[BC3] doet mijn koetje het wel????
  • Reacher
  • Laatst online: 14-10 21:30
Reacher
oldschool
Ik weet niet of er al zo''n topic is, ik kreeg er geen gevonden die toereikent is voor mijn vraag.
Doet mijn koe het wel????
als ik op de stats kijk dat staat er dat ik nix ingestuurd heb, en daarmee sta ik dus op 0.
als ik de dpc client open krijg ik dit te zien :
[Apr 25 06:53:27 UTC] Sent 2 blocks (5*2^28 keys) to server.
[Apr 25 06:53:27 UTC] 0 RC5 blocks (0*2^28 keys) remain in buff-in.rc5
[Apr 25 06:53:27 UTC] 7 RC5 blocks (34*2^28 keys) are in buff-out.rc5
.....10%.....20%.....30%.....40%.....50%.....60%.....70%.....80%.....90%....100
[Apr 25 07:10:45 UTC] Completed one RC5 block 2937938B:00000000 (4*2^28 keys)
0.00:18:08.07 - [986,831.56 keys/sec]
[Apr 25 07:10:45 UTC] Connecting to distributed.net 145.89.128.249:2064
via HTTP proxy proxy.kennisnet.nl:8080
[Apr 25 07:10:48 UTC] Fetch::Invalid request acknowledgement
[Apr 25 07:10:49 UTC] Fetch::Invalid request acknowledgement
[Apr 25 07:10:50 UTC] The keyserver says: "Why is a cow2 ? Mu. (Ommmmmmmmmm)"
[Apr 25 07:10:52 UTC] Retrieved RC5 block 2 of 10 (20.00% transferred)
[Apr 25 07:10:53 UTC] Fetch::Invalid request acknowledgement
[Apr 25 07:10:53 UTC] Retrieved 2 blocks (9*2^28 keys) from server.
[Apr 25 07:10:55 UTC] Flush::Corrupt acknowledgement for packet 0.
[Apr 25 07:10:56 UTC] Flush::Corrupt acknowledgement for packet 0.
[Apr 25 07:11:02 UTC] Flush::Corrupt acknowledgement for packet 0.
[Apr 25 07:11:02 UTC] Loaded RC5 8*2^28 block 29215BA0:00000000
[Apr 25 07:11:02 UTC] Summary: 4 RC5 blocks 0.00:45:34.85 - [981.53 kkeys/s]
[Apr 25 07:11:02 UTC] 1 RC5 block (1*2^28 keys) remains in buff-in.rc5
[Apr 25 07:11:02 UTC] 8 RC5 blocks (38*2^28 keys) are in buff-out.rc5
Werkt ie of werkt ie niet
BVD
but I don't like you in that way
the best things in life are illegal
born to do porn!
Zegt ie Mooooeeeehhhh??...
Dan doet ie ''t :)
  • BC3 Victim
  • Laatst online: 29-09-2006
Hij doet het wel, je hebt alleen wel erg weinig blokjes in je buffers }:O
  • Reacher
Reacher
oldschool
Op woensdag 25 april 2001 09:41 schreef Gizz het volgende:
en hoe los ik dat op????
born to do porn!
  • Andy
  • Laatst online: 15-07 18:17
Andy
rm -r
-klik met rechts in het venster van je koe
-in het menu dat tevoorschijn komt klik je op "configure"
- kies optie 2
dan zie je het volgende voor je neus:
1) Buffer in memory only? (no disk I/O) ==> no
2) In-Buffer Filename Prefix ==> buff-in
3) Out-Buffer Filename Prefix ==> buff-out
4) Checkpoint Filename ==> CP
5) Disable buffer updates from/to a keyserver ==> no
6) Keyserver<->client connectivity options
7) Disable buffer updates from/to remote buffers ==> yes
8) Load-work precedence ==> RC5,OGR=0,CSC=0,DES=0
9) Additional buffer-level checking ==> 0 (none)
10) Buffer-level check interval ==> 0:00 (on buffer change)
11) Preferred packet size (2^X keys/packet) ==> RC5=33
12) Fetch work threshold ==> RC5=3000,OGR=1
13) Fetch time threshold (in hours) ==> RC5=0
kies eerst eens optie 11 en maak daar je preferred packet size 33
dan kies je optie 12 en tikt daar in: rc5=5000
nu nog ff saven door optie 0 te kiezen tot je eruit bent.
Daarna eerst ff zorgen dat je internet-verbinding hebt, dan klik je weer met rechts in de koe en kiest de optie update buffers
als het goed is haalt hij nu voldoende werk op voor de eerstkomende tijd
Het is tzt ook aan te bevelen dat je iedereen in je kennissenkring ook besmet met een koe. Doe dit echter pas als je zelf een beetje door hebt hoe het allemaal werkt. Enneh, het is niet verboden om op verschillende PC''s hetzelfde emailadres in te vullen.........
Young child with dreams, dream every dream on your own. When children play, seems like you end up alone. Papa says he'd love to be with you, If he had the time. So you turn on the only friend you can find, there in your mind.. (Neil Diamond -Shilo-)
  • Reacher
Reacher
oldschool
Op woensdag 25 april 2001 09:58 schreef Andy het volgende:
- kies optie 2
Het wil niet helemaal lukke, ff een scr.shotje
(laat maar)
born to do porn!
  • MarcyDarcy
  • Laatst online: 21:52
is het al gelukt?
  • BC3 Victim
ik heb ook maar weinig blokjes in me buffers, heb aan die instellingen nix veranderd... heb geen zin in megaflushes laat mijn koe maar gewoon doorgrazen en fetchen en flushen...
  • JustMe
  • Laatst online: 06-11-2022
JustMe
#1 R@H
Als je het veranderd naar 5000 zit je nog niet op een megaflush, was dat maar zo ;)
Cureseekers | There's something wrong with this yogurt
  • BC3 Victim
Op woensdag 25 april 2001 19:52 schreef bram538 het volgende:
nee daarom. wil ik een megaflush (van 20.000+ blokjes ofzo) kost me dat weken... :( snelheid=zo''n 300-500 blokjes per dag...
  • MarcyDarcy
En dat met een t-bird 1 ghz?
Of je gebruikt je computer te veel...of hij staat niet lang genoeg aan er dag }:O
  • Wessie
  • Laatst online: 19-10 20:34
Wessie
Noizy Cows Crewmember
1 gig is toch 1000 WU''s of meer :?
Check www.teamanandtech.com en je weet ut !
Wessie ... member of the Noizy Cows !!!
