hpt370 controllerkaart linux probleem
lo
mijn debian systeem herkent mijn extra controllerkaartje ...
maar ik krijg mijn /dev/hde met geen mogelijkheid gemount ...
ff een /var/log/dmesg
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller on PCI bus 00 dev 39
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
HPT370: IDE controller on PCI bus 00 dev 48
PCI: Enabling device 00:09.0 (0005 -> 0007)
HPT370: chipset revision 3
HPT370: not 100% native mode: will probe irqs later
ide2: BM-DMA at 0xc400-0xc407, BIOS settings: hde:DMA, hdf:pio
ide3: BM-DMA at 0xc408-0xc40f, BIOS settings: hdg:pio, hdh:pio
HPT370: onboard version of chipset, pin1=1 pin2=2
HPT370: IDE controller on PCI bus 00 dev 98
PCI: Enabling device 00:13.0 (0005 -> 0007)
HPT370: chipset revision 1
ide4: BM-DMA at 0xd400-0xd407, BIOS settings: hdi:pio, hdj:pio
HPT370: IDE controller on PCI bus 00 dev 99
ide5: BM-DMA at 0xe000-0xe007, BIOS settings: hdk:pio, hdl:pio
hda: Maxtor 91080D5, ATA DISK drive
hdb: MAXTOR 4K060H3, ATA DISK drive
hdc: FX600S, ATAPI CD/DVD-ROM drive
hdd: Maxtor 96147H6, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: 21095424 sectors (10801 MB) w/512KiB Cache, CHS=1313/255/63, UDMA(33)
hdb: 117266688 sectors (60041 MB) w/2000KiB Cache, CHS=7299/255/63, UDMA(33)
hdd: 120064896 sectors (61473 MB) w/2048KiB Cache, CHS=119112/16/63, UDMA(33)
hdc: ATAPI 6X CD-ROM drive, 256kB Cache, DMA
Uniform CD-ROM driver Revision: 3.12
Partition check:
hda: [EZD] [remap 0->1] [1313/255/63] hda1 hda2
hdb: hdb1
hdd: [PTBL] [7473/255/63] hdd1
wordt netjes herkent kan alleen mijn /dev/hde1 niet mounten herket de disk niet ...
iemand bekent met dit probleem ?
/etc/fstab ...
/dev/hde1 /fub ext2 defaults,errors=remount-ro 0 1
  • ACM
ACM
Software Architect
Werkt hier
Op vrijdag 21 september 2001 13:51 schreef fungus het volgende:
Weet je zeker dat je hem op de goede hpt370 hebt? Zo te zien heb je er twee.
Daarnaast zou je nog es kunnen spelen met de hdX= kernel-params te wijzigen en kan je proberen die tweede controller met de ideX= kernel-params uit te zetten.
Verder kan het zijn dat je flink moet spelen met dat soort settings.
Ik neem aan dat je de 2.2.19 kernel draait?
lo ACM m8 ;)
zo kom je elkaar weer tegen ;) ja ik heb er 2 denk ik 1 op mijn moederboard en 1 als insteekkaart draai momenteel 2.4.7
zet je icq ff aan enauthorize me ;)
groeten aan zeikerd ;)
Zit ie niet op je secundaire master?? Dan is t /dev/hdg
Of is het niet gewoon /dev/hda (dit zal wel niet)
nee hij zit op /dev/hde1 kijk maar naar mijn log ....
trouwens raar dat hij 6 ide devices herkent ...
ide0 ... ide5 en ik zou er maar 4 moeten hebben.
ide0 t/m ide3
Zo ziet het er bij mij uit met slechts 1 onboard HPT370.
29
30
31
32
33
34
35
36
37
38
39
40
41
    ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:pio
    ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:pio
PCI: Found IRQ 11 for device 00:13.0
PCI: Sharing IRQ 11 with 00:0d.0
    ide2: BM-DMA at 0xe400-0xe407, BIOS settings: hde:DMA, hdf:pio
    ide3: BM-DMA at 0xe408-0xe40f, BIOS settings: hdg:DMA, hdh:pio
hda: QUANTUM FIREBALLP AS20.5, ATA DISK drive
hdb: AOpen 12X DVD-ROM/ASH 01112001, ATAPI CD/DVD-ROM drive
hdc: Hewlett-Packard CD-Writer Plus 8200, ATAPI CD/DVD-ROM drive
hde: IBM-DTLA-305040, ATA DISK drive
hdg: ST340823A, ATA DISK drive
ide2 at 0xd400-0xd407,0xd802 on irq 11
ide3 at 0xdc00-0xdc07,0xe002 on irq 11
hda: 40132503 sectors (20548 MB) w/1902KiB Cache, CHS=2498/255/63, UDMA(33)
hde: 80418240 sectors (41174 MB) w/380KiB Cache, CHS=79780/16/63, UDMA(44)
hdg: 78165360 sectors (40021 MB) w/512KiB Cache, CHS=77545/16/63, UDMA(100)
Partition check:
 hda: hda1 hda2 < hda5 hda6 >
 hde: hde1 hde2 < >
 hdg: unknown partition table
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 439M
agpgart: Detected Intel 440BX chipset
agpgart: AGP aperture is 64M @ 0xd0000000
 ataraid/d0: ataraid/d0p1 ataraid/d0p2 < ataraid/d0p5 ataraid/d0p6 ataraid/d0p7 ataraid/d0p8 ataraid/d0p9 ataraid/d0p10 ataraid/d0p11 ataraid/d0p12 >
Highpoint HPT370 Softwareraid driver for linux version 0.01
Drive 0 is 39266 Mb
Drive 1 is 38166 Mb
Raid array consists of 2 drives.
ik moet denk ik die ide4 en ide5 uitzetten maar hoe doe ik dat ?
Waarschijnlijk kun je je onboard RAID controller uitzetten in je bios. Je zou ook het insteekkaartje kunnen verwijderen.
oeps hij doet het nu ....
ff de hpt370 controllerkaart eruit gehaald en op ide3 moederboard dev aangesloten herkent hem dan zondetr problemen ... strange maarja het werkt ;)
bedankt voor de moeite
fungus
