[BC3] problemen met proftpd
  • banaan-X
Ik heb nu dit in xinetd.conf staan:
defaults
instances = 60
log_type = SYSLOG authpriv
log_on_success = HOST PID
log_on_failure = HOST
includedir /etc/xinetd.d
service ftp
socket_type = stream
wait = no
user = root
server = /usr/local/sbin/proftpd proftpd
Op een of andere vage reden geeft ie dan toch Connection Refused aan... (ligt niet aan firewall, wu-ftp werkt wel)
Als ik dan dat commando achter server zelf intype (als deamon draaien) en dan inlog doet iet het wel. Ik wil echter dat je Anonym kunt inloggen en dat werkt niet door dit in proftpd.conf te hebben:
# This is a basic ProFTPD configuration file (rename it to
# ''proftpd.conf'' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "XS4me ProFTPD"
ServerType inetd
DefaultServer on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# Normally, we want files to be overwriteable.
<Directory /*>
AllowOverwrite on
</Directory>
# A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ''welcome.msg'' displayed at login, and ''.message'' displayed
# in each newly chdired directory.
DisplayLogin welcome.msg
DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot behalve in /upload
<Directory *>
<Limit WRITE>
DenyAll
</Limit>
</Directory>
# En we willen graag dat anonymous in /upload mag uploaden
<Directory upload>
<Limit WRITE>
DenyAll
</Limit>
<Limit READ STOR>
AllowAll
</Limit>
</Directory>
</Anonymous>
Wat moet ik doen om dit te laten werken?? :?
  • ACM
ACM
Software Architect
Werkt hier
Ik zou proftpd gewoon standalone draaien.
En dan rustig (of eerst eigenlijk) de configuratie directives bekijken en de manual doorkijken...
  • banaan-X
maar waarom werkt ie nou niet vanuit xinetd?
Dat van die anonymous zoek ik dan later nog wel op, maar waarom werkt ie nou niet vanuit xinet?
service ftp
wait = no
user = root
Heb je dit in xinetd.conf staan? Welke bestanden heb je in /etc/xinetd.d/ staan? Staat daar iets anders dat op ook op 21 wil luisteren? Wat zegt je syslog?
Moet server niet linken naar in.proftpd ipv proftpd?
server = /usr/sbin/in.proftpd
Suc6
  • imdos
  • Laatst online: 10-09 09:50
imdos
I use FreeNAS and Ubuntu
proftpd is gelinkt naar in.profptd als ik me niet vergis! Verder zou je de DefaultRoot nog kunnen aanpassen.
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
  • BC3 Victim
  • Laatst online: 29-09-2006
Even voor de zekerheid vragen: wuftpd draait niet tegelijkertijd toch ? Want anders heb je 2 deamons die zich aan poort 21 willen binden...
Sorry zie het al..
Ik had vroeger een link naar in.proftpd.
  • imdos
imdos
Bestaat de groep nogroup wel btw???
en de user/groep ftp!
IdentLookups off
Daar kan het ook op misgaan ... tenminste het connecten duurt dan veel langer!
Maar ik vraag me af of je proftpd dan wel goed hebt toegevoegd in die xinetd! Die ken ik echter niet dus kan je er niet mee helpen.
via inetd; ftp stream tcp nowait root /usr/sbin/tcpd /usr/local/sbin/proftpd
  • banaan-X
Ik heb het gevonden:
AnonRequireShell off
moest er nog bij...
Iedereen bedankt voor de reacties.
