Mijn vraag
freezes/herstart na inschakelen monitor/tv , dit gebeurd op het moment als je bijvoorbeeld smorgens bij de pc komt.
-Win 11
Mobo X870 AORUS ELITE X3D ICE(Gigabyte/Aorus)
Cpu Ryzen 9 9950X3d
Ram 32gb 6000mhz cl28 KLEVV Fit-V (KD5AGU880-60B280F)
Ssd Samsung PM9A1 1TB (MZVL21T0HCLR-00B00) PCIe 4.0 x4
Gpu 5060TI 16gb EAGLE OC ICE (Gigabyte)
Psu Corsair rm650x
Alles is voorzien van de laatste bios/updates. genoeg schijfruimte. X3d is uit. Expo is aan. Eco mode is aan. voor de rest is dnek ik alles standaard
Het probleem is als ik terug kom smorgens en ik zet een monitor/tv aan
LG55sm9800pla
of AG273QS8R4 (agon 27inch 2k 240hz)
soms freezed/herstart de pc , zeer irritant ik draai een node.
Heeft iemand enig idee.
On Sun 15-11-2026 09:11:51 your computer crashed or a problem was reported
Alvast bedankt.
Met vriendelijke groet, Multivar
-Win 11
Cpu Ryzen 9 9950X3d
Psu Corsair rm650x
LG55sm9800pla
| Crash dump file: | C:\WINDOWS\Minidump\111526-8390-01.dmp (Minidump) |
| Bugcheck code: | 0x133(0x1, 0x1E00, 0xFFFFF806A21C63C8, 0x0) |
| Bugcheck name: | DPC_WATCHDOG_VIOLATION |
| Bug check description: | The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue). |
| Analysis: | This is likely caused by a hardware problem, but there is a possibility that this is caused by a misbehaving driver. This bugcheck indicates that a timeout has occurred. This may be caused by a hardware failure such as a thermal issue or a bug in a driver for a hardware device. Read this article on thermal issues A full memory dump will likely provide more useful information on the cause of this particular bugcheck. |
