Zerodayleaker geeft instabiele Kaspersky-exploit vrij om…
  • wfe
  • Registratie: September 2026
  • Laatst online: 01-09 16:15
Artikel: nieuws: Zerodayleaker geeft instabiele Kaspersky-exploit vrij om Windows 11 t...
Auteur: @JaspB
Dit probleem is reeds verholpen:
https://support.kaspersky.com/vulnerability/list-of-advisories/12430#310826
Description
Kaspersky has fixed the issue described in the HardBreacher research. The described issue could potentially have resulted in a partial degradation of the application functionality. The issue was mitigated by updating the antivirus databases.
Affected applications
  • Kaspersky Endpoint Security Windows versions 14.0 and 14.1
Fixed versions
  • Kaspersky Endpoint Security Windows versions 14.0 and 14.1 with antivirus databases released on August 30, 2026, and later.
they recommend their users check the antivirus database update date in the application.
  • JaspB
  • Laatst online: 18-11 22:23
JaspB
Nieuwsredacteur
Ah, dank voor de tip! Ik voeg het nu toe.
