moet aleen werken op eth1
  • GraveR
  • Laatst online: 22-08-2025
start anders linuxconf ff, via die manier kun je probleemloos die files aanmaken / editen...
### Managed by Linuxconf, you may edit by hand.
### Comments may not be fully preserved by linuxconf.
server-identifier <<<hostname van je bak>>>;
subnet 10.0.0.0 netmask 255.255.255.0{
      range  10.0.0.50 10.0.0.100;
      default-lease-time 31536000;
      option domain-name          "domein.naam";
            194.109.9.99,
            194.109.6.66;
      option subnet-mask          255.255.255.0;
voor een kortere :)
  • GraveR
Je start linuxconf, gaat naar de sectie "Linuxconf management" en uit dat menu pick je modules, en voila, daar kun je allerlei niet geactiveerde opties kiezen.
  • GiLuX
correction,
keb helemaal geen linuxconf op mijn bak,
zat in de verkeerde shell te kijken...:o
  • GraveR
Hmz... Zou toch maar installen, kan je veel werk uit handen nemen. Werkt in zowel text-modus als grafische modus X Window
  • GraveR
Je kunt DHCP niet aan een bepaalde kaart koppelen, maar alleen aan een bepaald subnet.
mocht je ook statische IPs willen uitdelen, kies dan voor een DHCP-range dat buiten het gebied van de statische range ligt.
#dhcpd eth1
et voila! Hij luistert op eth1
  • GiLuX
maar ik krijg deze melding als ik dhcpd start:
No subnet declaration for eth0.
Please write a subnet declaration in your dhcpd.conf file for the
network segment to which interface eth0 is attached.
exiting.
FF uit m''n hoofd:
subnet ip_network_of_eth0 netmask netmask_of_eth0 {
   not authoritative;
Dat je DHCPD niet aan een interface kunt hangen is volkomen onzin!
*kick* :)
Ik heb m'n DHCP netjes lopen met de conf die hieronder staat maar in m'n windows bak krijg ik geen IP van die server. Ik heb wel de route voor 255.255.255.255 geadd zoals in de Official Linux Networking Guide staat. Hoe kan dit??
M'n conf:
#dhcpd.conf
#configged for personal network
default-lease-time 1200;
max-lease-time 9200;
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.20 192.168.0.50;
option broadcast-address 192.168.0.1;
option routers 192.168.5.10;
M'n etho0 is een 3Com kaart die zeker weten goed werkt met IP 192.168.0.1 en subnet 255.255.255.0
  • asusk7m550
  • Laatst online: 12-08 11:49
asusk7m550
Athlon 550@500
Je broadcast adres staat wel fout, je moet er van maken 192.168.0.255 (nouja moeten is een groot woord)
Ik heb verder zelf
shared-network DHCP {
  option subnet-maks 255.255.255.0;
  default-lease-time 6000;
  max-lease-time 72000;
    range 192.168.0.2 192.168.0.126;
    option broadcast-address 192.168.0.255;
    option routers 192.168.0.1;
    option domain-name-servers 192.168.0.1;
  subnet 192.168.1.0 netmask 255.255.255.0 {}
Volgens mij 1 van de simpelse scriptjes, en het werkt ook nog. Waarbij de server 192.168.0.1 voor DNS, DHCP en routing zorgt.
It takes only a minute to get a crush on someone, an hour to like someone, and a day to love someone, but it takes a lifetime to forget someone.
Ik heb dat scriptje overgenomen en DHCP opnieuw gestart maar van de linux bak nog steeds geen IP's.
Heb DHCPD even met debug mode opgestart maar ook daar geen fouten.
Mijn andere pc is een Windows 2000 bak trouwens. Wie weet maakt het verschil.
Ik heb die config ook ff gekopieerd en had binnen een paar minuten een werkend geheel, ook op win2k. Echter moest er nog een dingetje bij voordat het ging werken:
ddns-update-style ad-hoc;
Dit op een server waar dns draait (9.nogwat :) ) en dhcp 3.0 .
Op zondag 11 november 2001 19:17 schreef whistler het volgende:
*kick* :)
M'n conf:
Hmzz euh... je router ligt buiten je subnet :?
Wordt een beetje lastig he ;)
  • I_stealth_I
  • Laatst online: 10:16
I_stealth_I
Tweak It OR leave it!
Op donderdag 24 mei 2001 02:40 schreef nelske het volgende:
FF uit m''n hoofd:
   not authoritative;
waar is die manual waarin ik dit kan vinden?
Ik heb op Eth0 Chello hangen, die een IP krijgt van chello haar DHCP Server. Eth1 is mijn LAN. Maar mijn DHCPd is zo actief om ETH0 een IP toe te wijzen. Dat is dus niet de bedoeling, teminste als ik ik verder wil internetten dan de UPC error page *D
/dev/null
  • I_stealth_I
I_stealth_I
Each interface on the server needs to have a subnet declaration. Having a subnet declaration does not necessarily mean that you need to serve DHCP on that interface. The declaration can be as simple as:
not authoritative;
maar mijn ETH0 krijgt gegevens van een Chello's DHCP dus die subnet en netmask kunnen verschillend zijn?
/dev/null
