[3ds max] Paul Steed low poly modeling boek
Paul Steed, 1 van de 3d modellers van q3 arena is eindelijk klaar met zijn boek, Modeling a character in 3ds max.
Voor de mensen onder ons (inclusief mezelf) die willen beginnen in low poly modelen voor games, lijkt dit boek me wel een aanrader, danwel handig om door te lezen.
Hier is wat hij zelf zegt van zijn boek (quote van het Polycount forum)
Hi. Just to clarify a few things about my book. It was my first attempt at translating thought to paper and balls to words. In the beginning I definitely over-explained things. I chronicled the movement of vertices and the division of edges with much didactic aplomb. As the book gains momentum I tend to do less over-explanation and provide more theory. As it stands the book probably rates as a beginner's tome on making a character in Max.
I apologize in advance if I screen-captured too many sequences of moving or merging vertices. However, keep in mind my main goal with the book is to just show you how I do it...regardless how retarded it may seem. Love it, hate it, use it to validate or refute your current character modeling methods. Over-detailing the process seemed better than under-detailing it. However, writing Modeling A Character In Max taught me a great deal and better prepares me for my next book (when I write it If youre an experienced modeler think twice about buying it and if you do buy it, use it for what its intended for at your level: show you how another modeler does it.
Regardless, I appreciate all the support from you reprobates and I look forward to hearing what you think about my book!
Lijkt me toch wel erg leuk om door te lezen om te zien hoe hij het precies doet. Hij gaat binnenkort ook beginnen aan het vervolg erop, hoe je je models moet animeren.
wow
thnx voor de tip
ik denk dat ik me dit boek zal aanschaffen
