[BC3] Wat betekenen deze foutmeldingen ?
  • BC3 Victim
  • Laatst online: 29-09-2006
ik kan je een algemeen advies geven:
probeer die ene netwerkkaart uit in een andere comp!
  • ACM
ACM
Software Architect
Werkt hier
Dan zal er wel een irq''tje te kort zijn?
En probeert de kernel er twee tegelijk hetzelfde irq toe te wijzen ofzo.
  • kieskes
  • Laatst online: 13:21
hallo, kan iemand me vertellen hoe ik deze fouten kan oplossen ?
... autorun DONE.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 64k freed
Adding Swap: 82616k swap-space (priority -1)
pcnet32.c: PCI bios is present, checking for devices...
PCI Master Bit has not been set. Setting...
Found PCnet/PCI at 0x1000, irq 10.
eth0: PCnet/PCI 79C970 at 0x1000, 00 80 5f 4a 37 df assigned IRQ 10.
pcnet32.c:v1.25kf 26.9.1999 tsbogend@alpha.franken.de
eepro100.c:v1.09j-t 9/29/99 Donald Becker http://cesdis.gsfc.nasa.gov/linux/driv
ers/eepro100.html
eepro100.c: $Revision: 1.20.2.10 $ 2000/05/31 Modified by Andrey V. Savochkin <s
aw@saw.sw.com.sg> and others
eth1: OEM i82557/i82558 10/100 Ethernet, 00:60:B0:67:53:AA, I/O at 0x1020, IRQ 1
1.
Board assembly 673610-001, Physical connectors present: RJ45
Primary interface chip i82555 PHY #1.
General self-test: passed.
Serial sub-system self-test: passed.
Internal registers self-test: passed.
ROM checksum self-test: passed (0x49caa8d6).
Receiver lock-up workaround activated.
ne.c:v1.10 9/23/94 Donald Becker (becker@cesdis.gsfc.nasa.gov)
NE*000 ethercard probe at 0x300: 00 40 f6 60 c7 b6
eth2: NE2000 found at 0x300, using IRQ 9.
NE*000 ethercard probe at 0x320: 00 80 48 b8 c4 a3
eth3: NE2000 found at 0x320, using IRQ 7.
eth2: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1284.
eth2: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1000.
eth2: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1292.
eth2: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1281.
eth3: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1253.
eth3: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1243.
eth3: Tx timed out, lost interrupt? TSR=0x3, ISR=0x2, t=1000.
eth3: Tx timed out, lost interrupt? TSR=0x53, ISR=0x2, t=1283.
die 2 kaarten die niet werken zijn 2 isa kaartjes, ne2000 compatible
de kaartjes staan hardwarematig niet ingesteld op een irq.
  • kieskes
Die beide kaartjes werken gewoon onder windows, dat is het probleem niet.
het probleem is dat ze niet P&P zijn (ISA kaartjes)
  • kieskes
er staat toch dat eth2 irq 7 gebruikt en eth 3 irq 9, mag toch geen probleem zijn
  • ACM
ACM
Software Architect
Werkt hier
Op zaterdag 19 mei 2001 18:34 schreef kieskes het volgende:
Mag niet nee ;)
Kan wel, of een deling met een ander apparaat.
  • kieskes
kijk is :
[root@www /root]# cat /proc/interrupts /proc/ioports | more
CPU0
0: 792163 XT-PIC timer
1: 14 XT-PIC keyboard
2: 0 XT-PIC cascade
4: 7 XT-PIC serial
8: 1 XT-PIC rtc
9: 0 XT-PIC NE2000
10: 95400 XT-PIC PCnet/PCI 79C970
11: 78511 XT-PIC eth1
13: 1 XT-PIC fpu
14: 62832 XT-PIC ide0
NMI: 0
0000-001f : dma1
0020-003f : pic1
0040-005f : timer
0060-006f : keyboard
0070-007f : rtc
0080-008f : dma page reg
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : fpu
01f0-01f7 : ide0
0300-031f : NE2000
03c0-03df : vga+
03f6-03f6 : ide0
03f8-03ff : serial(auto)
1000-101f : PCnet/PCI 79C970
1020-103f : Intel Speedo3 Ethernet
  • ACM
ACM
Software Architect
Werkt hier
Hehe, ik had iets vergelijkbaars een keer met een 3com kaartje, zou ook een uniek irq hebben.
Maar toch kreeg ik ook zo''n melding |:(
Reset en wat rommelen in bios leek het allemaal verholpen te hebben (was nooit eerder voor gekomen en sindsdien ook niet meer)
  • kieskes
Hmmm, ga is ff kijken hoe dat met zon brakke compaq werkt,
oja met een diskette |:(
  • kieskes
Hmmz, volgens het opstarten werken de kaarten nu :)
Weet jij nog een manier om via de console te kijken of ze ook echt werken ?
Ik kan er namelijk niet ff een kabeltje insteken..
