Quake3 opstart fout?? HELPPPPP
Jow
als ik quake 3wil gaan spelen krijg ik in een blauw schermpje een foutmelding :
in dat blauwe schermpje staat:
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:Program FilesQuake III Arenabaseq3pak0.pk3 (3539 files)
C:Program FilesQuake III Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: cc90330-b.assen1.dr.nl.home.com
IP: 212.120.70.148
Working directory: C:Program FilesQuake III Arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSYSTEMopengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...23 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
En daar boven dat blauwe schermpje knipperd
dit:
wie weet hoe ik dit kan repareren?
opnieuwe instaleren hefet geen zin!
probeer eens even te kijken op deze site... lijkt erop dat je geen OpenGL hebt, of geen goede drivers enzo...
  • Copyman
  • Laatst online: 31-10 16:34
Copyman
Dode muis
Op dinsdag 25 september 2001 20:33 schreef The_Snake het volgende:
Zeer belangrijke informatie: Inventaris
  • Dyxtra
Dyxtra
curb surfer
Als ik jou was zou ik mn IP en hostname ff uit dat stukje halen, je weet nooit wat voor geinponums hier rondlopen.
f.k.a D³
"that dude can really drive!!"
COH Replay Analyzer | Filmpjes
  • Chaoss
  • Laatst online: 23:34
Chaoss
Moderator Spielerij
Professioneel boekemantsje
Deze foutmelding hattik ook, het was bij mij op te lossen door de nieuwste update van Q3 er overheen te gooien. (quake 3 pointrelease ofzo heet dat ding)
Heb ik ook gehad, gewoon ff opnieuw je drivers instaleren, en klaar. :)
