[BC3] IP_tables en kernel 2.4.4
  • Lurge
Lurge
ActueleWind
sorry hoor maar ik kan niet vinden welke kernel opties ik allemaal moet hebben. Want daar zal het wel aan liggen ergens.
alvast bedankt
Lurge
ActueleWind
  • Lurge
Lurge
ActueleWind
Hoi,
Als ik mijn firewall scriptprobeer te draaien door deze regel te runnen: /usr/local/sbin/iptables --flush krijg ik deze error:
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol remove_proc_entry_Rd53970bc
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol vfree_R2fd1d81c
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol request_module_R27e4dc04
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol __generic_copy_to_user_Rd523fdd3
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol nf_unregister_sockopt
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol __generic_copy_from_user_R116166aa
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol sprintf_R3c2c5af5
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol irq_stat_Rc0ba6f96
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol printk_R1b7d4074
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol nf_register_sockopt
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol smp_num_cpus_R3b86334d
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol proc_net_Rea032240
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol __vmalloc_R79995c5b
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol net_ratelimit_Rf6ebc03b
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: unresolved symbol create_proc_entry_R4b1c34b9
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: insmod /lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o failed
/lib/modules/2.4.4/kernel/net/ipv4/netfilter/ip_tables.o: insmod ip_tables failed
iptables v1.2.1a: can't initialize iptables table `filter': iptables who? (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
Weet iemand wat ik hieraan kan doen ?
ik heb netfilter wel in de kernel zitten.
als ik mijn andere 2.4.4 kernel pak krijg ik alleen:
unresolved symbol: nf_unregister_sockopt
Kan iemand een oplossing geven voor een van de 2? of een andere mogelijkheid geven om mijn masquerading aan de praat te krijgen dat ik dus ook kan ftp''en achter mijn gateway
alvast bedankt
grtz
ActueleWind
  • BC3 Victim
  • Laatst online: 29-09-2006
Even je kernel compileren met de voor iptables benodigde opties aan.. en dan niet vergeten ook een make modules te doen en een make modules_install.
Hoe je je kernel moet configgen voor iptables staat uitgebreid beschreven in diverse howto''s, neem eens een kijkje op
http://netfilter.filewatcher.org
  • BC3 Victim
Met name ''network packet filtereing (replaces ipchains)'' moet aanstaan...
Verder zou ik bij ''IP: Netfilter configuration'' alles aanzetten..
