Athlon 1866MHz vs P4 2000MHz
  • procyon
  • Laatst online: 24-08 18:18
Ik heb dit vanochtend al gestuurd naar tweakers.net maar het is niet interessant genoeg ofzo :?
BAPCO SysMark 2001
System Intenet Business Overall
SYS 1.886GHz 196 196 196
Intel P4 2.0GHz 215 163 186
Intel P4 1.8GHz 198 154 175
AMD Athlon 1.4GHz 155 156 155
Yes, we know. Some think that BAPCO's SysMark 2001's use of applications with SSE optimizations gives Intel processors an unfair advantage. But the programs included in this benchmark (Office, Photoshop, Flash, Media Encoder) are applications many of us use. So while it's certainly not a perfect benchmarking program, it is nonetheless a good one to use in looking at a system's overall performance.
As we see in this first test, using BAPCO's SysMark 2001 as a measure of performance in some typically used applications, the SYS Cold-Fusion 1886 desktop gets the higest score, though it comes up short on the Internet test. But while it beats every other system, including the one with an Intel P4 2.0GHz processor, it does so by a margin of only 5% and at a huge price premium.
Business Winstone 2001
System Score
SYS 1.886GHz 70
Intel P4 2.0GHz 55.3
Intel P4 1.8GHz 52.9
AMD Athlon 1.4GHz 56
Content Creation Winstone 2001
System Score
SYS 1.886GHz 83.9
Intel P4 2.0GHz 72
Intel P4 1.8GHz 67.8
AMD Athlon 1.4GHz 73.4
In these two benchmarks, both from ZD, the SYS Cold-Fusion 1886 easily outperforms every other processor we tested. And this came as no great surprise, given that the 1.4GHz Athlon was already beating even a 2GHz P4. The real question here is... is a 10% boost in Content Creation Winstone 2001, or a 25% boost in Business Winstone 2001, worth $1885 to you? Because that's how much more than an otherwise identical Athlon 1.4GHz system the Cold-Fusion desktop costs.
3DMark2001 Pro 1024x768 32 bit Performance
System Score
SYS 1.886GHz 5705
Intel P4 2.0GHz 5884
Intel P4 1.8GHz 5745
AMD Athlon 1.4GHz 5159
dit is dus zonder pc 2400 geheugen en zonder de KT266A chipset!
misschien had je meer succes gehad moest je het enkel over die Cold-Fusion gehad hebben...
Bedoel, iedereen weet ondertussen wel dat een Athlon op hoge snelheden alles wat van Intel komt doet verkrampen, is gewoon geen nieuws meer.
Wel vaag, die 3dmark 2001 score, komt zeker omdat die P4 rimm geheugen had en die AMD maar 133Mhz geheugen...
Deze test zegt namelijk weer wat anders:
Afbeeldingslocatie: http://www.hardocp.com/reviews/cpus/intel/p417/p4-3dmark2001-w2k.gif
voor mij nogsteeds amd ;)
  • procyon
voor mij ook :)
Kan je nagaan hoe snel deze setup zou worden als er wel gebruike was gemaakt van pc-2400 geheugen icm de KT266A chipset..
daar kijk ik echt naar uit..
  • procyon
Op dinsdag 25 september 2001 15:38 schreef SM-DoubleD het volgende:
Je bent toch wel met mee eens dat dit wat spannender werk is dan de 100 benchmarks tussen de 2GHz p4 en de 1,4 GHz athlon die we daar hebben gezien..
Op dinsdag 25 september 2001 15:48 schreef Procyon for life het volgende:
ben ik het mee eens, maar ik vind het nog altijd saai.
Die benchmarks tussen Athlon/P4 komen toch altijd met dezelfde resultaten.
Wel spijtig dat die case zo duur is, naja, Vapochill is toch al een begin :)
JEP AMD schopt kont :P
