Probleem met tapestreamer op oude IBM RS/6000
  • Jazzy
  • Laatst online: 22:16
Jazzy
Moderator SSC/PB/AI
Moooooh!
Om te beginnen, dit is een hobbyprojectje en ik ben me er van bewust dat er niet zo veel parate kennis zal zijn, maar ik probeer het toch even.
Mijn systeem:
IBM RS/6000 43P Model 140
AIX 5.1 ML10
IBM FRU 59P6670 (Seagate STD2401LW) DDS4 20/40 tape drive
HP C5718A DDS4 tapes (nieuw)
Probleem:
Het schrijven van data naar tape geeft een foutmelding, zowel met backup als mksysb.
Hieronder de troubleshooting en informatie die ik verzameld heb, in het Engels.
/usr/bin/mksysb '-i' '-X' /dev/rmt0::
root@localhost:/root>/usr/bin/mksysb   '-i' '-X' /dev/rmt0
Creating information file (/image.data) for rootvg....
Creating tape boot image....................................
bosboot: Boot image is 14686 512 byte blocks.
0301-161 bosboot: dd failed to copy /dev/rmt0.1.
0301-165 bosboot: WARNING! bosboot failed - do not attempt to boot device.
0512-016 mksysb: Attempt to create a bootable tape failed:
        bosboot -d /dev/rmt0.1 -a failed with return code 48.
find /tmp | backup -ivf /dev/rmt0.1:
Mount volume 1 on /dev/rmt0.1.
        Press Enter to continue.
Backing up to /dev/rmt0.1.
Cluster 51200 bytes (100 blocks).
Volume 1 on /dev/rmt0.1
a            0 /tmp
a            0 /tmp/lost+found
a            0 /tmp/.strload.mutex
a            0 /tmp/block
a          157 /tmp/rc.net.out
a            0 /tmp/rc.net.serial.out
a            0 /tmp/.X11-unix
backup: /tmp/.X11-unix/X0 socket is not backed up.
a            0 /tmp/xlogfile
backup: /tmp/.PMDV1 socket is not backed up.
a            0 /tmp/sh8776.1
a         1120 /tmp/rpcbind.file
a            0 /tmp/sh15312.1
a            0 /tmp/.oslevel.datafiles
a            0 /tmp/.oslevel.datafiles/.oslevel.hold
backup: 0511-432 A write error occurred: There is an input or output error.
backup: 0511-079 The backup media may be damaged.
        Use a different disk to run the backup.
lscfg -vpl rmt0:
  DEVICE            LOCATION          DESCRIPTION
  rmt0              04-C0-00-5,0      Other SCSI Tape Drive
        Manufacturer................SEAGATE
        Machine Type and Model......DAT    9SP40-000
lsattr -E -l rmt0:
mode           yes Use DEVICE BUFFERS during writes          True
block_size     0   BLOCK size (0=variable length)            True
extfm          yes Use EXTENDED file marks                   True
maxlun         31  LVD SCSI Tape Drive                       True
res_support    no  RESERVE/RELEASE support                   True
var_block_size 0   BLOCK SIZE for variable length support    True
density_set_1  0   DENSITY setting #1                        True
density_set_2  0   DENSITY setting #2                        True
delay          45  Set delay after a FAILED command          True
rwtimeout      144 Set timeout for the READ or WRITE command True
ret_error      no  RETURN error on tape change or reset      True
lslpp -l | grep Tape:
  devices.scsi.tape.diag    5.1.0.50  COMMITTED  SCSI Tape Device Diagnostics
  devices.scsi.tape.rspc     5.1.0.0  COMMITTED  RISC PC SCSI Tape Device
  devices.scsi.tape.rte     5.1.0.54  COMMITTED  SCSI Tape Device Software
diag -d rmt0:
A PROBLEM WAS DETECTED ON Sat Jan  1 03:45:07 NFT 2000        801014
The Service Request Number(s)/Probable Cause(s)
(causes are listed in descending order of probability):
  973-320: Error Log Analysis indicates a permanent hardware failure.
    rmt0             FRU: n/a                  04-C0-00-5,0
    n/a              FRU: n/a                  04-C0-00-5,0
                     Test media.
ADDITIONAL INFORMATION FOR TAPE DRIVE (rmt0) IN LOCATION 04-C0-00-5,0        973016
This tape drive is not recognized by diagnostics.
For this reason, the SRN may be invalid.
Tried:
- Using a different tape
- Change block size from 512 to 0
- Set the streamer dip switches to all on, except 6, 8 and 9
- Checked the free space on /tmp, added -X to mksysb to automatically expand
None of the above made any difference. Noticed that the drive is recognized as 'Other SCSI Tape Drive' so reviewed the configuration. All looks well, except I don't know the proper value for density_set_1 and density_set_2, the current value of 0 indicates the highest possible value for this drive which should work. Shouldn't it?
Also tried to download and install a the Atape drivers but wasn't able to obtain a version 9.x.x.x which is the latest that was supported with AIX 5.1.
Currently having no other hardware or operating system available to test the tape drive in a different system.
At this point I'm out of options. The drive was sold to me as operable and seeing many others had similar issues with perfectly fine hardware I'm believing this is rather a configuration issue than a hardware problem. A bad tape would be possible, but two bad tapes form a new package? Not likely.
  • ninjazx9r98
  • Laatst online: 21:54
Het is een SCSI device dus het eerste om naar te kijken is of de boel goed zit qua termination.
Als dat niet op orde is kun je de meeste vreemde verstoringen verwachten.
  • koen05
  • Laatst online: 21:21
Hm, is al weer heel lang geleden dat ik een tapestreamer gebruikt heb, maar moet je niet naar /dev/st0 kijken?
(flashback ... mt -f /dev/st0 status ....)
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
ninjazx9r98 schreef op dinsdag 18 november 2025 @ 12:59:
Goed punt. Hij zit tussen de controller en harddisk op de kabel en termination staat uit. Wordt ook keurig gedetecteerd door de firmware en OS. Heb een heel aantal topics gelezen over mensen die dezelfde symptomen hadden, behalve dat dit dan 15-20 jaar geleden was, en SCSI problemen kwamen eigenlijk niet ter sprake. Leidt daar een beetje uit af dat het werkt of niet. En al zijn mijn problemen een beetje vaag, het is allemaal wel heel consistent.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
koen05 schreef op dinsdag 18 november 2025 @ 13:12:
Op Unix is het /dev/rmt0, op Linux inderdaad /dev/st0 en /dev/nt0.
  • DeBolle
  • Laatst online: 20:37
DeBolle
Volgens mij ligt dat anders
Jazzy schreef op maandag 17 november 2025 @ 21:09:
Oh boy, een 43P, met schuifje en een 604 CPU? :-)
bosboot wil naar de no-rewind device en vervolgens de data er achteraan, daar lijkt geen fout in te zitten.
Naast de al genoemde SCSI termination van de bus, kijk na of:
- DDS4 (standaard UltraWide) gaat werken op de SCSI kaart (standaard herinner ik mij DDS2 op een 43P model 133);
- Standaard SCSI is SCSI2/FastWide met de kaart in slot 1 - heeft de kabel/drive/term dezelfde specs?
- test met bijv. mt -f /dev/rmt0 rewind of de tape beweegt
- C5718A is een 150m DDS4 tape, test ook eens met dde 90m of 120m tape - die worden ondersteund in DDS2 format. AIX 5.1 zou daar moeilijk over kunnen doen.
Specs ...ik doe er niets meer aan.
  • ninjazx9r98
Jazzy schreef op dinsdag 18 november 2025 @ 13:23:
Het leuke en/of vervelende met SCSI termination issues is juist dat het alle kanten op kan gaan. Het kan werken, het kan niet werken, het kan half werken, het kan lijken te werken en alles wat daar tussenin zit. Het kan ook dagen/weken/maanden goed werken en er ineens mee stoppen.
Zou er ook niet teveel uit afleiden dat termination weinig genoemd wordt, zat mensen die destijds het belang van termination niet in wilde zien cq geloven omdat het ook vaak/meestal goed ging of leek te gaan.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
ninjazx9r98 schreef op dinsdag 18 november 2025 @ 14:55:
Begrijp je helemaal en wil het niet wegwuiven, ik deel gewoon mijn gedachtegang en waarom ik denk dat ik geen termination probleem heb. Heb je een idee hoe ik dat met zekerheid kan testen of controleren?
  • ninjazx9r98
Jazzy schreef op dinsdag 18 november 2025 @ 15:35:
SCSI is al weer een tijdje geleden voor me dus moest even diep graven in geheugen en zoeken online.
Als het klopt wat ik heb kunnen vinden dan heb je een DDS drive nodig die multimode ondersteunt en het typenummer dat je geeft zou dat moeten doen. Hij zou moeten werken in SE mode in een 43P, niet in LVD.
De DDS kan automatisch terug schakelen maar bij sommige schijn je dat te kunnen doen met jumpers. De DDS moet in SE/multimode en niet in LVD.
Het SCSI type van de bus zou je kunnen zien met "lsdev -Cc adapter"
Standaard zou je "Wide/Fast-20 SCSI" terug krijgen en dat is SE oftewel Single Ended.
Bij "Ultra/Wide LVD" is het LVD en kan de drive ook werken in LVD mode maar van wat ik kan vinden is LVD niet de standaard in een 43P tenzij die toegevoegd is.
Voor wat betreft termination moet het laatste device in de keten een terminator zijn of op het laatste device moet termination ingeschakeld zijn. Termination is en blijft een lastig verhaal.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
DeBolle schreef op dinsdag 18 november 2025 @ 13:46:
Een 604e op 332 MHz. :)
Qua SCSI kan ik geen probleem ontdekken, de drive wordt herkend en ik kan hem bedienen met tctl. Schrijfopdrachten genereren ook gewoon activiteit tot de foutmelding komt.
De SCSI-controller is on-board en inderdaad Wide SCSI. De streamer ondersteunt 68-pin Ultra2 SCSI (LVD), 68-pin SCSI Wide (SE) en 50-pin SCSI-2 met een 68 naar 50 adapter. Met dip switch 9 kun je Wide toestaan of hem beperken tot Narrow. Die stond bij mij op Wide maar heb ik net om te testen op Narrow gezet, maakt geen verschil en geeft precies dezelfde fout na een tijdje schrijven.
Met de handleiding (https://bitsavers.compute...0_Installation_199910.pdf) er naast ook de rest nog even nagelopen. Alles staat geconfigureerd voor AIX.
Termination is het probleem definitief niet, die staat aan op het laatste device in de keten (HD) en de streamer kan niet eens termineren. Ik had geen probleem met termination en heb er alleen een non-terminating device op de kabel bijgezet die tussen de controller en de andere devices hangt.
Ook nog even contact gehad met de Ebay-verkoper en gevraagd hoe hij hem getest heeft, dat was door een tape te lezen in een werkend systeem.
Wat rest zijn dan testen met andere tapes, al staat in de handleiding specifiek dat 150 meter 20/40 tapes ondersteund worden. En misschien het meest voor de hand liggende, een cleaning tape. Het ledje brandt dus hij zal er aan toe zijn.
Denk dat ik zo alle vragen weer beantwoord heb. Als bonus nog even een foto van het systeem nadat ik dipswitch 9 had omgezet. Heb de drive-cage inmiddels los in minder dan een minuut. :) Afbeeldingslocatie: https://tweakers.net/i/7sDUYdz1DGmWqE6RJyIdbAaFGmQ=/800x/filters:strip_icc():strip_exif()/f/image/qlb120m2ZEH2BTGs6phrHn1L.jpg?f=fotoalbum_large
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Om deze nog even af te sluiten... Heb later nog een identieke drive gekocht via Ebay en daar ook issues mee, alleen net weer iets anders. Andere foutmeldingen, andere mechanische geluiden en ander gedrag van de drie LEDs. Opnieuw weer de handleiding er bij, jumpers/dipswitches gecontroleerd maar niet succesvol kunnen kunnen lezen of schrijven. Dat bevestigt mijn vermoeden dat deze drives gewoon niet goed meer zijn door de ouderdom.
Inmiddels wat nieuwe hardware binnen en zojuist een succesvolle backup kunnen maken naar een externe HP C1554A DDS-3 drive:
Afbeeldingslocatie: https://tweakers.net/i/XbTGI2S6RKKHUvT-wCorkpseSc4=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/G1EYhTaPAtUNtLczb3n2aY8S.png?f=user_large
