[BC3] 2.4.4-ac5
  • 221 views sinds 30-01-2008
  • BC3 Victim
  • Laatst online: 29-09-2006
Zag dat wat mensen problemen hadden met 2.4.4.
Er zijn al weer een berg fixes gedaan op deze kernel.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
2.4.4-ac5
o    Fix DMA setup on hpt366/370               (Tim Hockin)
o    DRM memory alloc failure checks             (Akash Jain)
o    Remove bogus fs/buffer.c diff           (Ben LaHaise)
o    cs46xx update - adds Hercules Game Theatre XP   (Thomas Woller)
o    Fix menuconfig breakage with ()       (Andrzej Krzysztofowicz)
o    Updated multithreaded core dump support       (Don Dugger)
o    Remove dead ibmtr.h include               (Mike Phillips)
o    Fix misplaced letters in koi8-u             (Andriy Rysin)
o    Further alpha module locking fix           (Andrea Arcangeli)
o    Keyspan bitwidth fixes               (Hugh Blemings)
o    usb-uhci oops fix                   (Pete Zaitcev)
o    Add ability to specify preferred minor on   (Gerd Knorr)
      video/radio4linux devices
o    Further IPX updates               (Arnaldo Carvalho de Melo)
o    Further IRDA updates                   (Dag Brattli)
o    Make x86 ptrace framesize a define (code clean) (Pavel Machek)
o    Moxa serial tidy                     (Tim Hockin)
o    Fix tiny select race                   (Rusty Russell)
o    Update aic7xxx to 6.1.12               (Justin Gibbs)
o    Alpha was missing rwlock_init           (Reto Baettig)
o    Alpha SCHED_YIELD was broken on UP       (Andrea Arcangeli)
o    Allow IRQ sharingon more PCI ide           (Pete Zaitcev)
o    Fix capable checks found by Stanford analyser   (me)
      for cciss/cpqarray
o    List more devices in sysrq table     (Andrzej Krzysztofowicz)
o    Run uml exit callbacks reverse to init     (Andrew Morton)
o    Fix SMP resched_idle pre-emption bug       (Nigel Gamble)
o    Work around config problem with menuconfig
      and USB                      (Andrzej Krzysztofowicz)
o    Fix nasty bug in Alpha PCI mapping       (Hyung Min SEO)
      | Nautilus specific stuff not applied yet
o    SBLive endianness fixes (output only so far)    (Ira Weiny)
o    Move sblive pci_enable earlier         (Marcus Meissner)
o    Merge IBM ServeRAID 4.72 driver             (Keith Mitchell)
o    Fix affs races                     (Roman Zippel)
o    Fix cdrom unload crash         (Andrzej Krzysztofowicz)
2.4.4-ac4
o    Fix future domain scsi               (Carlo Prelz)
o    Merge Linux 2.4.5pre1
o    Fix ipx without sysctl compile         (Pavel Roskin)
o    Revert fork changes to match Linus 2.4.5pre1
o    Drop the threaded core dump code
      | It can go back in when it works
o    Drop pa-risc work - it'll be easier to resync
      just once as pa has moved on a lot
o    Add spin_lockprefetch to getempty_inode     (me)
      | Experimenting
o    Kbuild has moved                     (Keith Owens)
o    Update kernel docs on memory barriers       (Rusty Russell)
o    Move es1370 pci_enable and do some cleanup (Marcus Meissner)
o    Fix netfilter overuse of __exit             (Rusty Russell)
o    Fix alpha build bug                     (Michal Jaegermann)
o    Fix tigon1 build                     (Olivier Galibert)
o    Fix tmpfs deadlocks writing into a file from    (Christoph Rohland)
      an mmap of itself
o    Fix missing (but harmless) return in vmtruncate (Al Viro)
2.4.4-ac3
o    Fix hang on boot with SMP               (Andrea Arcangeli)
      | and fixes a few more uglies too
o    freevxfs module name was wrong (should be   (me)
      freevxfs.o)
o    Update alloc_etherdev docs             (Erik Mouw)
o    Remove dead funcs, put back ip_set_manually     (David Miller,
      in the ipconfig code            (Arnaldo Carvalho de Melo)
o    Fix SA_ONSTACK standards violation (for x86)    (Christian Ehrhardt)
      | Other arch maintainers should check..
o    Add another species of SB AWE 32           (Bill Nottingham)
o    SE401 USB camera driver                 (Jeroen Vreeken)
o    Correct MAX_HD and make stuff static in ps2esdi (Hal Duston)
o    Fix inode-nr corruption                 (Al Viro)
o    Fix pgd_alloc for user mode linux         (Jeff Dike)
o    Fix UML hostfs for get_hardsect_size       (Jeff Dike)
o    Tidy up APM options setting, add module opts    (Stephen Rothwell)
o    Fix acm open race                   (Oliver Neukum)
o    Further bounce buffer fixes               (Arjan van de Ven)
o    ACPI updates                       (Andrew Grover)
o    Move pci_enable_device earlier on via audio     (Arjan van de Ven)
2.4.4-ac2
o    Remove some spurious whitespace differences     (me)
      between trees
o    Make the VIA timer reload check test avoid (me)
      tripping on a timer as it rolls back to zero
o    Drop dasdfmt man page changes (dos ^M noise)    (me)
o    Drop experimental iee1284 pnp module loading    (me)
o    Revert pcnet32 chance causing compile errors    (me)
o    Remove wrong __init in sunhme           (Dave Miller)
o    Fix overlarge udely in aironet4500       (Arjan van de Ven)
o    Remove non existant parameter from aironet4500  (Keith Owens)
o    Kill duplicate aic7xxx include     (Andrzej Krzysztofowicz)
o    Fix pci2220i scsi compile bug           (Matt Domsch)
o    Fix module exception race on Alpha       (Andrea Arcangeli)
o    Disable broken large vmalloc support on Alpha   (Andrea Arcangeli)
o    Remove dead ia64 config entries             (Steven Cole)
o    Add kbuild list info to MAINTAINERS         (Steven Cole)
o    linux appletalk list has moved     (Arnaldo Carvalho de Melo)
o    Revert wrong mount changes in 2.4.4         (Andries Brouwer)
o    Revert drivers/scsi/scsi.c change in 2.4.4 (me)
      that subtly broke about 15 drivers
o    Fix typo in slab.h                 (Pavel Machek)
o    More correct child favouring fork behaviour     (Peter Österlund)
o    Only apply pci fixups if there is a VIA 686B    (Charl Botha)
o    Fix GDT padding error introduced by PnPBIOS     (Brian Gerst)
      support
o    Fix UML build without CONFIG_PT_PROXY       (Jeff Dike)
o    dmfe wasnt calling dev_alloc_skb           (Tobias Ringstrom)
o    Further Configure.help fixups           (Steven Cole)
o    Move pci_enable_device earlier in trident   (Marcus Meissner)
2.4.4-ac1
o    Merge with Linus 2.4.4
      | This wasnt entirely trivial so this is the only
      | stuff in this patch
      | The following stuff has been switched to the Linus branch
      | in the merge: uhci, dcache atomicity, raw I/O
http://linuxtoday.com/news_story.php3?ltsn=2001-05-04-023-20-NW-KN
  • E-Vix
  • Laatst online: 10-09 16:10
E-Vix
Nu met sneeuw!
Weer een lekker duidelijke topic naam.
Failed opening '/home/users/7942/signature.inc' for inclusion (include_path='.:') in /home/www/got/userstats.php on line 25
  • BC3 Victim
Ja goed, he ?
2.4.4 = versie kernel ac5 = 5e patch uitgebracht door Alan Cox.....
Dus ZEER DUIDELIJK imho.
  • Bulldog
Allemaal heel erg leuk en aardig, maar is het niet een beetje onzinnig om elke bug /fix die beschikbaar is hier te posten? Weet niet of iedereen hier wel in is geintreseerd (ja, ze hoeven het natuurlijk niet te lezen...) maar straks staat dit hele forum vol met fix /bug meldingen en dat lijkt mij toch niet de bedoeling. Het is hier tenslotte geen news-site:)
  • Jordi
Jordi
#1#1
Agreed, collega :)
Het zal wel niet, maar het zou maar wel.
