Problemen met hires op Bluesound
  • robbiestone
  • Laatst online: 23-07 16:01
I have been experiencing problems with my Bluesound Node X (Jubilee Edition) for quite some time when playing hi-res files from both Tidal and Qobuz.
The issue only affects 24-bit files. They sometimes stop at exactly the same point in a track, after which the message "Unexpected EOF" appears. What's particularly strange is that the same track may play perfectly the next day. I never experience this problem with 16-bit recordings.
To rule out my network, cabling, or the streaming services as the cause, I carried out extensive testing. Based on these tests, I have come to the conclusion that the issue is most likely related to the Node X itself or the BluOS software.
My findings are as follows:
  • I installed a new network switch.
  • The Node X is connected via wired Ethernet.
  • The latest BluOS firmware is installed.
  • With multiple 24-bit albums and tracks, playback always stops at the same point, followed by the message "Unexpected EOF".
  • The exact same tracks play flawlessly from start to finish in the Qobuz app on my PC.
  • The same hi-res files also play perfectly on another Qobuz user's Naim streamer.
  • When I reduce the playback quality in BluOS to 16-bit (CD quality), the problem disappears completely.
  • I experienced exactly the same issue previously with Tidal, which suggests that the problem is not specific to one streaming service.
  • In addition, the BluOS app occasionally displays the message "Connection failed: reconnecting in 30 seconds", even though the Node X is connected via wired Ethernet.
Based on all these tests, it appears that the problem is not caused by my network or by the streaming services, but rather by the Node X itself or the way BluOS handles certain hi-res streams. My suspicion is that BluOS crashes or fails whenever an audio file contains a minor irregularity, whereas other streamers continue playing those same files without any issues.
Has anyone else experienced this problem, or does anyone have a solution?
robbiestone.nl
  • Jorgen
  • Laatst online: 19:57
Jorgen
Moderator Beeld & Geluid
AV Liefhebber
Beste @robbiestone Tweakers is een overwegend Nederlands- en Vlaamstalig forum.
Zie ook onze huisregels:
3. We verwachten dat je de moeite neemt om een leesbaar bericht te maken en dat je leestekens gebruikt. Kunstmatige intelligentie (AI) mag als hulpmiddel worden gebruikt, maar grotendeels gegenereerde teksten zijn niet toegestaan. Daarnaast is de voertaal van Tweakers Nederlands. Engelse posts worden gedoogd, maar het is niet de bedoeling dat dit de boventoon gaat voeren. Voorbeeld: een vraag in het Engels stellen mag, mits Nederlandse antwoorden dan ook geaccepteerd zijn.
Gezien je in je eerdere berichten gewoon Nederlands sprak, is Engels in dit geval overbodig. Ik verzoek je om je post te herschrijven.
Tea. Earl Grey. Hot.
