Cisco vraag
  • RedsnowWinter
  • Registratie: Maart 2026
  • Laatst online: 19-04 22:49
Mijn vraag
Is deze code juist?
Cisco
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
enable
configure terminal
hostname Core01_ARN
no ip domain-lookup
vlan 30
name Productie
vlan 40
name Marketing
vlan 50
name Gasten_WIFI
exit
interface vlan 30
ip address 10.10.30.1 255.255.255.0
no shutdown
exit
interface vlan 40
ip address 10.10.40.1 255.255.255.0
no shutdown
exit
interface vlan 50
ip address 10.10.50.1 255.255.255.0
no shutdown
exit
interface vlan 1
ip address 10.10.0.2 255.255.255.0
no shutdown
exit
vtp domain SOLAR
vtp mode server
vtp password solar
interface range fa0/1 , fa0/3 , fa0/24
switchport mode trunk
switchport trunk allowed vlan all
spanning-tree vlan 1,30,40,50 priority 4096
ip dhcp excluded-address 10.10.30.1 10.10.30.50
ip dhcp excluded-address 10.10.40.1 10.10.40.50
ip dhcp excluded-address 10.10.50.1 10.10.50.50
ip dhcp pool vlan30
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
dns-server 62.36.55.85
exit
ip dhcp pool vlan40
network 10.10.40.0 255.255.255.0
default-router 10.10.40.1
exit
ip dhcp pool vlan50
network 10.10.50.0 255.255.255.0
default-router 10.10.50.1
exit
ip routing
router ospf 1
network 10.0.0.0 0.255.255.255 area 0
access-list 150 deny ip 10.10.50.0 0.0.0.255 10.10.30.0 0.0.0.255
access-list 150 deny ip 10.10.50.0 0.0.0.255 10.10.40.0 0.0.0.255
access-list 150 deny ip 10.10.50.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 150 deny ip 10.10.50.0 0.0.0.255 172.16.5.0 0.0.0.255
access-list 150 deny ip 10.10.50.0 0.0.0.255 172.16.20.0 0.0.0.255
access-list 150 permit ip any any
arn
enable
configure terminal
hostname SW01_ARN
no ip domain-lookup
vtp domain SOLAR
vtp mode client
vtp password solar
interface range fa0/4 - 5
switchport mode access
switchport access vlan 30
interface fa0/1
arn2
enable
configure terminal
hostname SW02_ARN
no ip domain-lookup
vtp domain SOLAR
vtp mode client
vtp password solar
interface fa0/4
switchport access vlan 40
interface fa0/1
interface fa0/3
Notes
ssh -l Admin ip address
show startup-config
show running-config
write
show ip interface brief
show ip route
show arp / show ip arp
show vlan brief
show interface trunk
show lldp neighbors
show lldp neighbors detail
show cdp neighbors
show version
show log
show history
SW1#enable
SW1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
SW1(config)#inter
SW1(config)#interface fa0/1
SW1(config-if)#shutdown
Show ip route is voor routers
Show nei is voor switch
[ Voor 4% gewijzigd door rens-br op 02-03-2026 08:36 ]
  • Cyphax
  • Laatst online: 11:43
Cyphax
Moderator LNX/AI
Ik kan uit je post niet opmaken wat je precies probeert te bereiken?
  • Hero of Time
  • Laatst online: 20-10 22:19
Hero of Time
Moderator LNX
There is only one Legend
Geen flauw idee of het juist is, maar je vraag stel je iig op de verkeerde plek. Cisco maakt netwerkapparatuur, LNX is voor Linux en overige clients. Je bent voor netwerken net te ver gescrolled. Dit topic hoort dus niet hier.
LNX -> Netwerken.
Commandline FTW
  • PD2JK
  • Laatst online: 11:46
PD2JK
ouwe meuk is leuk
Geen cold spare liggen waar je de config even in kunt plakken?
Anders is er vast wel iets op Marktplaats te vinden waar je mee kunt pionieren.
Aangezien er in de config gerept wordt over 'interface fa0/$' hebben we het over een vrij oud beest. Is 100Mbps nog snel genoeg? Wordt het apparaat nog voorzien van updates?
[ Voor 38% gewijzigd door PD2JK op 01-03-2026 20:39 ]
Toen waren beige computers heel gewoon.
  • Shinji
  • Laatst online: 11:31
Het klinkt als iets voor een school opdracht...
  • Boudewijn
Boudewijn
omdat het kan
Dit is vast juiste code maar wat moet het doen?
Kom op zeg, wat een aartsluie vraag :|
  • Will_M
Will_M
Intentionally Left Blank
@RedsnowWinter
Download zelf bij Cisco even ‘packet tracer’ en zie wat je code gaat doen (of juist niet gaat doen).
https://www.netacad.com/a...ng-academy/packet-tracer/
  • remco_k
  • Laatst online: 20-10 22:36
remco_k
een cassettebandje was genoeg
Bij zo'n vraag is het handig als je er bij vermeld wat het zou moeten doen/wat de intentie is. Want zonder die info kan niemand vaststellen of dit juist is, of niet.
Alles kan stuk.
  • SkiFan
  • Laatst online: 09:54
Dit gewoon emuleren met GNX. Kun je al je Cisco spul mee testen.
Jurist in zijn vrije tijd, IT'er van beroep.
  • rens-br
  • Laatst online: 07:57
rens-br
Admin IN & Moderator Mobile
@RedsnowWinter welkom op Tweakers.
Je openingspost voldoet momenteel niet helemaal aan de wensen/eisen die we er aan stellen. Zo is het belangrijk om eerst wat eigen onderzoek te doen naar je probleem. Ook is het handig om zoveel mogelijk informatie te verschaffen. Zou je dus het volgende toe willen voegen:
- Waar is dit precies voor?
- Wat heb je al gevonden, geprobeerd en gedaan?
- Wat moet het doen?
- Wat voor hardware gebruik je allemaal? (merk en type)
Op die manier kunnen we je een stuk beter helpen.
[ Voor 6% gewijzigd door rens-br op 02-03-2026 08:38 ]
  • Asterion
  • Laatst online: 09:04
Je vergeet alleszins je configuratie op te slaan. Bij een reboot ben je alles kwijt.
Maar je zegt ook totaal niet wat je wilt bereiken. Geef eerst eens wat meer uitleg. Download daarnaast ook eens packet tracker waarin je je configuratie kan testen.
