[BC3] stubs kwijt na vastloper?
  • Dijkhuis
  • Laatst online: 15-10 17:50
Mijn pc loopt wel eens vast (slechte win me), en als ik zo in m''n logs kijk lijkt het alsof ik daarna de huidige stub kwijt ben? is daar iets aan te doen?
ik had eerder van stappel begrepen dat de checkpoint-functie niet goed werkt.
dnetc v2.8010-463-CTR-00071214 for Win32 (Windows 4.90).
Using email address (distributed.net ID) ''dijkman@casema.net''
[Mar 29 09:31:19 UTC] Loaded OGR stub 25/5-2-6-27-21-4 (19.30% done)
[Mar 29 09:31:19 UTC] 92 OGR packets (92 work units) remain in buff-in.ogr
[Mar 29 09:31:19 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Mar 29 09:31:19 UTC] 1 cruncher has been started.
[Mar 29 09:31:48 UTC] *Break* Shutting down...
[Mar 29 09:31:48 UTC] Saved OGR stub 25/5-2-6-27-21-4 (19.30% done)
[Mar 29 09:31:48 UTC] Summary: 0 OGR packets (---.-- nodes)
0.00:00:00.00
[Mar 29 09:31:48 UTC] 93 OGR packets (93 work units) are in buff-in.ogr
[Mar 29 09:31:48 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Mar 29 09:31:50 UTC] Loaded OGR stub 25/5-2-6-27-21-4 (19.30% done)
[Mar 29 09:31:50 UTC] 92 OGR packets (92 work units) remain in buff-in.ogr
[Mar 29 09:31:50 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Mar 29 09:31:50 UTC] 1 cruncher has been started.
[Mar 29 13:47:33 UTC] Loaded OGR stub 25/5-2-6-28-4-10
[Mar 29 13:47:34 UTC] 91 OGR packets (91 work units) remain in buff-in.ogr
[Mar 29 13:47:34 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Mar 29 13:47:35 UTC] 1 cruncher has been started.
[Mar 29 15:45:57 UTC] Loaded OGR stub 25/5-3-13-23-1-9
[Mar 29 15:45:57 UTC] 90 OGR packets (90 work units) remain in buff-in.ogr
[Mar 29 15:45:57 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Mar 29 15:45:57 UTC] 1 cruncher has been started.
  • B-Force
  • Laatst online: 20-10 13:27
Wat is hier mis mee?
De eerste keer gaat ie verder waar ie was gebleven, de 2e en derde keer begint ie met een nieuwe stub....
  • Mobster
  • Laatst online: 07-06-2016
Mobster
Los Alcoholicos
Je moet even bij Buffer and Buffer update options en dan bij 4 een checkpoint filename instellen. Dan houdt ie zijn progress bij en ben jij als het goed is van je probleem af.
Suc6 }:O
Toch maar eens een andere sig bedenken :P
  • Dijkhuis
Volgens mij heb ik die laatste stubs helemaal niet afgemaakt, hij begint aan een andere, en de voorgaande komt niet in de buff-out ofzo.
En die checkpointfile schijnt niet goed te werken volgens stappel, de betreffende stub wordt namelijk dubbel verwerkt omdat er iets mis gaat met de buff-in.
  • Future
  • Laatst online: 24-11-2025
Ik had ook WinMe draaien en voortdurend vastlopers. Na elke vastloper begint de koe inderdaad met een nieuw packet.
Nu heb ik weer Win98 erop gezet en doet ie het weer perfect.
Blaat
  • crisp
  • Laatst online: 00:03
crisp
Devver
Pixelated
Hmm, de keren dat mijn pc crashte ging het toch wel goed hoor dankzij die checkpoint file. Gelukkig gebeurt dat slechts eens in de twee weken ofso (win98).
Intentionally left blank
  • JustMe
  • Laatst online: 06-11-2022
JustMe
#1 R@H
Bij mij werkt die checkfile ook perfect, ook al draai ik win me :(
Cureseekers | There's something wrong with this yogurt
  • Dijkhuis
Volgens mij gaater toch wat mis met die checkfile, zie onderstaande log:
[Apr 05 13:02:51 UTC] Recovered 1 checkpoint packet
[Apr 05 13:02:52 UTC] Loaded OGR stub 25/5-18-3-9-8-14 (67.10% done)
[Apr 05 13:02:52 UTC] 93 OGR packets (93 work units) remain in buff-in.ogr
[Apr 05 13:02:52 UTC] 0 OGR packets (0 work units) are in buff-out.ogr
[Apr 05 13:02:53 UTC] 1 cruncher has been started.
[Apr 05 13:38:52 UTC] Completed OGR stub 25/5-18-3-9-8-14 (192,532,920,639 nodes)
0.00:36:00.04 - [2,811,835.32 nodes/sec]
[Apr 05 13:38:52 UTC] Loaded OGR stub 25/5-18-3-9-8-14 (68.10% done)
[Apr 05 13:38:52 UTC] Summary: 1 OGR packet (6.07 Gnodes)
0.00:36:00.04 - [2.81 Mnodes/s]
[Apr 05 13:38:52 UTC] 92 OGR packets (92 work units) remain in buff-in.ogr
[Apr 05 13:38:52 UTC] 1 OGR packet (1 work unit) is in buff-out.ogr
[Apr 05 14:09:27 UTC] Completed OGR stub 25/5-18-3-9-8-14 (192,532,971,007 nodes)
0.00:30:34.23 - [2,794,953.83 nodes/sec]
[Apr 05 14:09:27 UTC] Loaded OGR stub 25/6-2-3-20-9-21
[Apr 05 14:09:27 UTC] Summary: 2 OGR packets (11.20 Gnodes)
0.01:06:34.28 - [2.80 Mnodes/s]
[Apr 05 14:09:27 UTC] 91 OGR packets (91 work units) remain in buff-in.ogr
[Apr 05 14:09:27 UTC] 2 OGR packets (2 work units) are in buff-out.ogr
[Apr 05 21:35:30 UTC] The perproxy says: "[eNeRGy]"
[Apr 05 21:35:30 UTC] Retrieved 1 OGR packet (1 work unit) from server
[Apr 05 21:35:31 UTC] Sent 2 OGR packets (2 work units) to server
Behalve dat hij die stub twee keer afmaakt, heeft hij dan ook nog eens een verschillende grootte. dit stinkt.
