Nieuwe FW downloads QNAP QTS 5.2.7.3297
  • Ventiman
  • Laatst online: 16-10 16:07
Artikel: download: QNAP QTS 5.2.5.3145
Auteur: @Drobanir
Er zijn een aantal nieuwe updates (zie o.a.: https://community.qnap.com/c/en/firmware/74)
QTS 5.2.7.3297 build 20251024 2025-10-27
QTS 5.2.7.3288 build 20251015 2025-10-17
QTS 5.2.6.3195 build 20250715 2025-07-30
Releasenotes update 5.2.7.3297 build 20251024:
[Security Updates]
- Applied multiple security updates to further enhance system security.
[New Features]
Control Panel
- When performing a firmware update, you can now choose to automatically install required app updates, ensuring a smooth app experience after the firmware update is complete.
[Enhancement]
Control Panel
- Added a setting in "Control Panel > System > Hardware > General" that allows users to enable or disable the IR sensor on supported NAS models, helping reduce unexpected system restarts that the IR sensor may cause.
Domain Security
- Simplified the setup process for Azure Single Sign-on (SSO) and updated the feature name to "Microsoft Entra ID Single Sign-on (SSO)".
NFS Serviece
- Adjusted the default settings for NFS host access to enhance the security of NFS exports.
[Fixed Issues]
- Fixed an issue where, under certain conditions, domain users could not copy certain files despite having the correct permissions.
- Resolved an issue where, if domain users had been assigned delegated roles, "Control Panel > Privilege > User Groups" would display an empty list unless users manually refreshed it.
- Fixed an issue where, when a container service port was connected via a USB-to-LAN adapter, disconnecting the LAN cable would cause the port to become inaccessible.
- Fixed an issue on certain NAS models where, after a firmware update, the system might incorrectly indicate that some disks have been removed.
- Improved startup stability for certain NAS models.
  • Drobanir
  • Laatst online: 18-10 08:48
Drobanir
Meukposter / BBG'er
Duckduck is my friend
Bedankt voor je tip, maar deze zijn van minstens een maand geleden en helaas te oud om nu nog te plaatsen op Tweakers.
There is no future in timetravel. Mijn waterkoeling-inbouw-fotoverslag (oud!).
