[BC3] rare cups/samba probleem
  • 65 views sinds 30-01-2008
  • goodfella
  • Laatst online: 15-08 07:59
OKay, ik heb deze ook in
alt.os.linux.slackware gepost vandaar dat ie in het engels is:
Hi slackguru''s
I''ve installed cups and it''s working great!
I''m suprised by the easy install and configuration.
Athough I did it on the commandline and not the webadministration tool.
Samba is working fine, the win98 client can reach the shares directory.
But I''ve tried to use cups for sharing the printer with samba.
It didn''t worked out, :-(
The win98 client can see the printer, which is installed correctly on my
system because I''ve tested it. On startup the cups deamon automatically
starts.
I''ve chosen for:
print command = lpr-cups -P %p -o raw %s
so the win98 client can use their own drivers.
see also my smb.conf below.
Under win98 I installed the network printer and set it as default printer.
I''ve tried to print several documents/images but the printer never
prints. It just sents the print tasks and nothing happens! There''s no
error message or something.
This is my smb.conf:
[global]
workgroup = XXXXXXXXXXX
netbios name = vegeta
interfaces = 192.168.0.1/24
allow hosts = 192.168.0. x.x.x.x
guest account = trunks xuan vegeta
printing = cups
printcap name = lpstat
load printers = yes
[home]
comment = Test
path = /home
browseable = yes
read only = yes
create mode = 0644
available = yes
public = yes
writable = no
[printers]
comment = All Printers
path=/var/spool/samba
browseable = yes
guest ok = yes
writable = yes
public = yes
printable = yes
create mode = 0700
lpq command = lpstat -o %p
lprm command = cancel %p-%j
available = yes
Please Please help me!
Thanx in advance!
Goodfella
Dit probleem heb ik ook!
Dit is in de laatste 4 weken al 3 of 4 keer gevraagd. Je moet in de dir /etc/cups de bestanden mime.convs en mime.types aanpassen
Sterkte met zoeken.....
  • Wilke
  • Laatst online: 06:17
BC3 !?
Uhm, beetje oude thread?
  • deadinspace
  • Laatst online: 23:10
deadinspace
The what goes where now?
Op dinsdag 18 juni 2002 16:35 schreef Wilke het volgende:
Nogal :)
JelleAret, start maar een nieuw topic waarin je je probleem duidelijk uitlegt ;)
Op deze manier blijven we ons dingen afvragen als 'welke distro heb je' (toevallig wel zelfde als topicstarter of niet)?
