Netbeui onder WinXP, voor intel printerserver/s
voor iedereen die WinXP draait en een printer aan een Intel printerserver, niet aan de praat kan krijgen,de oplossing is het installeren van Netbeui, en dan kun je je printer ook gewoon onder WinXP installeren,
uitleg installatie Netbeui WinXP:
How to Install NetBEUI on Windows XP
Formal product support for Microsoft Windows XP will be available from Microsoft beginning October 25, 2001. Until then, you can consult with your counterparts, peers, and Microsoft Most Valuable Professionals (MVPs) by using our online newsgroups. Access to the Microsoft newsgroups is available from the following Microsoft Web site:
http://communities.microsoft.com/newsgroups/default.asp
The information in this article applies to:
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
SUMMARY
This article describes how to install the NetBEUI protocol on a Windows XP-based computer. This may be useful because the NetBEUI protocol is not included in the list of installable protocols in Windows XP even though the files that are needed to install the protocol are included with the installation CD-ROM. It is important to note that the NetBEUI protocol is not supported on Windows XP.
MORE INFORMATION
The Netnbf.inf and Nbf.sys files are the files that are needed to install the NetBEUI protocol. To install the NetBEUI protocol:
Click Start, click Control Panel, and then double-click Network Connections.
Right-click the adapter you want to add NetBEUI to, and then click Properties.
On the General tab, click Install.
Click Protocol, and then click Add.
Click Have Disk, insert your Windows XP CD-ROM, open the Valueadd\msft\net\netbeui folder, click the Netnbf.inf file, and then click Open.
Click OK, and then click OK to complete the installation.
Additional query words:
Keywords : kbnetwork kbtool
Issue type : kbhowto
Technology : kbWinXPProSearch kbWinXPHomeSearch kbWinXPSearch
